Spike Kavalench
Oil cooler spacer bushings?
My mechanic wants to install longer bolts to pass through both sides of the oil cooler, using 3 3/8 x 5/16” od .058 wall thickness bushings, in order to spread the load of the cooler and prevent cracking of the one tab that was originally attached to the cowl using 6 short bolts.
Is this a good idea and if so, where can I source those long bushings?
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
Mine has the spacers.  I think they are standard AN hardware.  They are a PITA to install.
Share this post
Link to post
Most installations use the long bolts.  For bushings buy aluminum tubing from Spruce.
Share this post
Link to post
