FastTex Posted December 24, 2018 Report Share Posted December 24, 2018 Anyone with a M20F 1970 who can tell me where the freaking brakes fluid reservoir is located? I have opened all the cowlings and the compartment where the battery is installed but I cannot see one. I have checked the service manual but the book I have doesn't show the location. I have checked inside the cabin but I could not see it...it got to be somewhere! Merry XMAS MSers! 1 Quote Link to comment Share on other sites More sharing options...
7.Mooney.Driver.0 Posted December 24, 2018 Report Share Posted December 24, 2018 it installed inside on the upper left hand side of the firewall, you can access it by removing the LH avionics panel. Hope this helps. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
orionflt Posted December 24, 2018 Report Share Posted December 24, 2018 Just forward of the pilots windscreen aft of the firewall, under the avionics access panel Brian Quote Link to comment Share on other sites More sharing options...
FastTex Posted December 24, 2018 Author Report Share Posted December 24, 2018 Thanks! So it's inside the cabin...I need to remove the top instrument cover to check the level...wow! I do not see any inspection panels from the outside... Quote Link to comment Share on other sites More sharing options...
7.Mooney.Driver.0 Posted December 24, 2018 Report Share Posted December 24, 2018 Thanks! So it's inside the cabin...I need to remove the top instrument cover to check the level...wow! I do not see any inspection panels from the outside... Yes it located inside the cabin, If you have the 201 windshield mod those access panels are removed. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Sabremech Posted December 24, 2018 Report Share Posted December 24, 2018 57 minutes ago, siu1526 said: Yes it located inside the cabin, If you have the 201 windshield mod those access panels are removed. Sent from my iPhone using Tapatalk If you have the SWTA 201 windshield mod, you still have smaller access panels. David 3 Quote Link to comment Share on other sites More sharing options...
FastTex Posted December 24, 2018 Author Report Share Posted December 24, 2018 I have the Lasar mod not sure if it's the 201 I need to verify. How do you guys check the fluid level? It seems absurd to remove the top of the instrument panel at every pre-check... Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted December 24, 2018 Report Share Posted December 24, 2018 Mine drips on my foot occasionally, so I know there’s fluid in it! 3 2 Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 25, 2018 Report Share Posted December 25, 2018 If you have the SWTA 201 windshield mod, you still have smaller access panels. David SWTA cowl mod with the access panel removed and a rubber stopper in place for bleeding the brakes. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
FastTex Posted December 25, 2018 Author Report Share Posted December 25, 2018 5 minutes ago, Marauder said: SWTA cowl mod with the access panel removed and a rubber stopper in place for bleeding the brakes. Sent from my iPhone using Tapatalk Pro Got it....unfortunately I do not have that inspection panel... Quote Link to comment Share on other sites More sharing options...
Culver LFA Posted December 25, 2018 Report Share Posted December 25, 2018 12 minutes ago, Marauder said: Correction! SWTA cowl mod with the access panel removed and a rubber stopper in place for bleeding the brakes. Quote Link to comment Share on other sites More sharing options...
Ragsf15e Posted December 25, 2018 Report Share Posted December 25, 2018 I have 201 windshield, no access plates. The fill tube/valve runs through the firewall and is easily accessible with top cowl off. Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 25, 2018 Report Share Posted December 25, 2018 If all the rubber hoses have been replaced... Access is usually, an annual event. If the rubber hoses (return lines) are ancient, they drip... waiting for annual leads to flaps not working before annual... Then the leaks all get repaired. PP thoughts only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
rbridges Posted December 25, 2018 Report Share Posted December 25, 2018 11 hours ago, Ragsf15e said: I have 201 windshield, no access plates. The fill tube/valve runs through the firewall and is easily accessible with top cowl off. yep. We bled my flaps. There is hose coming through the firewall. When they forced fluid from the bottom, it pushed fluid out the hose by the firewall. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted December 26, 2018 Report Share Posted December 26, 2018 On 12/25/2018 at 8:59 AM, rbridges said: yep. We bled my flaps. There is hose coming through the firewall. When they forced fluid from the bottom, it pushed fluid out the hose by the firewall. seems kind of defeatist to have a tubing with flammable liquids coming through the firewall. Quote Link to comment Share on other sites More sharing options...
