SantosDumont Posted July 11, 2019 Author Report Share Posted July 11, 2019 5 hours ago, Browncbr1 said: Do you run ROP with low power settings much? Usually I do a cruise climb with full mixture then run LOP in cruise. That's the procedure specified in the manual for the IO-360-ES because it has an altitude compensating fuel pump. 2 Quote Link to comment Share on other sites More sharing options...
