elimansour Posted February 13, 2019 Report Share Posted February 13, 2019 Hi All. I am trying to locate the correct fire extinguisher to mount in my '98 Mooney Allegro. It has a notch under the back seats with a metal bracket but I am not sure which extinguisher to purchase. Is there a specific model that needs to be purchased or should I just measure and go with in that direction. Sorry for the mundane question. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted February 14, 2019 Report Share Posted February 14, 2019 It doesn't look like the ones mentioned in the parts book from the 90's are available anymore. It looks like the 352T became the C352TS. Here's the new one (you might need a new bracket?) If your is already the 352T, you won't need the bracket: https://search.skygeek.com/?vwcatalog=stylespilotshop&keywords=H3R+Aviation+Model+C352TS&x=0&y=0#jmui=f%3A213%3A305419896%3AbDyGVKuX%bpkIP5u*X5gX18. With my discount at Aircraft Spruce I can get it shipped to you for $241.53 This explains the difference between the 1200 and the c352TS: https://www.h3raviation.com/downloads/rta1200-vs-c352ts.pdf 3 Quote Link to comment Share on other sites More sharing options...
elimansour Posted February 14, 2019 Author Report Share Posted February 14, 2019 Thank you! I really appreciate the information. Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 14, 2019 Report Share Posted February 14, 2019 @elimansour Eliman, feel free to push the thank you button or like on Lance’s post... Lance is an incredible resource of information about buying proper stuff for Mooneys... It will help others... Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
elimansour Posted February 14, 2019 Author Report Share Posted February 14, 2019 Absolutely! That was great info. I love this site and hope that I can contribute although I am still learning Mooney... 1 Quote Link to comment Share on other sites More sharing options...
320KPH Posted February 16, 2019 Report Share Posted February 16, 2019 I thought of a Stephen Coonts book that mentioned the effects of Halon on humans and I found an interesting site regarding this issue. https://www.skybrary.aero/index.php/Halon_Fire_Extinguishers Where a portable Halon extinguisher is used by cabin crew, it is usually recommended to consider donning a smoke hood before discharging it so as to eliminate this risk, but for pilot use on the flight deck, this will not be an option and risk awareness is the only defence. The fumes are toxic if inhaled and all practicable precautions should be taken when they are used. 1 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted February 16, 2019 Report Share Posted February 16, 2019 16 hours ago, 320KPH said: I thought of a Stephen Coonts book that mentioned the effects of Halon on humans and I found an interesting site regarding this issue. https://www.skybrary.aero/index.php/Halon_Fire_Extinguishers Where a portable Halon extinguisher is used by cabin crew, it is usually recommended to consider donning a smoke hood before discharging it so as to eliminate this risk, but for pilot use on the flight deck, this will not be an option and risk awareness is the only defence. The fumes are toxic if inhaled and all practicable precautions should be taken when they are used. https://www.aircraftspruce.com/catalog/pspages/provitasmokehood.php?clickkey=29040 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted February 16, 2019 Report Share Posted February 16, 2019 Do they use Halon anymore, thought it was replaced by a more user friendly substitute:Tom Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 16, 2019 Report Share Posted February 16, 2019 A more EPA friendly substitute... expect ozone depletion to be the issue...? -a- Quote Link to comment Share on other sites More sharing options...
