Dreamlifter Posted January 2, 2019 Report Share Posted January 2, 2019 AD 77-17-04: (a) Remove the RH and LH control wheels and inspect the aft two inches of the control wheel shaft for cracks (particularly at the attachment holes for the wheel). Use visual and dye penetrant inspection methods. My eagle eyed A&P notified me that I was about 40HRS from this inspection. Has anyone had this done and could you pass on what their shop charged? Thanks in advance for any help. Steve Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 2, 2019 Report Share Posted January 2, 2019 I purchased this from Aircraft Spruce Magnaflux Kit and gave it to my IA, he didn't charge me for the inspection or sign off. I removed my yokes, he did the inspection, I sent the yokes out to be wrapped in leather and we put them back on, total time was maybe 3hrs start to finish. Not exactly an answer but should give you an idea of the labor time Quote Link to comment Share on other sites More sharing options...
Dreamlifter Posted January 2, 2019 Author Report Share Posted January 2, 2019 Thanks RLC, good idea to provide the Magnaflux Kit. Maybe Don Maxwell can comment. Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted January 2, 2019 Report Share Posted January 2, 2019 Same here, wasn't charge by my IA as part of owner annual. -Robert Quote Link to comment Share on other sites More sharing options...
Dreamlifter Posted January 2, 2019 Author Report Share Posted January 2, 2019 Nice, just came out of annual along with the JPI EDM 830 install..... trying to take the high road on this. 1 Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted January 3, 2019 Report Share Posted January 3, 2019 Mine was done as part of my last annual, signed off, and included in flat rate. Now I definitely paid for lots of other stuff, but this inspection seems to be pretty easy. 1 Quote Link to comment Share on other sites More sharing options...
Gary0747 Posted January 3, 2019 Report Share Posted January 3, 2019 (edited) I obtained the heavy wall shaft for the pilot side that is not subject to the AD years ago. I still need the one for the copilot side to get clear of the AD. Seems ridiculous since very little time is spent flying from that side. If anybody knows a source for the heavy shafts now,please let me know. Edited January 3, 2019 by Gary0747 Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted January 3, 2019 Report Share Posted January 3, 2019 56 minutes ago, Gary0747 said: If anybody knows a source for the heavy shafts now,please let me know. me to Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted January 3, 2019 Report Share Posted January 3, 2019 1 hour ago, Gary0747 said: I obtained the heavy wall shaft for the pilot side that is not subject to the AD years ago. I still need the one for the copilot side to get clear of the AD. Seems ridiculous since very little time is spent flying from that side. If anybody knows a source for the heavy shafts now,please let me know. Mooney through your local MSC. I did the shafts on my M20C several years ago. I bought the shafts from Mooney through SWTA. BTW... DMax weighed in on this topic on the MAPA mailing list. 1 Quote Link to comment Share on other sites More sharing options...
Andy95W Posted January 3, 2019 Report Share Posted January 3, 2019 44 minutes ago, gsxrpilot said: BTW... DMax weighed in on this topic on the MAPA mailing list. What did he say? I was a MAPA member in the 1990s and again since 2011. I have never been able to crack the code on their antiquated mailing list. 1 Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted January 3, 2019 Report Share Posted January 3, 2019 Most are damaged complying with the AD. That is a tapered pin, bigger at top than nut side. They are damaged taking out or over torqued installing. There is also an allen set screw on the side that gets over torqued and collapses the tube. Later models have a thicker tube and not as easily damaged. If the yoke is tight and does not wiggle it should be OK. Dmax 2 Quote Link to comment Share on other sites More sharing options...
