Need a little help...
afward
Well, we might've found our starter plane: A 1963 M20C (I'll ask for comments in the vintage forum here).  I'm obviously a little excited, but unfortunately I'm also not current and don't have ready access to get that way quickly.  So I'm in a bit of a pickle: How do I test-fly and airplane I'm not proficient enough to fly?
My home airport is KSUZ, and the plane in question is at KRST.
What would be your suggestions for handling this situation?  I can drive there (26 hours round-trip!), but I'll still need someone who knows what to look at to actually check it out...
Thanks!
Link to comment
Share on other sites
PPI can include the test flying part... I used a guy named DMax... for that...
That far away costs a lot of extra time and money...
Short cutting the obvious can get really expensive extra fast...
See if an MSer can give it the once over... then send it for PPI...
It is hard to get excited about that much work that far away... or adsorbing so much risk... on the unknown...
Do you have a transition trainer in mind...? This might be the time to use his expertise and do some training on the flight home.
Try to find something closer to home for your first plane...  Ken Reed often shares his experience of buying good planes without even seeing them... so it is possible...
Buying machines at a distance isn’t very hard... making sure it meets your expectations is quite the challenge...
If you don’t have expectations...  get ready first, then buy the plane...
PP thoughts only, not a CFI...
Link to comment
@Hank KRST in Rochester, MN is correct. :)
@carusoam I'd thought of having OasisAero in WIllmar do the PPI, and looking for someone to do transition training was already on my to-do list.  The hardest part seemed to be getting in-person with the thing and having someone who could fly it safely to help me check it out.  All that said, your point is not lost on me; finding something I can reasonably get to (and back!) in a day seems wise...
Link to comment
On the other hand, you don't find great M20C's for sale in every city. So when you find a good one, it's worth going to get it. Here are my suggestions...
  1. Use the MooneySpace map to see who from MooneySpace here is close to KRST. Reach out to them to see if they'd go by and look at it for you. This is just to have someone other than the seller tell you about the plane.  Assuming you still want the plane after this...
  2. Negotiate a purchase price pending a pre-buy inspection and arrange to have the guys at OasisAero do the pre-buy. At this point, buy a plane ticket to Minnesota and go look at it yourself and talk with Oasis. Arrange to be there the day Oasis gets the plane. Assuming all is still go...
  3. Leave the plane with Oasis and go home. Await the results of the pre-buy... Also start arranging for a CFI to fly the plane home with you from KRST.
  4. Assuming a successful pre-buy inspection, wire the funds to the seller, call the CFI and go get the plane.
In my opinion, flying the plane is much less important than the pre-buy inspection. You might also send the details/link to the plane you're interested in, so one of us here on the forum to help you evaluate it and make an informed decision. There is a lot of experience on this forum and several who have bought and sold a lot of Mooneys.
  • Like 6
Link to comment
Looking at the map, I see a couple people that might help.  I'll reach out to them privately.
I started a separate thread to discuss the plane itself (seemed appropriate to split the discussions).  It's over in the vintage topic if you'd like to jump in there.  I'd certainly appreciate any advice or commentary anyone can provide.
Edited by afward
Fixing wierd extra spaces?
Link to comment
Says me go visit said airplane and owner, and see if said owner can take you for a flight  before or after the PPI.  Give you a chance to see everything at work.  A good idea would be to hire a CFI to give you instruction as you fly said airplane back home.   I wound up having to train int eh aircraft remotely, which wasn't ideal.  But it worked out.
Don't be afraid to do lots of dual.  Moneys are neither hard to fly or land.  But they'll bite if treated wrong.
Link to comment
If we move forward with an offer and PPI, I certainly will go to the plane to fly in it.  At the point I know we're moving forward I'll also search out a CFI for transition training.  It'll probably be more than just the minimum hours just so I know I'm comfortable with it.  We'll see how it works out...
My impression is that Mooneys, in general, don't tolerate sloppiness like certain other types...  Not a bad thing, IMO.  I don't doubt I'll get pretty good at going around before I get good at not needing to.
Link to comment
The most important thing in a Mooney is to be on speed on final.  In your Ranger if you're over the numbers at 75mph and hold it off the airplane will land itself.  The only caution about going around is a Mooney in landing configuration has the mother of all pitch up motions when you firewall it.  It can easily be handled but will be a real surprise if you aren't ready for it.
Good luck in your purchase, and do post up some photos when you're done.  Like I said, I think the one you're looking at is a bargain for the price.  Isn't ideal, but for the ideal plane you're going either going to pay a lot more or search a lot more and get a lot more lucky.
Link to comment
A few points.
