elimansour Posted March 16, 2019 Report Share Posted March 16, 2019 Hi all - My plane is coming up on 1000 hrs since the last compliance with the no back clutch spring SB. Any recommendations of a maintenance facility in the Southwest that is expert in performing the SB? I have been told by several mechanics (and have read the threads on MS) that the SB should only be accomplished by someone who is expert in this. Thank you! Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 16, 2019 Report Share Posted March 16, 2019 For homework... Check in with Andrew’s photo gallery for an awesome picture collection of all things ‘no back clutch’ spring related. @Hyett6420... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted March 16, 2019 Report Share Posted March 16, 2019 I replaced mine at 1000+ hours a few years ago. My local mechanic removed the actuator and sent it to a Mooney service center for overhaul. My mechanic is a KPAO legend and very experienced (He has my total respect and trust) but he decided to let the Mooney experts at a nearby Mooney Service Center rebuild it. Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted March 16, 2019 Report Share Posted March 16, 2019 4 hours ago, Hyett6420 said: Rebuilding a complete actuator yes is a job for an expert. But to replace the back spring is SO easy its untrue, it is literally removing the actuator, taking the covering plate off, remove / replace back spring and put back together. It took about 2 hours to remove and replace spring and about another 4-6 to put it back in the plane. Andrew My actuator's brass clutch needed to be replaced too since it had some deformation and damage. Does that need more disassembly? Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted March 16, 2019 Report Share Posted March 16, 2019 No not at all, once ypu have removed the four holding bolts the whole thing comes apart easily. I vaguely remember there’s a special grease required?Tom Quote Link to comment Share on other sites More sharing options...
SheryLoewen Posted March 20, 2019 Report Share Posted March 20, 2019 LASAR has the expertise. Northern California 1 Quote Link to comment Share on other sites More sharing options...
