Seat Latch Failure
DonMuncy
A while back, there was a thread in which several people expressed concern with the possibility of the pilot's seat unlatching and sliding back during take-off. I have come up with a device to prevent that risk. It fits over the right seat rail behind the seat, and prevents the seat from sliding back. The brass appendage is a spring/ball latch that snaps past the top of the rail to keep it from bouncing off. That may be overkill, but it seems to work. The notches are to clear the back cotter key stop. The funny step goes to the rear, and is necessary to clear a small hump at the back, and the carpet (at least on my plane). One downside is the necessity to tailor it to your particular  seat location. But it is easy to put the seat in position, reach back and press it onto the rail, and equally easy to reach back and remove it. Naturally, feel free to copy, modify or make suggestions for improvement. I could probably be induced to make you one, but would need the measurement from the rear seat bracket to the back "wall".
Link to comment
Share on other sites
Well. How about them apples! Very nice Mr Don.
Link to comment
12 hours ago, Hank said:
Looks well made. Great machining. Can you give us a picture of it in place?
I'm not smart enough to have thought of that at the time. I'll see if I can get one.
Link to comment
I'm a big dude, so seat latch failure worries me a lot.  Don't suppose you have the receipts for the pieces with part/item numbers so we can find them a bit more quickly in the aviation aisle at our local Home Depot?  Thanks for doing the work to design the thing and sharing!
Link to comment
Here are a couple of photos of the device, in place.
I don't think Home depot has the materials. I got mine at a high class hardware store in Dallas (Elliott's). The spring ball catch came from Rockler (Woodworking place). Unfortunately, I left it at the hangar. I will try to get back out there and get the dimensions of the aluminum channel. I will post them when I get the measurements.
Link to comment
What is the recommended technique to survive a seat latch failure on takeoff? Let go of the yoke??
I had this happen during my transition training at about 50’, I just relaxed my arms and hands, was able to keep my right hand on it because I could slip out of the shoulder belt. It was just a reflex.
A cheaper solution is to put your flight bag behind your seat. Just make sure nothing can get crushed.
Tom
Link to comment
4 hours ago, M20Doc said:
For those without Don’s skill set, or hanger fairies, this might work.  I believe that Cessna and Monney seat track profiles are the same.
https://www.aircraftspruce.ca/catalog/pspages/saftstop.php?clickkey=11451
Nice find.  It looks like the screw on this would chew up the (relatively soft, very expensive to replace) rail.  Don's solution looks much better, both in terms of performing the function (the SAF-T-STOP could move, you'd have to bend some beefy aluminum and probably shear the pin lock for your seat to budge with Don's) and in reduced wear and tear on the rail.  (I needed to have a pair replaced a couple annuals ago.  It hurt.)
Link to comment
I've taken to holding onto the center windshield bar with my right hand during takeoff. I move my right hand up there just prior to rotation and keep it there until either ready to switch to autopilot or leveling off a bit.
I know the traditional position is hand on the black, blue, and red knobs. But no one can give me a good reason to keep it there once I've rotated. So I've adjusted my technique to keep a right hand on a firm hold. So if the seat let go, I can pull on that instead of the yoke or the throttle.
Link to comment
I measured the material for the anti-seat latch failure device, in case it is of value to anyone. It is channel aluminum 1/16 inch thick, and 1/2 inch inside width. The step-up shim is 1/8 inch thick by 5/8 wide. The spring ball latch is 5/16 inch outside diameter. The over all length of mine is 16 1/2 inches, but of course, dependent on the usual seat position. I think I keep mine in the second hole from the front.
Link to comment
Thanks Paul, I missed that line.   PM sent with an "inducement".     (Wish I knew his favorite bribe.  Hopefully cash is one of them.)
Link to comment
Truth is, if a Chinese company geared up and built 1000 of them, they could probably turn them out for $2. You saw where Aircraft Spruce wants $70 for a pair of devices to do the same thing. (My belief is that one of them would provide plenty of security)  With the way I bought the material, I have about $12 in one. (Those spring ball latches are pretty expensive.) With the design work in it, I have no idea how much time I have in mine. If I were diligent, I could probably make one in an hour, plus the time for the JB Weld holding the ball latch in place to  set up. Knowing that I have no intention of trying to make a living making them, and I really don't want to even turn a profit, how much would you charge for them? It would have to be enough to deter too many people from wanting them. I don't want to wind up spending a month turning them out :) Additionally, anyone wanting one would have to measure from their usual seat position back to the front of the rear seat, or have me make it long and have the user use a hacksaw to cut to size. Remember, these are hand made, and you would have to live with the quality of my abilities.
Link to comment
1 minute ago, Seymour said:
Like, Mooney?   ;)
I'll be measuring my seat distance tomorrow morning.   Thanks Don!
Look at the pics I posted, showing mine in place, and make sure our planes are close enough to the same, that it will work. I think they should be, but we want to be sure.
Link to comment
I have the Saf-T-Stops on the 172 and they saved my ass on a return to service flight about 8 years ago, front seat legs were setting on the rail not in it, at rotation the seat tilted back on the rear seat legs, the stop did their job. It takes very little tightening and hasn't damaged the rail so far (1500+hrs)
Link to comment
Wow, but the guy that installed the seat sure didn’t do his job. Sounds like the Saf-T-Stop may have saved you but the seat installer almost killed you!  Glad your here to tell about it.
Link to comment
I could make some of these.  I think I would use spring loaded ball set screws with locking nuts threaded into an aluminum block screwed to the side of the long rail.
This would allow for tension adjustment for snapping the U channel onto the rail and would be mechanically solid.  May want to use 1/8" thick. U channel stock.    I could make them longer than necessary and then they can be fitted and cut with a small hack saw in the field.
John Breda
Link to comment