I would not fly PIC in a plane I am looking to purchase anyway. I would want the seller to take me for a ride.  If it is at a broker the broker can be PIC. So it doesn't matter being current or rated. In fact, for both of my Mooney purchases I was not qualified to fly it when I bought it. For the J I was not complex rated and for the Encore I was not high performance rated. Transition training took care of those short comings.
Regarding the pre-purchase, there is a ton you can do on your own without employing a mechanic. Take off the cowl and take a look. Are things neat and clean? Or are they oily, dirty, chafed, corroded, and worn? Even a novice can spot the difference. Remove the tail avionics bay panel and take a look in the tail. Look for corrosion and dirt. Remove wing access panels and take a look inside. Look in the wheel wells for corrosion. Take a look at the logbooks. Look for regular oil changes and maintenance. 10 hours and no maintenance between annuals is a red flag. Years with no annual is a red flag. I looked at a number of planes and I have rejected a lot of planes in my pre-pre purchase inspection. Once past that we can pay for a pro pre-purchase inspection.
Link to comment
I am based just north of you at CXW. I have access to an M20C in Conway if you ever want to come up; I own a K (252). We have 4 (or 5) Mooneys based here. I think there is another guy flying a short body out of SUZ, recently. There is an SR22 based there that I fly some for the owners.
Link to comment
Yeah, I'd seen your location before and thought we might arrange a meeting sometime if I ever got around to a real introduction...  Didn't realize there were so many Mooneys over there, though.
That said, I know at least one SUZ-based short body and have been in it for a couple flights (not PIC).  My wife has also sat in it, though the front seats were out at the time for annual.
Are any of the Mooney pilots there current CFIs?  SUZ doesn't have a Mooney CFI (the club has four or five CFIs, but none are Mooney-specific).
Link to comment
@larryb You make a fine point about the test flight.  Of course, that takes me back to the problem of getting to the bird to check it out...
I did just receive the last ten years of logbooks, and I'm told he has the rest but hasn't digitized them yet.  I'll probably spend some time tomorrow going through what he sent.
Link to comment
Yes the other 252 owner is a CFI and a long-time Mooney owner - a C before the 252, but currently flies for a local company. We also have a few other guys that have other jobs (professional pilots) that could work for CFI check-outs in a Mooney. Hopefully soon, I can finish my CFI up and be another resource.
My 252 is currently offline for complete panel upgrade but is in the final stretch of completion.
As you get closer, let me know how I can help.
Link to comment
17 minutes ago, Ross Taylor said:
Just keep in mind that it takes a while. I just got my disc, ordered 4 weeks prior.
WOW!
That is SLOW.  It's been a couple of years since I ordered one, but it only took a week, at most.  There's government  progress:wacko:
Link to comment
9 hours ago, Yetti said:
Order the disk from the FAA if you are serious
9 hours ago, MikeOH said:
Order it, even if you're not :D
I must have a dozen, or more, from when I was shopping.  They are all of $10.
8 hours ago, Hank said:
So order it now, @afward!
Ordered. :)
@Yetti thanks for the reminder.
Link to comment
10 hours ago, MrRodgers said:
DISC?
What are you referring to?
You can order a CD-ROM disc with all of their 337 records. We got ours after buying a '66 E, so I could compare the 337s I have to what the FAA has. In this particular case, the recommendation is to order that disc pre-purchase... a good idea that I didn't even know about until recently.
https://www.faa.gov/licenses_certificates/aircraft_certification/aircraft_registry/copies_aircraft_records/
Edit to add a note: I had to hunt our PCs at work to find one with a working CD drive, so I could move the files to a flash drive. If you really want to be nostalgic, you can fax them your request. Considering what went into making and mailing the disc, $10 is a bargain.
Link to comment
Well, I'm having a little difficulty getting eyes on the plane I have under consideration (seller isn't the most responsive and at best I'm a couple weeks out from being able to go myself), so...
Would it be better to buy a '63 C that's already ADS-B compliant, has a mid-time engine and non-AD prop hub, but needs IFR re-cert (and probably AI overhaul + new clock), probably new gear pucks, and doesn't have A/P or GPS, OR...
... a '68 C with GX60, STEC30 w/ alt hold & "GPS nav tracking" (GPSS?), 6-pack panel, Strikefinder, nice paint & decent interior, sold by a broker at a lower cost, but has a beyond TBO engine and needs a new CDI to be IFR legal (has a single HSI now)?
Edit: Or should I hold off until there's better inventory available?
Edited by afward
Link to comment
Post some links... or send them in a PM. I'd be interested to take a look.
Link to comment
