Gary0747 Posted March 22, 2019 Report Share Posted March 22, 2019 (edited) Does anybody have any data or know what the Pressure difference between the inlet and outlet of the fuel servo on IO360? I am seeing about 6psi drop on different gauges. Edited March 22, 2019 by Gary0747 Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 23, 2019 Report Share Posted March 23, 2019 Sounds like a good tech question for @M20Doc.... dP for fuel across the fuel servo... IO360. ^^^^ Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted March 23, 2019 Report Share Posted March 23, 2019 That’s a good question and not a value I’ve ever checked. The factory pressure pick up is on the finger screen body, where are you doing the other pressure check? Have you cleaned the finger screen? Not that it should affect fuel pressure, the factory fitting in the finger screen body has a built in restrictor is it clean? Clarence Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted March 23, 2019 Author Report Share Posted March 23, 2019 I have an EI flow meter and pressure gauge between the engine mechanical pump and the servo and have just installed a JPI Pressure transducer at the location where the factory pressure gauge used to be. This is on the outlet side of the servo I assume. We will check the screen but have never found anything there since I assume the gascolator filter is doing a good job. The inlet pressure has been running close to 30psi and the outlet where the old factory gauge was shows 22 to 24 psi. I was reading the Precision Aeromotive manual for the servo and the only thing I could find about Pressure was a statement that “ In general inlet pressures 5 to 10 psi greater than engine requirements will not adversely affect the performance of the system”. Which makes me think the pressure drop I am seeing might be normal. The strange thing is I never noticed the difference on the old factory gauge but now do with the JPI. Quote Link to comment Share on other sites More sharing options...
EricJ Posted March 25, 2019 Report Share Posted March 25, 2019 On 3/22/2019 at 4:21 PM, Gary0747 said: Does anybody have any data or know what the Pressure difference between the inlet and outlet of the fuel servo on IO360? I am seeing about 6psi drop on different gauges. Do you mean from the fuel feed to the servo to the fuel feed to the divider? If so, I think that's going to change depending on all kinds of things like throttle and mixture position, speed, altitude, etc. I'd expect it to vary quite a bit. Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted March 25, 2019 Author Report Share Posted March 25, 2019 There are three ports on the servo. The inlet the outlet to the servo. And a tap from the body of the servo that goes to the fuel pressure gauge. I have gauges on both the inlet and the normal pressure tap.. Quote Link to comment Share on other sites More sharing options...