Marauder Posted January 3, 2019 Report Share Posted January 3, 2019 Mooney through your local MSC. I did the shafts on my M20C several years ago. I bought the shafts from Mooney through SWTA. BTW... DMax weighed in on this topic on the MAPA mailing list. I’m sure the price has gone up a lot but I bought the entire kit including yokes back in 1998. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
FastTex Posted January 3, 2019 Report Share Posted January 3, 2019 11 hours ago, RLCarter said: I purchased this from Aircraft Spruce Magnaflux Kit and gave it to my IA, he didn't charge me for the inspection or sign off. I removed my yokes, he did the inspection, I sent the yokes out to be wrapped in leather and we put them back on, total time was maybe 3hrs start to finish. Not exactly an answer but should give you an idea of the labor time Sorry for the off topic...where did you send the yokes, how long it took and how much? Thanks! Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 3, 2019 Report Share Posted January 3, 2019 3 hours ago, FastTex said: Sorry for the off topic...where did you send the yokes, how long it took and how much? Thanks! I used a local car upholstery shop, charged me $150 and took about a week. I also taped new wires for my PTT switches to the yokes before he wrapped them so the wire is under the leather and come out at the shaft and through the stitching on the yoke horn 1 Quote Link to comment Share on other sites More sharing options...
DualRatedFlyer Posted January 3, 2019 Report Share Posted January 3, 2019 11 minutes ago, RLCarter said: I used a local car upholstery shop, charged me $150 and took about a week. I also taped new wires for my PTT switches to the yokes before he wrapped them so the wire is under the leather and come out at the shaft and through the stitching on the yoke horn Does that mean your ready to part with those fancy buttons you made?? Quote Link to comment Share on other sites More sharing options...
RLCarter Posted January 3, 2019 Report Share Posted January 3, 2019 22 minutes ago, DualRatedFlyer said: Does that mean your ready to part with those fancy buttons you made?? Nope.... Did the PTT buttons at the same time the yokes were being done. They are easy to make, and when you glue the leather around them it hides a lot of sins 1 Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted January 3, 2019 Report Share Posted January 3, 2019 5 hours ago, FastTex said: Sorry for the off topic...where did you send the yokes, how long it took and how much? Thanks! http://customizer.aerocomfort.com/wheel/choose 3 Quote Link to comment Share on other sites More sharing options...
mike20papa Posted January 3, 2019 Report Share Posted January 3, 2019 There is such a better engineered upgrade to these shafts...than the "two holes are better than one" factory fix. I see a yoke/shaft connection that utilizes a thru piece of .25" X .032",4130 hard brazed (90ksi silver solder) to the interior of the main shaft that simultaneously reinforces and distributes out the yoke forces into the shaft... reinstall the control wheel, ream for AN3 bolt and forget about it... 1 Quote Link to comment Share on other sites More sharing options...
Andy95W Posted January 3, 2019 Report Share Posted January 3, 2019 19 minutes ago, mike20papa said: There is such a better engineered upgrade to these shafts...than the "two holes are better than one" factory fix. I see a yoke/shaft connection that utilizes a thru piece of .25" X .032",4130 hard brazed (90ksi silver solder) to the interior of the main shaft that simultaneously reinforces and distributes out the yoke forces into the shaft... reinstall the control wheel, ream for AN3 bolt and forget about it... I agree, that is better- is there any approval basis for this modification? It isn't included in the AD or SB M20-205B. 1 Quote Link to comment Share on other sites More sharing options...
M20C Posted February 11, 2019 Report Share Posted February 11, 2019 alternative means of compliance, perhaps? Quote Link to comment Share on other sites More sharing options...
Kesk Posted January 9 Report Share Posted January 9 On 1/2/2019 at 3:27 PM, RLCarter said: I purchased this from Aircraft Spruce Magnaflux Kit and gave it to my IA, he didn't charge me for the inspection or sign off. I removed my yokes, he did the inspection, I sent the yokes out to be wrapped in leather and we put them back on, total time was maybe 3hrs start to finish. Not exactly an answer but should give you an idea of the labor time Old post but this magnaflux kit is what we use on our DA20s for their nose gear dye pen check. Good stuff. 1 Quote Link to comment Share on other sites More sharing options...
