afward Posted May 23, 2019 Report Share Posted May 23, 2019 (edited) Looks like the closest MSC is AGL Aviation at KMRN. I just sent them an email to check availability and cost, but I'd really like to see if anyone has other recommendations. The plane is a '68 C. Thanks! @carusoam thanks. The plane is in Louisville, KY and AGL Aviation is of course in Morganton, NC. Edited May 24, 2019 by afward Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 23, 2019 Report Share Posted May 23, 2019 KLOU... https://en.m.wikipedia.org/wiki/Bowman_Field_(airport) KMRN... https://www.airnav.com/airport/KMRN NC 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 24, 2019 Report Share Posted May 24, 2019 AGL is a really well known resource... and MSer. how far away is the plane from there? Getting a seller to move the plane a long distance becomes a challenge if things don’t work out so well... best regards, -a- Quote Link to comment Share on other sites More sharing options...
afward Posted May 24, 2019 Author Report Share Posted May 24, 2019 Skyvector gives me 242.3nm direct. Maybe too far for the seller, but worth checking either way. Any closer recommendations? Anyone? Quote Link to comment Share on other sites More sharing options...
kpaul Posted May 24, 2019 Report Share Posted May 24, 2019 2 hours ago, afward said: Skyvector gives me 242.3nm direct. Maybe too far for the seller, but worth checking either way. Any closer recommendations? Anyone? Well, Joey Cole of Cole Aviation is located @ KDNN its about 30nm closer. I know you are looking for a PPI, but I fly my plane from Mississippi to take it to Lynn and Tamara at @AGL Aviation Quote Link to comment Share on other sites More sharing options...
afward Posted May 24, 2019 Author Report Share Posted May 24, 2019 14 minutes ago, kpaul said: Well, Joey Cole of Cole Aviation is located @ KDNN its about 30nm closer. I know you are looking for a PPI, but I fly my plane from Mississippi to take it to Lynn and Tamara at @AGL Aviation I could be convinced to do so as well from time to time. Dmax is closest, though, and for routine stuff I have an on-field A&P (now IA) that appears to prefer owner-assisted work. But first, the PPI... Quote Link to comment Share on other sites More sharing options...
Austintatious Posted May 24, 2019 Report Share Posted May 24, 2019 (edited) 15 hours ago, carusoam said: AGL is a really well known resource... and MSer. how far away is the plane from there? Getting a seller to move the plane a long distance becomes a challenge if things don’t work out so well... best regards, -a- Heed this... Just did this (as buyer) and it can be challenging. Even when things DO work out (as in my case) Edited May 24, 2019 by Austintatious 1 Quote Link to comment Share on other sites More sharing options...
