MrRodgers Posted December 9, 2018 Report Share Posted December 9, 2018 I was reading through some recent threads about the cockpit fuel drain this week and there were viewpoints shared for and against utilizing the fuel drain next to the fuel selector in the cabin. I filled my tanks today and sumped each tank and used the cockpit drain pull as the plane has been sitting for a few weeks. I later noticed a slight and slow dripping outside my hangar coming from the fuel sump under the cockpit. The dripping continued throughout the day. After 4 hours of flight time it still continues. Has anyone else experienced this and if so what’s the fix? A new O ring / seal? Thanks in advance for your suggestions. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ilovecornfields Posted December 9, 2018 Report Share Posted December 9, 2018 Did you try pulling it all the way up then pushing it all the way down slowly a couple of times? Mine did that once but that fixed it. Hopefully it’s not dripping in the hangar. Might be a good idea to make sure your fuel valve is off. 2 Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 9, 2018 Report Share Posted December 9, 2018 I was reading through some recent threads about the cockpit fuel drain this week and there were viewpoints shared for and against utilizing the fuel drain next to the fuel selector in the cabin. I filled my tanks today and sumped each tank and used the cockpit drain pull as the plane has been sitting for a few weeks. I later noticed a slight and slow dripping outside my hangar coming from the fuel sump under the cockpit. The dripping continued throughout the day. After 4 hours of flight time it still continues. Has anyone else experienced this and if so what’s the fix? A new O ring / seal? Thanks in advance for your suggestions. Sent from my iPhone using Tapatalk You’ll need to replace the O rings in the gasoclator. I bought mine from Lasar. https://lasar.com/seal-kitsSent from my iPad using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
Shadrach Posted December 9, 2018 Report Share Posted December 9, 2018 Check the fuel pump drain. Quote Link to comment Share on other sites More sharing options...
EricJ Posted December 9, 2018 Report Share Posted December 9, 2018 There are several things in that location that could be dripping. When mine did that it was a loose fitting on one of the fuel lines (it had been worked on recently). Reseating the ring, i.e., activate the drain again a couple times, may help if that's what's dripping. 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted December 9, 2018 Report Share Posted December 9, 2018 If it’s really the collator you may not have pushed it all the way in. However it’s good to replace the seal at annual since you have it appart anyway. -Robert 1 Quote Link to comment Share on other sites More sharing options...
FloridaMan Posted December 10, 2018 Report Share Posted December 10, 2018 I always hold it for three seconds. As part of preflight, I open the cabin door, slide my body between the door and the wing, place both hands on my wing and set my ass on the wing walk (make sure you're not wearing pants or a jacket with metal rivets or zippers that could scratch things), lean over and pull the ring for three seconds, then get up and continue to sump my wings and look in the tanks. This is the fastest way to check it and beats having to walk all the way around the wing and having to get in the plane to reach it. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted December 10, 2018 Report Share Posted December 10, 2018 Could also be the fuel pump has gone south. They are in the same area Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 11, 2018 Report Share Posted December 11, 2018 Reminder... 1) mechanical fuel pump has a drain... 2) electric fuel pump has a drain... 3) Fuel separator has a drain... All three are within feet of each other and look pretty similar from a few feet away... Find out what’s leaking and why... could be a cleaning and reseating a valve, or replace an oring, or a fuel pump diaphragm/OH... Just a summary of what I read here... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
