Mark89114
Failed AI indicator......and repair nonsense
My backup AI decided to give up the ghost after only being repaired/overhauled 10/17.  I called the repair shop and they tried to tell me it was because I wasn't running enough vacuum, i.e. idle RPM, this low suction causes something called "washboarding" and then said this was an indication of vacuum pump failure.  Well I want to call BS, as my KI-256 is still working.  I want to claim BS as I have been flying for 30 years and no a little something and I mean very little.  I have never heard of a dry vacuum pump failing slowly, guess it is possible, but every one I have had just fails and it is recently new, maybe 300 hours.  He wanted to blame carbon dust was getting in there, well I have an inline filter between the vacuum pump and the instruments, so I know that likely isn't the issue.  I also replaced the "oily hose" from the standby pump to the main system so I don't think that should be the issue either.  The upside down is with system running and the spinning video is after shutdown, which I have never seen.  I guess the summary is I don't trust these guys work and will send somewhere else.  Any other shop recommendations?        Thanks, Mark
Edited by Mark89114
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
If it’s an RC Allen they’re not good gyros.
Share this post
Link to post
I have a low time sigmatec (200 hours to)I removed from my M you could have cheap...probably less than overhauling yours..pm if interested
Share this post
Link to post
Probably because your picture went inverted.
Share this post
Link to post
The AI took down the whole panel!   :)
Wait....
the still pic doesn’t do it justice... the video is more of a must see...
This is the back-up AI gone amiss?
Share this post
Link to post
I have decided that all aviation anomalies can be explained with the phrase "Because I was inverted"
Share this post
Link to post
You guys used to always be so helpful...….(sarcasm font)
Sorry for the sideways picture......I only recently learned how to rotate a picture on wastebook…...if it doesn't do it for me automatically.
Share this post
Link to post
Hey Mark,
Does your O have a vacuum gauge?
or just the lights on the enunciator panel?
Somebody added a simple vac gauge early in my O’s life...
Other people probably wire a signal to the JPI...
With two independent vac pumps, it’s probably not a low vac issue... unless the regulator has gone TU...
Then again, the primary AI is running on vac... ‘air’ is probably printed on the face of the instrument...
As for gyro OH there are a few favored shops around here... One well known resource is a BK specific guy...
I’m not familiar with the others...
As for straightening up the pics... it has gotten much easier lately, but not part of MS yet...
Share this post
Link to post
I just had that happen too. Paid an excessive amount to get the gyro overhauled. Within minutes it went crazy and eventually started spinning just like yours only faster. I verified the vacuum with my golden WWII Bendix Pioneer vacuum gauge and my vacuum was right on. The instrument shop checked my 80 year old gauge against their mercury column and it was dead nuts on.
I took it back and they rebalanced ithe gyro and now it works perfect. They never admitted there was anything wrong, but....
Share this post
Link to post
The repair shops story was almost identical to yours.....couldn't have been anything we did.....
Pulled it out and sent it back to them.....will see if they provide warranty coverage.
Share this post
Link to post
Not sure I understand how a filter between the instrument and the vacuum pump helps the instrument... maybe the filter is on the suction side of the AI?
Share this post
Link to post
In the vacuum hose between the AI and the vacuum pump. When you shut the engine down the instrument cases contain vacuum and the pump has none and the carbon dust migrates up into the gyros into the grease thats in the bearings and then causes failure
Share this post
Link to post
The filter is there in case of a pump failure. The cowling is pressurized and can push air(and dust) through the pump and into the instrument after the vanes break.
The situation you describe is impossible. Draw out a complete vacuum system on a napkin and think it over some more. ;)
Share this post
Link to post
These are ridiculous times. Aviation is so conditioned to insane prices...Ai prices are a good indicator.
I applaud the feds making it easier for solid state to make the way into the cockpit. With items like the AV20 and dynon product in lieu of paying 1500 for just an overhaul on a non primary gyro, things get better. Garmin has exploited technology like the G430 for so long and kept prices at such a ridiculously high price I just can’t justify spending money on the brand.
Perhaps if you only sold a few hundred items the high cost would be justified. With Garmin pushing for adsb to be the standard, and subsequently monopolizing the market and suing others, I like to see competitors step up.
Good luck on your AI!
Share this post
Link to post
Perhaps you can explain why my gyros has carbon dust in the bearings even though the pump is older than the Gyro and has not failed?
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
