larrynimmo Posted March 8, 2019 Report Share Posted March 8, 2019 (edited) when my right wing is near full of fuel, or if it gets cold outside I get a fuel odor in my cabin....while avionics crew is pulling wires I took pictures of my fuel pick-up fitting, and fuel level sender mount are both leaking. I was wondering if the screws could be tightened...are the nuts attached to a flange on the other side...am I going to have to take the tank apart and redo epoxy from the inside of the tank to get it to stop leaking? Picture need rotate 90picture is upside down Edited March 8, 2019 by larrynimmo tried to rotate Quote Link to comment Share on other sites More sharing options...
DVA Posted March 8, 2019 Report Share Posted March 8, 2019 It’s interesting that someone decided to smear Buna-N (the red film) on the inside. That’s not a sealer (it’s put on as a top coat over the sealer) but it’s also unlikely to be part of your current problem. You could try making sure the screws are tight but I doubt it will help much, with the caution that you might make it worse. Both the sender and the pickup seem to be leaking from what I can see, right? As the resting pressure of the fuel increases with fuller tanks, you get more weeping. The sealant becomes less pliable over time and temperatures affects it more, and the gaskets on both units degrade. This looks like an relative easy fix if you are only leaking past the gaskets. Both units can be manipulated through just the top aft fuel panel. Here’s a pic of what the inside looks like if you e never seen it. We do fuel tank reseals regularly, I see this often. DVA Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
buddy Posted March 8, 2019 Report Share Posted March 8, 2019 You should be able to just remove the screws and replace the gaskets. Give laser a call and they should have the gaskets in stock. Quote Link to comment Share on other sites More sharing options...
Oldguy Posted March 8, 2019 Report Share Posted March 8, 2019 I had the same "fragrance" in my '84 J and tightening the screws on the fuel pickup did the trick for me, although you look like both the pickup and sender need tightening on yours. I was worried I needed to replace the gasket, and then found out it is a $60 part! Once you get them all tightened, clean off the residue from the leaks and watch it for a few days. It should stay clean. If not, then it is time to get your local mechanic involved. Good luck! Quote Link to comment Share on other sites More sharing options...
Igor_U Posted March 8, 2019 Report Share Posted March 8, 2019 Gaskets (for fuel sender) were cheap when I replaced them. I believe I still have a spare one and are common to Piper aircraft... I would have to look for it in my hangar and get p/n. Quote Link to comment Share on other sites More sharing options...
Marauder Posted March 8, 2019 Report Share Posted March 8, 2019 when my right wing is near full of fuel, or if it gets cold outside I get a fuel odor in my cabin....while avionics crew is pulling wires I took pictures of my fuel pick-up fitting, and fuel level sender mount are both leaking. I was wondering if the screws could be tightened...are the nuts attached to a flange on the other side...am I going to have to take the tank apart and redo epoxy from the inside of the tank to get it to stop leaking?Picture need rotate 90picture is upside down You have a cork gasket sitting underneath. Tightening a little may stop the leak. Bladder system. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Bryan Posted March 8, 2019 Report Share Posted March 8, 2019 Those of you that have installed CiES senders, do they come with new gaskets? ordered the senders and want to be prepared for the install to have everything needed. Quote Link to comment Share on other sites More sharing options...
EricJ Posted March 8, 2019 Report Share Posted March 8, 2019 I had a similar issue and (carefully) tightening the screws solved the problem. I've since installed new senders, etc., so that was the bigger cure. 1 minute ago, Bryan said: Those of you that have installed CiES senders, do they come with new gaskets? ordered the senders and want to be prepared for the install to have everything needed. I believe new gaskets are included, or at least I didn't get charged for gaskets when mine was put in. Quote Link to comment Share on other sites More sharing options...
Marauder Posted March 8, 2019 Report Share Posted March 8, 2019 Those of you that have installed CiES senders, do they come with new gaskets? ordered the senders and want to be prepared for the install to have everything needed. Yes. Old and new senders next to each otherSent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Marauder Posted March 8, 2019 Report Share Posted March 8, 2019 I did install new screws and didn’t reuse the old ones. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted March 8, 2019 Report Share Posted March 8, 2019 I think there's a torque spec on those perimeter screws - Clarence will be along shortly to confirm - you want to squeeze that gasket tight enough and uniformly. Cork is probably more sensitive to proper installation. There's a rubber gasket alternative that's thicker an probably more forgiving and longer lasting. @M20Doc Quote Link to comment Share on other sites More sharing options...
Guest Posted March 9, 2019 Report Share Posted March 9, 2019 Here is your torque value. Some Acetone on a rag will clean up the old fuel dye. Clarence Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted March 9, 2019 Report Share Posted March 9, 2019 Thanks Clarence, that's what I was remembering. Turns out that the right way to screw 5 small screws is not trivial. It reinforces the old saw about how it's the things we know that ain't so that gets us in trouble. Quote Link to comment Share on other sites More sharing options...
EricJ Posted March 9, 2019 Report Share Posted March 9, 2019 It also says that retorquing to prevent leaking is okay. 1 Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 9, 2019 Author Report Share Posted March 9, 2019 It’s leaking pretty good from one of the screws for the fuel pixup...looking to see if I can fix with taking out tank access covers...just one screw leaking 1 Quote Link to comment Share on other sites More sharing options...
