vorlon1 Posted February 12, 2019 Report Share Posted February 12, 2019 Can someone help me identify what the missing piece is called, or better yet: where do I order one to 'fill in'? Thanks! Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted February 12, 2019 Report Share Posted February 12, 2019 It appears to be just a "filler" to cover the notch in a panel cut out. A VSI does not have a adjustment knob that an altimeter has. I suppose an avionics shop would have a box full of such parts left over from upgrades. Quote Link to comment Share on other sites More sharing options...
vorlon1 Posted February 12, 2019 Author Report Share Posted February 12, 2019 6 minutes ago, Bob_Belville said: It appears to be just a "filler" to cover the notch in a panel cut out. A VSI does not have a adjustment knob that an altimeter has. I suppose an avionics shop would have a box full of such parts left over from upgrades. Yeah, I asked. My shop; not so much, and I am missing three... :-/ Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted February 12, 2019 Report Share Posted February 12, 2019 1 minute ago, vorlon1 said: Yeah, I asked. My shop; not so much, and I am missing three... :-/ Wouldn't be very difficult to make them but I bet someone here will come up with a source after dinner. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 12, 2019 Report Share Posted February 12, 2019 This is why I have lots of stuff laying around. To spend lots of time fabricating a 50 cent part. Maybe go for the black lexan. Or cut up a black computer keyboard and get to sanding. And I would feel validated on purchasing a nice sanding station. 2 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted February 12, 2019 Report Share Posted February 12, 2019 This is why I have lots of stuff laying around. To spend lots of time fabricating a 50 cent part. Maybe go for the black lexan. Or cut up a black computer keyboard and get to sanding. And I would feel validated on purchasing a nice sanding station. Actually in this case you should join EAA and get the free Solidworks download, draw up a filler piece with a hole, then buy a 3D printer and make the $0.50 part that way.Sent from my LG-US996 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 12, 2019 Report Share Posted February 12, 2019 There is nothing missing, the notch is made for the adjustment portion of altimeters and VSI’s. You could cut and file a small filler and secure it with an instrument screw. Clarence Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 12, 2019 Report Share Posted February 12, 2019 16 minutes ago, KSMooniac said: Actually in this case you should join EAA and get the free Solidworks download, draw up a filler piece with a hole, then buy a 3D printer and make the $0.50 part that way. Sent from my LG-US996 using Tapatalk It's a very nice Delta sanding station. Got to keep the fabricating skilz up 1 Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted February 13, 2019 Report Share Posted February 13, 2019 1 hour ago, Yetti said: This is why I have lots of stuff laying around. To spend lots of time fabricating a 50 cent part. Maybe go for the black lexan. Or cut up a black computer keyboard and get to sanding. And I would feel validated on purchasing a nice sanding station. My kind of thinking. Quote Link to comment Share on other sites More sharing options...
vorlon1 Posted February 13, 2019 Author Report Share Posted February 13, 2019 1 hour ago, KSMooniac said: Actually in this case you should join EAA and get the free Solidworks download, draw up a filler piece with a hole, then buy a 3D printer and make the $0.50 part that way. Sent from my LG-US996 using Tapatalk You're 'killin me! lol Quote Link to comment Share on other sites More sharing options...
gacoon Posted February 13, 2019 Report Share Posted February 13, 2019 Deleted Quote Link to comment Share on other sites More sharing options...
vorlon1 Posted February 14, 2019 Author Report Share Posted February 14, 2019 Still no ideas? OK, where did this come from? This is what I am looking for. The panel was rebuilt about 15 years ago. Quote Link to comment Share on other sites More sharing options...
Igor_U Posted February 14, 2019 Report Share Posted February 14, 2019 You are making this more complicated than it is. I don't think you can order the part and the cutout is a standard cutout for altimeter instrument that, for some reason is done on other location (VSI). If I were you, I'd take a piece of paper and trace the contour of the cutout, then transfer that to Al sheet of a same thickness as you panel. Cut it, trim or file to that size, drill an appropriate hole for the screw and paint it black to match you panel. Good luck. Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 14, 2019 Report Share Posted February 14, 2019 19 minutes ago, Igor_U said: You are making this more complicated than it is. I don't think you can order the part and the cutout is a standard cutout for altimeter instrument that, for some reason is done on other location (VSI). If I were you, I'd take a piece of paper and trace the contour of the cutout, then transfer that to Al sheet of a same thickness as you panel. Cut it, trim or file to that size, drill an appropriate hole for the screw and paint it black to match you panel. Good luck. I think you are making it more complicated with all that fancy planning and transfer.... cut out. sand it close walk to plane. see if fits. trim it up and bevel the edges Quote Link to comment Share on other sites More sharing options...
PT20J Posted February 14, 2019 Report Share Posted February 14, 2019 Altimeters have a setting knob, VSIs have a zeroing adjustment screw. Quote Link to comment Share on other sites More sharing options...
