Weight and Balance - CG question (M20E)
Hi all... let me say that I've been reading a ton here and thank you all for the great information.  This is my first post, as I'm the new owner of an M20E.
I have a question about Center of Gravity, as I'm preparing for a cross-country flight in this new-to-me bird.  I entered all the W&B info into Garmin Pilot and was surprised to see that the CG is very far aft with me and my wife in the front (combined weight about 280) and 100 pounds in the back.  In digging into the last equipment list and W&B revision (after a prop change), I think I'm seeing an error in their calculation.  The prior CG/ARM was 46.84, which seems pretty standard for the Es.  After a 3-pound weight increase on the nose, with the new prop/hub, they indicate a new CG farther aft... of 48.78.  To me, that doesn't make sense. And, with this 48.78 CG, we're barely within the envelope.  I think it's actually supposed to be 46.78 but I'd love the hive eyes on this.
Once we're back at home base with this plane, I'll have it weighed to figure this out.  And, even with the 48+ CG, we're still within the envelope and I don't see a problem with our ferry plans.  Until we can get it weighed, though, does it indeed seem like this revision sheet calculation is erroneous?  Or am I missing something?
Thanks much!
Ross Taylor, Flagstaff AZ
26812
Link to comment
Share on other sites
I was looking at the W&B for a Bonanza I owned and noticed an error. Started checking and found about 10 errors.  Some were addition, subtraction and multiplication errors, a couple cases of adding a moment rather than subtracting. Guess it is easy to make those errors taking things out, putting others in.  Some of that stuff was done back in the day before cheap calculators.  In the end, you are the party responsible for your paperwork.
Link to comment
I would not weigh the plane. Recalculate the W&B sheet and I suppose you'll find the error that you suspect is in there. I would enter the weights and arms into an excel spreadsheet to minimize the chance of making my own errors. (an A&P should verify and sign your new W&B).
My ('66) M20E empty weight is 1680.7 and moment is 79833 for a CG of 47.5. But I have a several heavy mods including avionics in the tail cone with a high moment. I suppose a more typical E would have an empty CG forward of mine and your 46.84 is much more likely than the 48.78. Of course the 3 pounds added to the nose should have moved the CG forward, not back, so I'd start with that calculation if you have both W&B sheets.
Link to comment
^^^^^^^^^^^^^^^^ Do this exactly. ^^^^^^^^^^^^^^^^^
Bob knows what he's talking about.
Link to comment
Okay, thanks all!  Three takeaways here, for me...
First, my impression that adding 3-ish pounds to the nose couldn't move the CG aft is correct.  Yay, I'm not a *complete* idiot!  Haha!
Second, I'll scuttle my plans to have the plane weighed and will dig through the equipment history and recalculate the W&B from scratch.
Third, the correct ARM is under 47 and we're good to fly.  I was getting a little worried when I saw where we were landing in the envelope with the 48.78 value.
Okay, there's a fourth takeaway for me (which I'd already seen from my prior reading).  There are lots of folks here willing to help others - thank you for that!
Link to comment
Suspect the arms that an errant mechanic may use... some people may accidently use an incorrect reference...
Sice the Cg moved back, when weight was added forward of the reference plane... suspect all of the calculations performed by the errant mechanic...
The 0.0 arm is a bolt on the nose gear...? Not the firewall... or something really obvious.... (check this detail for accuracy)
Welcome aboard, Ross,
Link to comment
On 3/14/2019 at 3:45 PM, N201MKTurbo said:
You can always weight the plane for a sanity check. Nobody says you have to update your aircraft records.
I always find the airplane W&B discussons bizarre.  If you say I fly my plane over gross all the time people think you are reckless.  If you fly around with an incorrect W&B (which almost everyone does) you are smart.
Everyone should follow your advice.  If you are going to overload the plane do it so knowingly, not unknowingly.
Link to comment
If you have all the history of W&B revisions, do this: Open up excel or another spreadsheet, start from how the plane left the factory and work forward. Some pieces of equipment will go in, some will come out, and at the end you should have something very close to or matching the most recent W&B, and if not it can help you spot an error. It may consume some time but I think its worthwhile.
But as a gut-check, with 2 in the front and 100 lbs in back you will be fine
If you put 2 adults in the back seat it will start getting aft fast...
Link to comment
The cost...
To do it properly requires removing all kinds of dirt and extra wires from years gone by...
along with the proper weighing... emptying or filling tanks properly will be needed.
Not done with all the extra effort required, ends up with a lower UL than expected...
If done officially, the new lowered UL ends up in the log books to be figured out later...
Either way... it is better to have the real WnB Numbers to do the proper calculations...
PP thoughts only,
Link to comment
59 minutes ago, ArtVandelay said:
Do not use the fill the fuel tanks method, in my case if I did that it would cost me 18lbs of useful load, because my 64 gallon tanks actually hold 67 gallons.
Unless you know your actual tank capacity. When my tanks were stripped and resealed, it took 52.4 gallons to fill both to the caps (versus standard capacity of 52 gal).
Link to comment
+1 on the un-opened file...
Try to make the file share-able in one way or another...  better for somebody to see something...
Early Mooneys had critical WnB data on a loose piece of graph paper tucked in the logs...
You really want to know...
  • Any errors in the history of the WnB of the plane...
  • Any errors in the calculations the new pilot is making with the new 2 U plane....
Link to comment
When I reweighed my Mooney I gained 98 pounds of Useful load. The first factory W&B was in error!
One can use the TCDS for figuring out the correct arms for equipment by looking at other listed equipment and their arms.
The Mooney Datum is the center of the nose gear mount bolts.
Go ahead and refigure all your paper work (if you know you have it all) and see where you sit. But to really know what you have- reweigh. It ain't that hard or expensive.
Link to comment
Thanks all. I picked her up in Virginia on Tuesday and got back to Flagstaff yesterday evening, right at sunset. It was a really nice trip.
It looks like I have all the docs and the original W&B sheet was there, too. I'll do some math and see what I find. And at some point I'll get her weighed, out of curiosity. But I'm certainly not concerned. What a nice flying machine!
Link to comment
