KB4 Posted December 30, 2018 Report Share Posted December 30, 2018 Huge thanks to MS ers for the help especially StevenL757 who flew in to personally help me. Didn’t sync but will do at next annual. AC/Nav brackets holes did not line up with existing nut plates so needed a little fab work to complete. Used existing power and ground from old power supplies which were all removed. Saved about 6lbs but need a more accurate scale for exact #. Unbelievable difference in brightness intensity. 6 1 Quote Link to comment Share on other sites More sharing options...
bradp Posted December 30, 2018 Report Share Posted December 30, 2018 Those look straight up mean. Nice work with the flush patch. 2 Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted December 31, 2018 Report Share Posted December 31, 2018 I agree. Shout out to Ed from Ed’s Aircraft Refinishing at Brookhaven Airport (KHWV) for helping with this work as well. Steve 1 Quote Link to comment Share on other sites More sharing options...
ZuluZulu Posted January 8, 2019 Report Share Posted January 8, 2019 Awesome! Would a short walkaround video showing all of these lights in action be too much to ask? Quote Link to comment Share on other sites More sharing options...
N442PT Posted January 9, 2019 Report Share Posted January 9, 2019 I just did the same Whelen 650 Upgrade. I also need to to run the wire to sync the strobes but it’s not that noticeable until you get close to the clouds. Very bright. 68F50956-9846-4C67-8A75-6BF9E4DD4EAA.MOV 2 Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted January 9, 2019 Report Share Posted January 9, 2019 Very nice! Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 9, 2019 Report Share Posted January 9, 2019 Great first post, PT! Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Niko182 Posted March 15, 2019 Report Share Posted March 15, 2019 I'm trying to do my conversion this weekend. Can regular connectors from a computer shop be used or do they need to be certified? Nik Quote Link to comment Share on other sites More sharing options...
Marauder Posted March 15, 2019 Report Share Posted March 15, 2019 1 hour ago, Niko182 said: I'm trying to do my conversion this weekend. Can regular connectors from a computer shop be used or do they need to be certified? Nik I think the mechanics will chime in shortly but I think they will need to be waterproof (at least that is what Terry and I did).I can't remember if we used knife disconnects or straight butt connectors. https://www.aircraftspruce.com/catalog/elpages/knifedisc.php Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 15, 2019 Report Share Posted March 15, 2019 how much did the three parts cost? Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 15, 2019 Report Share Posted March 15, 2019 in fact this is a great install...id like to get the exact model numbers and where would be the best place to buy these. Quote Link to comment Share on other sites More sharing options...
Niko182 Posted March 15, 2019 Report Share Posted March 15, 2019 I bought them off aircraft spruce. The set goes for about 1300 bucks, but its the last time youll need to replace the lights in the aircrafts life time. Also gain about 4 to 8 lbs of useful load, and the amp usage drops from 15 amps to about 2 to 4 amps. Quote Link to comment Share on other sites More sharing options...
Pritch Posted March 16, 2019 Report Share Posted March 16, 2019 6 hours ago, Niko182 said: I'm trying to do my conversion this weekend. Can regular connectors from a computer shop be used or do they need to be certified? Nik I used the heat shrink but connectors, simple easy and sanitary. Pritch Quote Link to comment Share on other sites More sharing options...
Niko182 Posted March 16, 2019 Report Share Posted March 16, 2019 1 hour ago, Pritch said: I used the heat shrink but connectors, simple easy and sanitary. Pritch so just a regular 4 pin connector can be used? Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted March 16, 2019 Report Share Posted March 16, 2019 10 hours ago, Pritch said: I used the heat shrink but connectors, simple easy and sanitary. Pritch The elves that did mine like these: https://www.aircraftspruce.com/catalog/elpages/soldering-sleeves.php?clickkey=9639 Quote Link to comment Share on other sites More sharing options...
