super6
Just bought a junk m20c Ranger
:unsure:I bit off a rebuild project and will need some help.  I am not yet a pilot or a flyer. That said please be gentle.
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
What would make you want to do that?
Are you looking to undo what you have done?
We know a guy...
Welcome aboard.
You now have two projects...
1) Learn to fly...
2) Rebuild plane...
You have plenty of time... and resources...
Share this post
Link to post
Everyone should have their own “Everest” to climb, keep looking at the goal and put one foot in front of the other..
Share this post
Link to post
Lol. The mooney was built in 1968, The bank account is healthy,and this is a retirement hobby.I have ambitions. And I hope the thread is fun!
Edited by super6
left a responce off
Share this post
Link to post
Just some back ground on this air frame, Landed gear up belly skins and doors damaged prop and engine went south. I will need to buy an A1A  And prop The total expenditure so far is $6000 This is why I will need help.
Share this post
Link to post
What did you pay for the air frame? Did it include instruments?
Share this post
Link to post
$2995 and no Instruments. Other than basic. It will Need radios And ads b in out. new slate.
Edited by super6
Share this post
Link to post
Airframe carefully inspected for corrosion by a Mooney expert (particularly spar and steel frame) so far?   If not might be a good point to do this before going any further toward restoring vs. scrapping....
Share this post
Link to post
no inspections so far, I do not have  possession yet.I will  have an inspection done.
Share this post
Link to post
Sorry for all the questions, but will you need to move it somewhere, or work on it where it is now?
Share this post
Link to post
2 minutes ago, super6 said:
In case anyone is interested,The tail # is N69zz
Well, this opens up other questions, like, why was it decommissioned? Looks pretty good (highlight mine):
1968 M20C N69ZZ
Rare corrosion free M20C loaded with speed mods. Hangared at MOB. Logs read like well loved business Jet (AD-logs for 17 years) TTAF 4100, 0 SMOH/SPOH, fresh annual, good paint-white w/red and dove gray, good glass/tires, no hail, late 231 style custom high back cloth seats. KMA24 audio panel, dual Collins Nav 251/Com 351, Apollo Flybuddy Loran, King digital Digitak KT 76C TSO transponder, digital narco 890 DME, PC wingleveler autopilot, wired for yoke-mounted GPS, 201 windshield, cowl enclosure mode, 231 wing tips w/strobe enclosure, belly beacon, 231 wing and tail root fairings, 231 tail enclosure, flap and aileron gap seals, elevator hinge seals, new style shock disks, brake rotation conversion, 201 blade antennas, alt conversion, high capacity fuel bladder mod.
Share this post
Link to post
I will need to move it part of the $6000. I have a warehouse
Share this post
Link to post
HRM it seems simple minded on my part, But I did the home work on this plane
Share this post
Link to post
Thanks To everyone who replied. My first post here and help full so far!
Share this post
Link to post
Not really. This way you know every little detail of your Mooney. That is something other owners only get after years of owner (A&P) or owner-assisted annuals.
Share this post
Link to post
call if your close by
I would have someone who knows what corrosion to look for on a Mooney assess the plane. The listed owner shows the plane was last flown last July and has been based in Florida. If you have corrosion on the steel cage and/or wing spar, it’s repairable but will be a lot of work and cost. There are two Mooney owners on this site who have done wing replacements/major repairs. They can comment on the amount of work and cost. Same goes for the steel cage.
If the plane gets past that step, I would continue to build out a list of what you need to rebuild it. Sounds like you started already. I didn’t catch if you are an AP or IA, if not, since this is a certified airframe, you will need someone to sign off on any work you do. As owners, we are limited on what we can do. Someone willing to work with you that has the required credentials?
I would make friends with Alan Fox and Jerry Pressley. If you need components, they have or can get access to what you may need. There is no Costco or Walmart for unique parts on vintage Mooneys.
Once you have an idea what it will cost on paper, I would decide if the project is financially viable. If you are going to stick $60k in rebuilding of this aircraft, it might be better to find a plane in that price range.
And oh yeah, get your medical started. Maybe you won’t pass even Basic Med. Then what you going to do? Try to beat that guy who posted pictures here of himself flying his two kids around on a student pilots certificate?
I’d admire your passion. Hope you can pull it off. Unfortunately we have also seen owners get kneecapped by unexpected expenses. Good luck.
Share this post
Link to post