MikeOH Posted December 26, 2018 Report Share Posted December 26, 2018 Interesting. My ‘70F has the 201 windshield and the brake fluid reservoir is on the engine side of the fire wall; easily accessible with the top cowling removed. I just assumed that was the stock location until this thread. Quote Link to comment Share on other sites More sharing options...
kpaul Posted December 27, 2018 Report Share Posted December 27, 2018 1 hour ago, Yetti said: seems kind of defeatist to have a tubing with flammable liquids coming through the firewall. You mean like my stock fuel and oil pressure gauges? 2 Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 27, 2018 Report Share Posted December 27, 2018 Interesting. My ‘70F has the 201 windshield and the brake fluid reservoir is on the engine side of the fire wall; easily accessible with the top cowling removed. I just assumed that was the stock location until this thread. I think someone was smart and moved it from its original location. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
FastTex Posted December 27, 2018 Author Report Share Posted December 27, 2018 2 hours ago, MikeOH said: Interesting. My ‘70F has the 201 windshield and the brake fluid reservoir is on the engine side of the fire wall; easily accessible with the top cowling removed. I just assumed that was the stock location until this thread. I flew a PA28-140 for a few years and the brakes fluid check was part of the pre-flight. The reservoir was easily accessible opening the cowling (I know...different shape, system, etc.). I never thought this was going to become such a big deal! I wish mine was were yours is but I'm afraid @Marauder is right: someone moved it. I guess I will just remove the top instrument panel cover and take a peak... Quote Link to comment Share on other sites More sharing options...
Yetti Posted December 27, 2018 Report Share Posted December 27, 2018 2 hours ago, kpaul said: You mean like my stock fuel and oil pressure gauges? Which I am sure have been converted to stainless braid teflon hoses and appropriately sealed at the firewall interface. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted December 27, 2018 Report Share Posted December 27, 2018 5 minutes ago, Yetti said: Which I am sure have been converted to stainless braid teflon hoses and appropriately sealed at the firewall interface. You’ve converted yours? Quote Link to comment Share on other sites More sharing options...
Yetti Posted December 27, 2018 Report Share Posted December 27, 2018 Just now, Shadrach said: You’ve converted yours? Mine came converted or that would have been the first thing I did. Quote Link to comment Share on other sites More sharing options...
FastTex Posted December 27, 2018 Author Report Share Posted December 27, 2018 7 hours ago, Yetti said: Mine came converted or that would have been the first thing I did. So we are talking about moving the reservoir to the engine side of the firewall...is there any space? Do you guys have it in the same exact position but opposite firewall location? Quote Link to comment Share on other sites More sharing options...
RLCarter Posted December 27, 2018 Report Share Posted December 27, 2018 3 hours ago, FastTex said: So we are talking about moving the reservoir to the engine side of the firewall...is there any space? Do you guys have it in the same exact position but opposite firewall location? The ones I've seem leave the resivoir aft of the firewall and uses tubing to plumb the filler to the other side Quote Link to comment Share on other sites More sharing options...
Yetti Posted December 27, 2018 Report Share Posted December 27, 2018 (edited) I could see several concepts. Inside: You would still have brakes if you caught the engine on fire. One less hole in the firewall which is a goal. But they make sealant to keep the fire out. Outside: Would probably need a DER to do it, though some of the Cs have it outside. Someone machined a very nice one. Maybe think about using hard tubing for the direction you choose. As long as there are no leaks, you don't have to access it for decades. Although it is on the annual inspection. Edited December 27, 2018 by Yetti Quote Link to comment Share on other sites More sharing options...
