Airways Posted January 15, 2019 Report Share Posted January 15, 2019 How would you describe the part that is in the yellow circle ? It needs replacing and I wonder if I can search for it on the used parts market. I know it houses an airfilter but I wonder how the metallic housing is called. Acft is a 252. Quote Link to comment Share on other sites More sharing options...
Bryan Posted January 15, 2019 Report Share Posted January 15, 2019 28 (PartNumber: 600417-501) Filter Assembly 29 (PartNumber: 605243-501) .Cowl Assembly, Lower 30 (PartNumber: 600406-501) .Filter Can Assembly (see 71-60-00) Quote Link to comment Share on other sites More sharing options...
Bryan Posted January 15, 2019 Report Share Posted January 15, 2019 And 71-60-01 looks like this: Quote Link to comment Share on other sites More sharing options...
Airways Posted January 15, 2019 Author Report Share Posted January 15, 2019 Thanks ! All the info I need ! Looks expensive Quote Link to comment Share on other sites More sharing options...
Oldguy Posted January 15, 2019 Report Share Posted January 15, 2019 43 minutes ago, Airways said: Looks expensive It's on an airplane, so that goes without saying. 3 Quote Link to comment Share on other sites More sharing options...
Bryan Posted January 15, 2019 Report Share Posted January 15, 2019 Whatever I think the part/service should cost, I find that if add a zero to that figure (before the decimal) it usually is close -b 1 1 Quote Link to comment Share on other sites More sharing options...
jackn Posted January 15, 2019 Report Share Posted January 15, 2019 Air filter housing. If the rubber boot is ripped, that can be purchased & replAced. Quote Link to comment Share on other sites More sharing options...
Airways Posted January 15, 2019 Author Report Share Posted January 15, 2019 It is the connection between the plumbing and the housing inlet that is cracking into little fragments. Has been repaired (welded) before but we think a second repair isn't possible/adviseable anymore. Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 15, 2019 Report Share Posted January 15, 2019 What kind of material is it? Metal or rubber? Rubber has a tendency to age poorly in under cowl conditions... So if it is tearing or falling apart, the rest of the part isn’t far behind... If it is rubbing on something, or being heated by nearby exhaust parts, then a repair and remedy can be found... Rubber enemies... heat abrasion UV light Oxygen/ozone Getting squeezed, cold flow... If it is a Mooney specific part, your MSC should be able to get it... Lasar.com.... If it is a typical hose, there may be standards that can be used.... We have a supplier of hose and seals around here for that type of work... PP thoughts only, not a mechanic . Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Airways Posted January 15, 2019 Author Report Share Posted January 15, 2019 It’s metal. Most of the chips were found in the air filter, but one went through the compressor. Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted January 15, 2019 Report Share Posted January 15, 2019 do-hickey. 1 Quote Link to comment Share on other sites More sharing options...
Airways Posted January 15, 2019 Author Report Share Posted January 15, 2019 (edited) I found it on the Lasar website. Thank you for those references, @Bryan Edited January 15, 2019 by Airways Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 15, 2019 Report Share Posted January 15, 2019 Airways, If you can... See if you can post a few good pics of what broke up... That will probably be helpful to a few people/252ers. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
larryb Posted January 15, 2019 Report Share Posted January 15, 2019 The air filter assembly in my 252 Encore rubs against the lower cowl. I asked my MSC about this and they said it is very common, and not much can be done. There is just not enough clearance. On other aircraft they have cut off a piece and welded a patch. Mine is not that bad. I have been maintaining it with anti-chafe tape. A piece on the fair filter box and a piece on the lower cowl. I replace them at each oil change. I also replaced the snubbers on the lower front engine mount that keep the cowl from riding up. That gives more clearance between the air filter and lower cowl. In the 18 months that I have owned my Encore, I have found 3 recurring trouble spots. One is the front exhaust cross over heat shield, which is prone to cracking. The next is the inter-cooler mount which is prone to cracking. And the third is this, the air filter rubbing against the lower cowl. Larry Quote Link to comment Share on other sites More sharing options...
jackn Posted January 16, 2019 Report Share Posted January 16, 2019 FWIW, on mine, if you rotate the air filter counter clockwise before tightening the hose clamp to the turbo, it won’t rub. The rubber boot will still fit nicely to the NACA inlet. Quote Link to comment Share on other sites More sharing options...
