NicoN Posted January 10, 2019 Report Share Posted January 10, 2019 A few days before we had the Problem with the master sw no more working. At tthe same session my companion removed the portection cover from the High-Boost pump Switch - I do not know why and als re-assembled it. Now, something is a Little bit different. Before, I remember I had two "Actions" possible for the Switch. 1. Rotate the cover by 90° and you can Switch ON the HIGH BOOST permanently. 2. With the protection cover flipped back, I can press the Switch slightly, the pumps runs for a Moment an the protection cover works like a spring to push the Switch back to off. Now, the cover seems to be a Little more away from the rocker. It works, but there is something different. Is there a Picture around, how the cover, the spring and the "washer" Need to be assembled correctly? Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 10, 2019 Report Share Posted January 10, 2019 The cover is an option for the CB/switch... Klixon Switches are part of the Sensata group of companies... https://www.sensata.com/sites/default/files/a/sensata-20tc series-single phase rocker type actuator-datasheet_0.pdf Unfortunately, I am unable to find the lift-up switch cover that goes over the switch... Often the name of that cover is called a ‘switch guard’... Unfortunately, my google skills are alive this morning... Hope this link gets you step closer... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
jackn Posted January 10, 2019 Report Share Posted January 10, 2019 Hope this helps Quote Link to comment Share on other sites More sharing options...
NicoN Posted January 10, 2019 Author Report Share Posted January 10, 2019 Okay, I will compare it with our "setting" this weekend Quote Link to comment Share on other sites More sharing options...
