BaldEagle Posted April 14, 2019 Report Share Posted April 14, 2019 Hi all, Thought I'd reach out to the forum before I call the shop in the morning. I was 15 mins out from home base this afternoon and the Aspen PFD starts running off battery and the Low Voltage light is flickering. Ammeter was showing a very small discharge. The only other odd behavior is that all of the CHTs on the EDM 700 was showing zero. I didn't have a lot of time to diagnose: power cycled the Aspen, would run fine for a minute and then would start running off battery again and low voltage light would flicker again. Pulled the alternator circuit breaker, recycled after a minute, same symptoms, same after pulling Aspen breaker. When the low voltage light went out the temps started rising on the JPI, and then back to zero when the low voltage light came back on. This all happened at cruise power settings. I'm guessing it's the alternator or voltage regulator, but I'd be grateful for any suggestions. Main battery was replaced a couple of weeks ago. Quote Link to comment Share on other sites More sharing options...
DXB Posted April 14, 2019 Report Share Posted April 14, 2019 You may get lucky and find its just a corroded/ loose contact on the alternator (it was for me). Check the alternator belt tension also. Assuming its a Plane Power, the install manual has a detailed troubleshooting procedure- it should be followed before pulling the alternator. Also note the Aspen pfd will revert to battery with only a small drop in bus voltage - something like 12.3V Quote Link to comment Share on other sites More sharing options...
kortopates Posted April 14, 2019 Report Share Posted April 14, 2019 Hi all,....Pulled the alternator circuit breaker, recycled after a minute, same symptoms, same after pulling Aspen breaker. Did you reset the field CB or Alt output CB.The field is one you want to reset.But it could be anything including a broken field wire at the alternator.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
BaldEagle Posted April 14, 2019 Author Report Share Posted April 14, 2019 7 minutes ago, kortopates said: Did you reset the field CB or Alt output CB. The field is one you want to reset. But it could be anything including a broken field wire at the alternator. Sent from my iPhone using Tapatalk Alt. Field Quote Link to comment Share on other sites More sharing options...
kortopates Posted April 14, 2019 Report Share Posted April 14, 2019 Good news is that these are usually fairly quick to diagnose. Hopefully it's just a bad/broken connection.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 15, 2019 Report Share Posted April 15, 2019 2 hours ago, BaldEagle said: Hi all, . The only other odd behavior is that all of the CHTs on the EDM 700 was showing zero. bad loose ground. Start at the battery. Make sure all connections are shiny bright. Check engine ground strap. 1 Quote Link to comment Share on other sites More sharing options...
BaldEagle Posted April 15, 2019 Author Report Share Posted April 15, 2019 3 hours ago, DXB said: Assuming its a Plane Power Kelly Aerospace, who I’ve never heard of. The replacement original listed on Spruce is a Hartzell, with the same part number. I think my alternator may be rather old. I did drop the lower cowling this afternoon and poked about, nothing obvious and all the connections to the back of the alternator looked good (nothing broken or loose). I’ll get it booked in to an avionics shop to get a diagnosis. I’ve been out of the airplane ownership thing for a while, and the one thing that used to have me pulling my hair out were electrical issues Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 15, 2019 Report Share Posted April 15, 2019 (edited) Kelly aerospace was bought by Hartzell. Its the same company in Alabama, the same employees who cant read, spell, or put accessories together correctly. Edited April 15, 2019 by jetdriven 1 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted April 15, 2019 Report Share Posted April 15, 2019 1 hour ago, BaldEagle said: Kelly Aerospace, who I’ve never heard of. The replacement original listed on Spruce is a Hartzell, with the same part number. I think my alternator may be rather old. I did drop the lower cowling this afternoon and poked about, nothing obvious and all the connections to the back of the alternator looked good (nothing broken or loose). I’ll get it booked in to an avionics shop to get a diagnosis. I’ve been out of the airplane ownership thing for a while, and the one thing that used to have me pulling my hair out were electrical issues My first choice would be an A&P that's good at airframe electrical. An avionics shop would likely swap new parts in - if they'll do the job. These are repairable if you have the patience and not in a hurry. I recently had my rotor in an my alternator short out, but .25 AMU's later I had it repaired with new rotor, brushes and bearings versus over 1 AMU for a replacement alternator. 1 Quote Link to comment Share on other sites More sharing options...
