Larry from NJ Posted January 11, 2019 Report Share Posted January 11, 2019 I have a Socata Trinidad with a good panel that includes a Century 31 autopilot. However, the altitude hold is a problem (roll is no problem). I noticed an entire string on folks who have a similar problem. Can someone call me? (973) 525-9400. Thanks. Larry Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 11, 2019 Report Share Posted January 11, 2019 Welcome aboard, Larry. you might type in what you want in a phone call... somebody might have an answer, but that someone might not be able to call you... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Larry from NJ Posted January 13, 2019 Author Report Share Posted January 13, 2019 I have had the computer checked out; the attitude indicator checked out and the servo checked out. All OK. I don't know where to go. Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted January 13, 2019 Report Share Posted January 13, 2019 Altitude hold is derived from a barometric sensor coupled to the static system. If your Century 31 operates correctly in pitch mode but won’t engage or hold altitude mode check the static connection and static system. Have a look at the maintenance section of the Operating Manual for suggestions: Century 31 Operation Manual 1 Quote Link to comment Share on other sites More sharing options...
