Joe Larussa Posted May 13, 2019 Report Share Posted May 13, 2019 Where do you like to keep your oil level? I usually like it at 6 quarts if I’m doing flights around and hour or two. Long trips I like to start at seven. Do you notice any indications when it falls below a certain level? Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted May 13, 2019 Report Share Posted May 13, 2019 7 minutes ago, Joe Larussa said: Where do you like to keep your oil level? I usually like it at 6 quarts if I’m doing flights around and hour or two. Long trips I like to start at seven. Do you notice any indications when it falls below a certain level? same on a 64c 180hp......I find anymore than 6.25 just ends up on the belly..... Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 13, 2019 Report Share Posted May 13, 2019 IO550...8 qts. Excess oil doesn’t seem to find the vent. -a- Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 13, 2019 Report Share Posted May 13, 2019 Five flight schools I've been associated with had a standard practice of filling Lycoming IO-360, O-360, O-320 engines to 7 qts on the dipstick and adding a quart when it got down to 6. I've run both my M20Js that way with very little oil on the belly from the breather. Skip 2 Quote Link to comment Share on other sites More sharing options...
Joe Larussa Posted May 13, 2019 Author Report Share Posted May 13, 2019 5 minutes ago, PT20J said: Five flight schools I've been associated with had a standard practice of filling Lycoming IO-360, O-360, O-320 engines to 7 qts on the dipstick and adding a quart when it got down to 6. I've run both my M20Js that way with very little oil on the belly from the breather. Skip Ever notice a twitchy oil pressure reading below 6 quarts? Quote Link to comment Share on other sites More sharing options...
Andy95W Posted May 13, 2019 Report Share Posted May 13, 2019 19 minutes ago, Joe Larussa said: Ever notice a twitchy oil pressure reading below 6 quarts? In the winter during cold temperatures I'll let mine go down to 5 1/2 or so. JPI oil pressure and temperature stay rock solid in cruise. 1 Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted May 13, 2019 Report Share Posted May 13, 2019 23 minutes ago, Joe Larussa said: Ever notice a twitchy oil pressure reading below 6 quarts? Twitchy, no. But maybe on a long flight that starts at 6 qts, maybe, if I really analyze it, maybe a few (like 5) degrees warmer oil and a psi or 2 less pressure on the jpi. But still steady. I try to start all flights short or long at 6 or it gets real oily underneath. Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 13, 2019 Report Share Posted May 13, 2019 Twitch when oil levels drop is typical of air bubbles getting drawn into the system... My Chevy will do it too... Even though the pick-up for the oil is way down at the bottom... The oil is spread around the engine really well when flying... The oil gear pump has no difficulty delivering air that sneaks in to the other side... PP thoughts only, -a- 1 Quote Link to comment Share on other sites More sharing options...
kerry Posted May 13, 2019 Report Share Posted May 13, 2019 When it gets below 5 quarts I add a quart. Anything above 6 goes thru the blow by. O-360. 2 Quote Link to comment Share on other sites More sharing options...
kpaul Posted May 13, 2019 Report Share Posted May 13, 2019 9 hours ago, carusoam said: IO550...9 gal. Excess oil doesn’t seem to find the vent. -a- 9 Gallons? Are you running a big radial on your O? 1 2 Quote Link to comment Share on other sites More sharing options...
EricJ Posted May 13, 2019 Report Share Posted May 13, 2019 I went to the Lycoming rep's talk at the recent IA seminar here and he explained that anything above 6 qts in an I/O-360 is essentially in the windage of the crank and is susceptible to getting blown out. The 8 qt capacity meets the FAAs requirement of being able to run for a certain number of hours (I think 4 hours? May have had to do with the tank capacity.) at the maximum oil consumption rate before starvation. I think the pump still makes pressure at 2 Qts or something like that. If the pressure is starting to twitch at much higher levels there may be a pickup problem. 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 13, 2019 Report Share Posted May 13, 2019 4 hours ago, kpaul said: 9 Gallons? Are you running a big radial on your O? I put in so much oil, I must have slipped and fell on all the excess.... For penance, I tried to find a decent resource... proving my dipstick being longer than all the other IO550s... Oil Capacity for the IO550s is only 8 quarts. But, if you fill it after a flight... you will find an extra quart showing up on the dipstick a day later... The following should be (was supposed to be) a link to an interesting read for the IO550 engine... Penance part III... http://www.continentalmotors.aero/xPublications/Maintenance Manuals/OI-16ELEC_2015-07-15/ I highly recommend finding the engine manufacturer’s manual for your engine... Compare to your POH written by Mooney... And your STC written by Rocket Engineering... They all cover the same ground, but do it in an interesting way specific to the plane... Fuzzy PP memories only, not a mechanic... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted May 13, 2019 Report Share Posted May 13, 2019 3 hours ago, EricJ said: I went to the Lycoming rep's talk at the recent IA seminar here and he explained that anything above 6 qts in an I/O-360 is essentially in the windage of the crank and is susceptible to getting blown out. The 8 qt capacity meets the FAAs requirement of being able to run for a certain number of hours (I think 4 hours? May have had to do with the tank capacity.) at the maximum oil consumption rate before starvation. I think the pump still makes pressure at 2 Qts or something like that. If the pressure is starting to twitch at much higher levels there may be a pickup problem. IIRC the FAA used to require a sump at least twice the capacity of the minimum certified oil volume. Since the IO-360 has a minimum volume of 4 qts, the sump has to be 8 qts. I think there is actually one IO-360 meant for aerobatics that is certified down to 2 qts, but I think it still has an 8 qt sump I'm guessing they changed that with the new part 23 certification requirements? Quote Link to comment Share on other sites More sharing options...
