TheJudasNut Posted May 11, 2019 Report Share Posted May 11, 2019 Hello again, For those of you using Fltplan.com or FltplanGo, would you care to share your username and tail number? I'm seeking different profiles to find something accurate for my friend's new airplane. If you have a profile, please also indicate any specifics regarding how you use it, ie: assumed taxi time, airspeed used in climb, cruise mixture strategy, and descent airspeeds/power settings. Thank you in advance to any and all who are willing to share your their numbers. -JN Quote Link to comment Share on other sites More sharing options...
RLCarter Posted May 11, 2019 Report Share Posted May 11, 2019 Using someone else's performance profile is no different than using the generic profile that is already there. Your friend needs to use real world numbers for their aircraft to be accurate 1 Quote Link to comment Share on other sites More sharing options...
skydvrboy Posted May 12, 2019 Report Share Posted May 12, 2019 I used the generic F profile and then gradually changed it for what I was seeing in my own plane and how I fly it. I'm usually within 5 minutes and a gallon of fuel of what it shows on a long flight or a series of shorter flights. The generic profile was really close if I flew the way it was set up. It assumed rich of peak and reduced throttle for descent at cruise airspeed. I cruise lean of peak and maintain cruise power during the descent for extra speed. Your mileage may vary, but I'd start with whatever the default profile is for a C model and make adjustments from there. 1 Quote Link to comment Share on other sites More sharing options...
TheJudasNut Posted May 12, 2019 Author Report Share Posted May 12, 2019 18 hours ago, RLCarter said: Using someone else's performance profile is no different than using the generic profile that is already there. Your friend needs to use real world numbers for their aircraft to be accurate Unfortunately, the generic profile that I see in the drop-down menu is for a 200HP M20E. I was hoping to fly a few legs and compare the estimates from other profiles to the resultant true air speeds, times, and burns that occur during real flights. I thought it would be easier to begin "tightening" the profile if I started from a C model rather than the available E model data. Quote Link to comment Share on other sites More sharing options...
TheJudasNut Posted May 12, 2019 Author Report Share Posted May 12, 2019 17 hours ago, skydvrboy said: I used the generic F profile and then gradually changed it for what I was seeing in my own plane and how I fly it. I'm usually within 5 minutes and a gallon of fuel of what it shows on a long flight or a series of shorter flights. The generic profile was really close if I flew the way it was set up. It assumed rich of peak and reduced throttle for descent at cruise airspeed. I cruise lean of peak and maintain cruise power during the descent for extra speed. Your mileage may vary, but I'd start with whatever the default profile is for a C model and make adjustments from there. Thank you for sharing your experience. That may be the best I can do for now, although there doesn't seem to be a C model default profile online. If there was, I would probably have been satisfied to start with that. Quote Link to comment Share on other sites More sharing options...
vorlon1 Posted May 12, 2019 Report Share Posted May 12, 2019 I passed on the numbers for my 67c several months ago... I guess they still haven't incorporated them. Quote Link to comment Share on other sites More sharing options...
TheJudasNut Posted May 12, 2019 Author Report Share Posted May 12, 2019 38 minutes ago, vorlon1 said: I passed on the numbers for my 67c several months ago... I guess they still haven't incorporated them. Would you mind sharing your Fltplan user name? I would be very grateful for this data. Quote Link to comment Share on other sites More sharing options...
vorlon1 Posted May 13, 2019 Report Share Posted May 13, 2019 I too used the generic f profile. Quote Link to comment Share on other sites More sharing options...
