25 RPM fluctuations
201Steve
23 minutes ago, 201Steve said:
Good call on the fuel pressure. I had forgotten that had happened. Here is a full instrument scan where the fuel pressure is moving again. It didn’t seem to have a correlation but maybe another thing to keep an eye on
11566D6A-61C2-476E-964C-1F9485AAC222.MOV
Were your strobes on? If so, try it again with the strobes off just to see if there's a ground issue.
Link to comment
Share on other sites
On 12/27/2018 at 6:34 PM, M20Doc said:
In your first video, as well as fuel pressure the old Alcor EGT wanders almost in sync with the tachometer.
All 3 seem to be goofing out a bit. Fuel Pressure, RPM, and Alcor EGT. The insight egt moves a little, but I figure there’s no way you get a constant EGT temp to the “T”. Or I wouldn’t think.
Link to comment
I believe that your fuel pressure gauge is a mechanical gauge, so the pressure may indeed be wandering.  I don’t think it would affect EGT, the servo should be able to handle some variation in pressures.
 Your G1 engine monitor sadly doesn’t have data logging from what I read on Insight Avionics
The tachometer is electric driven by magneto impulses from the P lead circuit.  With a constant speed propeller, I don’t think the RPM would change unless the governor isn’t able to keep up.  Do you feel/ hear a change in engine performance?
Link to comment
I’m hearing an occasional variation in sound/feel. It is maybe once or twice every 10-20 minutes. It’s very short, so by the time I start scanning and checking instruments, I can’t correlate it to fluctuation.
Link to comment