0TreeLemur Posted January 16, 2019 Report Share Posted January 16, 2019 9 hours ago, Airways said: How would you describe the part that is in the yellow circle ? It needs replacing and I wonder if I can search for it on the used parts market. I know it houses an airfilter but I wonder how the metallic housing is called. Acft is a 252. I'm glad you asked. That is a Turbo Encabulator. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwjv1L-HkfHfAhXwRt8KHbC7BwYQwqsBMAB6BAgDEAQ&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DAc7G7xOG2Ag&usg=AOvVaw2fgJikev-sbCrgwuvTTX_N 1 1 Quote Link to comment Share on other sites More sharing options...
Bryan Posted January 16, 2019 Report Share Posted January 16, 2019 1 hour ago, larryb said: The air filter assembly in my 252 Encore rubs against the lower cowl. I asked my MSC about this and they said it is very common, and not much can be done. There is just not enough clearance. On other aircraft they have cut off a piece and welded a patch. Mine is not that bad. I have been maintaining it with anti-chafe tape. A piece on the fair filter box and a piece on the lower cowl. I replace them at each oil change. I also replaced the snubbers on the lower front engine mount that keep the cowl from riding up. That gives more clearance between the air filter and lower cowl. In the 18 months that I have owned my Encore, I have found 3 recurring trouble spots. One is the front exhaust cross over heat shield, which is prone to cracking. The next is the inter-cooler mount which is prone to cracking. And the third is this, the air filter rubbing against the lower cowl. Larry I have two of those issues on my Encore: -air filter box rubbing (not bad, but I like the anti-chaffe tape) -cross exhaust heat shield breaking. I am just 12 months into this Encore but owned another 232 before this one. Quote Link to comment Share on other sites More sharing options...
wpbarnar Posted January 16, 2019 Report Share Posted January 16, 2019 @larrybIn the 18 months that I have owned my Encore, I have found 3 recurring trouble spots. One is the front exhaust cross over heat shield, which is prone to cracking. The next is the inter-cooler mount which is prone to cracking. And the third is this, the air filter rubbing against the lower cowl. I have experienced the same issue on the crossover tube a couple of times. My solution so far: Start with new brackets or standoff’s. Not repaired, welded, or high life cycled pieces. Use a die grinder or Dremial tool and relieve all the edges on the standoff that is riveted to the shield. The manner in which it is stamped and bent creates numerous sharp edges and stress risers. Grinding or rounding the edges helps relieve the stress and their potential to crack. Follow the service manual guidance on the two clamps that secure the shield. One needs to be tightened more than the other. Lastly, I scrutinize this area everyoil change. Bill Quote Link to comment Share on other sites More sharing options...
Airways Posted January 16, 2019 Author Report Share Posted January 16, 2019 11 hours ago, carusoam said: Airways, If you can... See if you can post a few good pics of what broke up... That will probably be helpful to a few people/252ers. Best regards, -a- I’ll make some pictures the next time I visit the shop. Should happen as soon as the spare parts are in. 1 Quote Link to comment Share on other sites More sharing options...
Airways Posted February 5, 2019 Author Report Share Posted February 5, 2019 On 1/16/2019 at 12:26 AM, carusoam said: Airways, If you can... See if you can post a few good pics of what broke up... That will probably be helpful to a few people/252ers. Best regards, -a- There you go. You can see that the filter has been repaired in the past. These spare parts are getting rare ! Thank you Lasar 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 5, 2019 Report Share Posted February 5, 2019 Great pics, Airways! Looks like that piece is feeling the strain... Look to see if there is supposed to be supports for the big aluminum housing and the hose that connects on that end... the pic shows that there may be a better way to hold the connection together. Mostly because there wasn’t 200 other people saying this happened to me too.... It is a tough vibrating environment where that part lives. Your mechanic may find a better way to keep stress from being applied to that connection.... The slots that initially ended with a round hole, seem to not have held back cracks and their propagation... looks like a tear ran all the way to the weld and continued on from there... Thanks for sharing the pics! They really tell a story of what is happening and give a hint to what to look for for other owners... any cracks emanating beyond the round hole will want to propagate until stopped... PP thoughts only, not a mechanic. Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