rbridges Posted May 13, 2019 Report Share Posted May 13, 2019 I think I read that to be certified, an engine has to run on half the maximum volume. I generally keep mine between 5-6; closer to 6 for longer trips. 1 Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted May 13, 2019 Report Share Posted May 13, 2019 24 minutes ago, carusoam said: I put in so much oil, I must have slipped and fell on all the excess.... For penance, I tried to find a decent resource... proving my dipstick being longer than all the other IO550s... Oil Capacity for the IO550s is only 8 quarts. But, if you fill it after a flight... you will find an extra quart showing up on the dipstick a day later... The following should be (was supposed to be) a link to an interesting read for the IO550 engine... I was a little surprised with my oil level--when I fill the motor with 6 qts after an oil change and do the test run, the next time I check the oil level it will say almost exactly 6 qts. I always thought the oil filter would hold a cup or so, and the oil system would hold another cup. Quote Link to comment Share on other sites More sharing options...
bradp Posted May 13, 2019 Report Share Posted May 13, 2019 Long trips I'll do 6.5 and add at 6 (knowing that I've probably got more in the crankcase that hasn't sunk to the sump yet). Local flights I try to keep it around 6. If I put 8 in it's on the belly. If I put 7 in it's not on the belly as much, but my "consumption rate" goes up to 1 qt/4-5 hrs. If I keep it around 6-6.5 my consumption rate is 1 Qt / 7 hrs and that's the figure I use as my personal consumption baseline. That and my belly / antennas stay cleaner. Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 13, 2019 Report Share Posted May 13, 2019 24 minutes ago, jaylw314 said: I was a little surprised with my oil level--when I fill the motor with 6 qts after an oil change and do the test run, the next time I check the oil level it will say almost exactly 6 qts. I always thought the oil filter would hold a cup or so, and the oil system would hold another cup. The IO550 has its oil cooler mounted to the engine... lots of surface area that is able to drain back over time(?) and it’s oil filter is mounted upside down as well... According to the drawing below.... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted May 13, 2019 Report Share Posted May 13, 2019 3 minutes ago, carusoam said: The IO550 has its oil cooler mounted to the engine... lots of surface area that is able to drain back over time(?) and it’s oil filter is mounted upside down as well... That's interesting with the upside down oil filter--that must be a pain in the heiney to change If the oil cooler is right on the motor, I'd figure it should drain pretty darn quickly, right? I mean, the IO-360 oil cooler is waaay, back at the firewall in comparison... Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted May 13, 2019 Report Share Posted May 13, 2019 I'll leave it at 5 or 6 for short flights. Long flights 3 hours + I'll put it at 7. Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 13, 2019 Report Share Posted May 13, 2019 3 hours ago, jaylw314 said: IIRC the FAA used to require a sump at least twice the capacity of the minimum certified oil volume. Since the IO-360 has a minimum volume of 4 qts, the sump has to be 8 qts. I think there is actually one IO-360 meant for aerobatics that is certified down to 2 qts, but I think it still has an 8 qt sump IO-360/O-360 oil capacity is: Max 8, Min 2, Aerobatic engines are dry sump. Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 13, 2019 Report Share Posted May 13, 2019 17 hours ago, Joe Larussa said: Ever notice a twitchy oil pressure reading below 6 quarts? No, but I did note a decrease in oil pressure and an increase in temperature when it got down to 4. Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted May 13, 2019 Report Share Posted May 13, 2019 4 minutes ago, PT20J said: IO-360/O-360 oil capacity is: Max 8, Min 2, Aerobatic engines are dry sump. Yeah, now I'm all confused The TCDS says the minimum usable is 6 qts Quote Link to comment Share on other sites More sharing options...
PT20J Posted May 13, 2019 Report Share Posted May 13, 2019 2 minutes ago, jaylw314 said: Yeah, now I'm all confused The TCDS says the minimum usable is 6 qts Usable (not minimum usable) qty is 6 qts. 8 - 6 = 2 minimum. 1E10_Rev_28.pdf 1 Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted May 13, 2019 Report Share Posted May 13, 2019 16 minutes ago, PT20J said: Usable (not minimum usable) qty is 6 qts. 8 - 6 = 2 minimum. 1E10_Rev_28.pdf 302.02 kB · 1 download Oooooh, I get it Quote Link to comment Share on other sites More sharing options...
sdflysurf Posted May 13, 2019 Report Share Posted May 13, 2019 Thank you for starting this thread. So as a new aircraft/mooney owner I feel (feel as in nothing scientific here - gut telling me only) that my M20F likes to show about 5-6 on the dipstick and any more that I add has been ending up leaking/blowing/whatever out and appearing on the bottom of the plane. Sounds like that is perfectly normal now and what exactly causes this? My oil pressure and temp have always seemed fine, I was just getting concerned that I needed to keep a couple of qts of Aeroshell 100w+ in my baggage compartment. Quote Link to comment Share on other sites More sharing options...
