0TreeLemur Posted January 16, 2019 Report Share Posted January 16, 2019 1 hour ago, M20F said: https://www.amazon.com/dp/B0041ESF2G/ref=cm_sw_r_cp_api_i_1ZZpCb96SXBNK Cool. We didn't have one of those. Quote Link to comment Share on other sites More sharing options...
M20C Posted February 1, 2019 Report Share Posted February 1, 2019 (edited) If you place a floor jack under the tail stand and a chain (put the chain through a vynal or rubber hose) around the prop shaft up front to support the motor, removing the top two motor mount bolts (on the firewall) will allow the engine to rotate forward (down) giving greater access to the accessories on the back of the motor. It is really an easy thing to do and will allow easier removal of the prop governor. This is why there is the small block on the lower two engine mount attachment points. Edited February 1, 2019 by M20C 2 1 Quote Link to comment Share on other sites More sharing options...
chriscalandro Posted February 1, 2019 Report Share Posted February 1, 2019 I did it last night. I removed the cover to my slick mag, moved the hot air scat hose and the right tools for the job made it no big deal. Quote Link to comment Share on other sites More sharing options...
salty Posted February 1, 2019 Report Share Posted February 1, 2019 1 hour ago, M20C said: If you place a floor jack under the tail stand and a chain (put the chain through a vynal or rubber hose) around the prop shaft up front to support the motor, removing the top two motor mount bolts (on the firewall) will allow the engine to rotate forward (down) giving greater access to the accessories on the back of the motor. It is really an easy thing to do and will allow easier removal of the prop governor. This is why there is the small block on the lower two engine mount attachment points. This is what i was going to suggest. I used this method when reinstalling my engine and installing the engine monitor. I could jack up the engine to see how lines fit, jack it back down to move it out of the way, do the work, put it back up to check clearances, rinse and repeat. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted February 1, 2019 Report Share Posted February 1, 2019 (edited) not sure I would use a chain (covered in anything) around the crankshaft, a 1" flat nylon strap is much easier on things Edited February 1, 2019 by RLCarter Quote Link to comment Share on other sites More sharing options...
salty Posted February 1, 2019 Report Share Posted February 1, 2019 I used the engine lifting strap, not the shaft. You're not even lifting the entire weight of the engine, so it'll handle it fine. 1 Quote Link to comment Share on other sites More sharing options...
M20C Posted February 11, 2019 Report Share Posted February 11, 2019 On 2/1/2019 at 3:18 PM, RLCarter said: not sure I would use a chain (covered in anything) around the crankshaft, a 1" flat nylon strap is much easier on things Either way... the vynal hose I use provides plenty of protection... strap would work as well. Quote Link to comment Share on other sites More sharing options...
chriscalandro Posted February 11, 2019 Report Share Posted February 11, 2019 (edited) I wouldn't do any of that. I got mine out in about an hour and a half and only removed a scat hose and the cover of a mag. Also, if anyone cares my new pcu5000 is awesome. Edited February 11, 2019 by chriscalandro Quote Link to comment Share on other sites More sharing options...
