marky_24 Posted March 7, 2019 Report Share Posted March 7, 2019 The trim servo in my 78 J needs to be rebuilt again, just had it done and it lasted about 5 hours before it started slipping again.... My question is can I fly the plane without the servo installed? Placard the electric trim inop, and fly with the trim wheel? It took 4 weeks last time, and I have a flight review coming up soon Quote Link to comment Share on other sites More sharing options...
smccray Posted March 7, 2019 Report Share Posted March 7, 2019 What part number? I have a KS 272A p/n 065-0061-13 that I need to sell. Out of a 28 volt airplane so I suspect it won't work but... Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted March 7, 2019 Report Share Posted March 7, 2019 36 minutes ago, marky_24 said: The trim servo in my 78 J needs to be rebuilt again, just had it done and it lasted about 5 hours before it started slipping again.... My question is can I fly the plane without the servo installed? Placard the electric trim inop, and fly with the trim wheel? It took 4 weeks last time, and I have a flight review coming up soon Talk to @Bob Weber He specializes in consulting with people on these older autopilots. Quote Link to comment Share on other sites More sharing options...
PT20J Posted March 7, 2019 Report Share Posted March 7, 2019 Have you checked the trim manually? It’s common for the Mooney trim system to get stiff. Also, check the carrier bearing where the trim servo attaches to the trim torque tube. It’s supposed to be lubed every year, but is frequently overlooked. If the servo really has gone bad again, it should be under warranty from the rebuild. To make the plane flyable without the servo you’d need to remove the chain from the torque tube and have A&P do appropriate paperwork. Skip Quote Link to comment Share on other sites More sharing options...
N231BN Posted March 7, 2019 Report Share Posted March 7, 2019 Have you checked the trim manually? It’s common for the Mooney trim system to get stiff. Also, check the carrier bearing where the trim servo attaches to the trim torque tube. It’s supposed to be lubed every year, but is frequently overlooked. If the servo really has gone bad again, it should be under warranty from the rebuild. To make the plane flyable without the servo you’d need to remove the chain from the torque tube and have A&P do appropriate paperwork. Skip Good points here, the bearing on my 231 hadn't been lubed in quite a while when I got it. That made a huge difference in how the electric trim worked. Quote Link to comment Share on other sites More sharing options...
Oldguy Posted March 7, 2019 Report Share Posted March 7, 2019 Might also suggest to check the age and cleanliness of the grease on the jackscrew. I seem to recall a recent thread about cleaning it and the difference it made. 1 Quote Link to comment Share on other sites More sharing options...
marky_24 Posted March 8, 2019 Author Report Share Posted March 8, 2019 Thanks for all the ideas, I'll take a look at the Jack screw. Quote Link to comment Share on other sites More sharing options...