Oldguy Posted March 10, 2019 Report Share Posted March 10, 2019 21 hours ago, larrynimmo said: It’s leaking pretty good from one of the screws for the fuel pixup...looking to see if I can fix with taking out tank access covers...just one screw leaking It's always the one under the pickup tube because it is a bear to get tightened and torqued properly. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2019 Report Share Posted March 10, 2019 (edited) On 3/9/2019 at 2:39 PM, larrynimmo said: It’s leaking pretty good from one of the screws for the fuel pixup...looking to see if I can fix with taking out tank access covers...just one screw leaking Remove the screw and replace it with an AN3 bolt, much easier to torque with a crows foot wrench. Transfer the washer to the bolt. Clarence Edited March 10, 2019 by M20Doc Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 11, 2019 Report Share Posted March 11, 2019 I re did one of my senders three times and it still leaked, so I put a light coating of tank sealant on the sender, the airframe and both sides of the gasket. It didn't leak a single molecule of fuel after that. I had to remove it about a year later and was thinking it would be a horror story getting it apart, but it wasn't that hard and cleaning it up for a reseal was no big deal. I know it isn't by the book, but it works. BTW, it wouldn't reseal because too many ham fisted mechanics were in there before I bought the plane! 1 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted March 11, 2019 Report Share Posted March 11, 2019 36 minutes ago, N201MKTurbo said: I re did one of my senders three times and it still leaked, so I put a light coating of tank sealant on the sender, the airframe and both sides of the gasket. It didn't leak a single molecule of fuel after that. I had to remove it about a year later and was thinking it would be a horror story getting it apart, but it wasn't that hard and cleaning it up for a reseal was no big deal. I know it isn't by the book, but it works. BTW, it wouldn't reseal because too many ham fisted mechanics were in there before I bought the plane! Good job! Who would have figured? Fuel sealant actually seals fuel. 1 Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 23, 2019 Author Report Share Posted March 23, 2019 Completion Report.... I completely removed the bottom fuel pick-up tube cleaned up the whole area with acetone and it cleaned up nicely.., installed a new $62 mooney gasket, put non hardening Permatex on the threads, and that was fixed. As for the fuel gauge I couldn't get it to pop loose (must be glued in place) removed old screw, installed new screws with the nylon crush bushing barrels, new screws and a light coating of non hardening Permatex and torqued everything. I only went to 15 inch pounds because it felt pretty tight at that. I also, took the opportunity to replace the 40 year old fuel hose, and installed a new quick drain for the tank. FYI if you order a fuel sender gasket from Mooney they are now sending a rubber one rather than the cork ones...it cost $28, but I ended up not using it. The plastic barrel bushings only cost $.50 each. Put 25 gallons in the tank...and no leak what-so-ever. YEAH! My A&P mechanic told me that you don't need sealant on the screws (even though we did it) because when you use a new gasket the crushing force of the compression is supposed to seal the screw threads so that nothing can pass through. 4 Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 23, 2019 Report Share Posted March 23, 2019 Great detailed follow-up and pics, Larry! Nice Fuel hose too... the old 60s original ones get really cracky... brittle. Your old ones were probably pretty ripe... even if they looked nice from the outside... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Rwsavory Posted March 23, 2019 Report Share Posted March 23, 2019 1 hour ago, larrynimmo said: Completion Report.... I completely removed the bottom fuel pick-up tube cleaned up the whole area with acetone and it cleaned up nicely.., installed a new $62 mooney gasket, put non hardening Permatex on the threads, and that was fixed. As for the fuel gauge I couldn't get it to pop loose (must be glued in place) removed old screw, installed new screws with the nylon crush bushing barrels, new screws and a light coating of non hardening Permatex and torqued everything. I only went to 15 inch pounds because it felt pretty tight at that. I also, took the opportunity to replace the 40 year old fuel hose, and installed a new quick drain for the tank. FYI if you order a fuel sender gasket from Mooney they are now sending a rubber one rather than the cork ones...it cost $28, but I ended up not using it. The plastic barrel bushings only cost $.50 each. Put 25 gallons in the tank...and no leak what-so-ever. YEAH! My A&P mechanic told me that you don't need sealant on the screws (even though we did it) because when you use a new gasket the crushing force of the compression is supposed to seal the screw threads so that nothing can pass through. Thanks for your report. This will help a lot of folks in the future. Versachem Prime Seal Type 3 Aviation also does the trick on these leaky screws. We replaced a sender gasket last year, and I had to use this to stop seepage. Re-torqueing alone was not sufficient. Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 25, 2019 Author Report Share Posted March 25, 2019 On 3/8/2019 at 8:07 PM, M20Doc said: Here is your torque value. Some Acetone on a rag will clean up the old fuel dye. Clarence I don’t trust this instruction....first off senders only have 5 holes. When I tightened mine, I felt very uncomfortable torquing to 15 inch pounds....and I do believe I made the right decision not to go further....The screws for this are a 6/32...look at the torching guide in the mooney service manual. Size 6 isn’t listed, but use size 8 as a guide Quote Link to comment Share on other sites More sharing options...
Guest Posted March 25, 2019 Report Share Posted March 25, 2019 (edited) I’ve never seen a fuel quantity transmitter held on with 6-32 screws. They have always been 10-32 screws or bolts. Clarence Edited March 25, 2019 by M20Doc Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 25, 2019 Author Report Share Posted March 25, 2019 Trust me 6/32 Quote Link to comment Share on other sites More sharing options...