BaldEagle Posted April 15, 2019 Author Report Share Posted April 15, 2019 10 minutes ago, kortopates said: An avionics shop would likely swap new parts in - if they'll do the job. One local avionics shop wouldn’t take 3 AMU from me for an Aspen Max upgrade. I know they’re all no doubt overwhelmed with the ADS-B mandate and 2020 coming up, but that was a bit surprising. And I’ll be lucky to see the upgrade this side of Christmas. Another shop did take my money, but they made it quite clear that they’re not hurting for business. Good for them. Aviation is a really weird industry. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted April 15, 2019 Report Share Posted April 15, 2019 With the cowls off, turn on the battery master and alternator field switches. Go the the front of the alternator, the pulley retaining nut should be a strong electromagnet. If it’s not measure field voltage at the field terminal, it should be very close to battery voltage. Look for broken, lose or damaged wires and terminal ends on the field power, field ground and output terminals. How many hours on the alternator? Brushes do wear with time, brush springs fail, brush leads fail, all of these are checked or replaced without alternator removal. Clarence Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted April 15, 2019 Report Share Posted April 15, 2019 13 hours ago, Yetti said: bad loose ground. Start at the battery. Make sure all connections are shiny bright. Check engine ground strap. I agree. The loss of those sensors makes it look like a grounding issue. The engine ground strap is a likely culprit since it was affecting engine sensors and the alternator. Quote Link to comment Share on other sites More sharing options...
BaldEagle Posted April 27, 2019 Author Report Share Posted April 27, 2019 I had some time today to do some troubleshooting before my A&P takes a look at it tomorrow. I noticed that the connections on one of the alternator posts was loose and dirty. So perhaps that's the issue. I cleaned them up with fine sand paper and contact cleaner, put them back on the post but the nut would just spin and wouldn't tighten, and then brains here managed to break the post. So now the alternator has to come off. So if it has to come off anyway what would you do? Send it off for repair / overhaul (in which case any recommended shops?), or just replace with a new one and be done with it. While I was having fun I was able to confirm that the ground strap is good. 2019-04-27_11-12-03_000.MOV Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 27, 2019 Report Share Posted April 27, 2019 what kind of alternator? If its the Kelly reman unit its a 1960s Ford alternator. That post can be easily repaired. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted April 27, 2019 Report Share Posted April 27, 2019 A new one costs about $500, so find out what an overhaul will cost. I replaced mine with new when I overhauled my engine because 1. It wasn’t an approved alternator 2. It was over 15 years oldTom Quote Link to comment Share on other sites More sharing options...
BaldEagle Posted April 27, 2019 Author Report Share Posted April 27, 2019 (edited) 1 hour ago, jetdriven said: what kind of alternator? If its the Kelly reman unit its a 1960s Ford alternator. That post can be easily repaired. Difficult to read the plate but I think it's a Kelly Aerospace 6520LS (12V). A new replacement (now Hartzell) runs at 0.8 AMU from Spruce. Edited April 27, 2019 by BaldEagle Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 27, 2019 Report Share Posted April 27, 2019 (edited) A local alternator shop can repair that post for 30$. Thats a fairly standard part. Edited April 27, 2019 by jetdriven 1 1 Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted April 28, 2019 Report Share Posted April 28, 2019 You’re not even sure the alternator is the problem yet.... Quote Link to comment Share on other sites More sharing options...
BaldEagle Posted May 5, 2019 Author Report Share Posted May 5, 2019 An update, in case it might help someone else in the future. I only just discovered that my EDM 700 also stores the voltage data, so I looked at the data for the last 7 months and the voltage output reduced from 13.3 to 12.8 over the time period and was occasionally dropping to 12.3 on the flight described above (at which point the Aspen would run off battery and low voltage light would flicker). Anyway, it seems that if alternator output is below 13.5 volts the alternator output is considered too low. Ideally I should have run a multimeter from the back of the alternator to be certain, but as the alternator is at least 15 years old I decided to replace it anyway so my A&P installed a new replacement this morning. Test flight was fine with the JPI showing between 13.8 and 14 volts, and Savvy Analysis showed the same so I’m calling this resolved. These engine data monitors are a godsend, I don’t know how we managed without them... 3 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 6, 2019 Report Share Posted May 6, 2019 Great reminder... JPIs record Voltage, that is feeding them... no additional hardware required... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