bradp Posted March 16, 2019 Report Share Posted March 16, 2019 Standard electronic connectors are acceptable for electronic work. It doesn’t mean that you should use autozone quality stuff but it doesn’t need a PMA to be legal. Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted March 16, 2019 Report Share Posted March 16, 2019 7 hours ago, LANCECASPER said: The elves that did mine like these: https://www.aircraftspruce.com/catalog/elpages/soldering-sleeves.php?clickkey=9639 Does anyone have any thought as to whether these are make an electrical bond that is secure long term. I got some of them and like them. But they are so easy, I am afraid I am missing something. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted March 16, 2019 Report Share Posted March 16, 2019 1 minute ago, DonMuncy said: Does anyone have any thought as to whether these are make an electrical bond that is secure long term. I got some of them and like them. But they are so easy, I am afraid I am missing something. Before I ever allowed my elves to use them I tried one out on two pieces of wire about a foot in length each. After an hour i tried to pull apart the wires and was completely satisfied that this solder was a good connection. I don't have any evidence of this but it seems much more secure long term than any type of crimping connector. I used a small heat gun. (https://www.amazon.com/Wagner-0503038-HT400-Heat-650ᵒF/dp/B000X4SMRQ/ref=pd_di_srch_sabr_2/134-5393021-3486424?_encoding=UTF8&pd_rd_i=B000X4SMRQ&pd_rd_r=acf24912-4825-11e9-8448-5f8f8266119a&pd_rd_w=rwGOq&pd_rd_wg=9CO5w&pf_rd_p=9ef90f7a-801a-4369-9d2c-54e19e59e1d6&pf_rd_r=4D6WCWS8QEH7WQ9NSG97&psc=1&refRID=4D6WCWS8QEH7WQ9NSG97) Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted March 16, 2019 Report Share Posted March 16, 2019 Thanks Lancecasper. That is consoling to know. I was worried that the heat necessary to activate them seemed to be much lower that soldering temperature, and would not bond properly. I like that heat gun. It is neater for this job than the large one I used. Everyone should try these connectors. Quote Link to comment Share on other sites More sharing options...
ragedracer1977 Posted March 17, 2019 Report Share Posted March 17, 2019 9 hours ago, DonMuncy said: Thanks Lancecasper. That is consoling to know. I was worried that the heat necessary to activate them seemed to be much lower that soldering temperature, and would not bond properly. I like that heat gun. It is neater for this job than the large one I used. Everyone should try these connectors. Solder sleeves is what Garmin recommends for all their avionics installs... Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted March 17, 2019 Report Share Posted March 17, 2019 9 hours ago, ragedracer1977 said: Solder sleeves is what Garmin recommends for all their avionics installs... Also very interesting to know. I may have to get me one of those small heat guns. They should work much better in tighter spots. Quote Link to comment Share on other sites More sharing options...
tigers2007 Posted March 18, 2019 Report Share Posted March 18, 2019 Slightly (or way) off-topic but I just saw this on Barnstormers. Guy is asking only 18 AMU for the set! Says they normally cost 40 AMU. This really puts LED nav lighting into a new dimension. Quote Link to comment Share on other sites More sharing options...
Niko182 Posted March 18, 2019 Report Share Posted March 18, 2019 I finished my install today. Took. Me about 7 and a half hours to do the complete setup. That included removing the powersupplies, re creating new connectors, and replacing all 3 strobe lights, and syncing the wing lights. As of now 2 of the 3 lights are synced and im quite ahppy about it. Also gained 4.2lbs of useful load. Ill add pictures tomorrow when its all signed off. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted March 18, 2019 Report Share Posted March 18, 2019 Sync all 3 it will look very nice. Im doing this job in a Twin Comanche. Unbelievably the strobes and the nav are both on a single wire. Somehow the sync function is combined with that as well. The end result is I have to pull 120’ of 20ga wire to both wingtips and the tail. Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted March 18, 2019 Report Share Posted March 18, 2019 why can't you use the existing wire? Quote Link to comment Share on other sites More sharing options...
