Candy man Posted December 6, 2018 Report Share Posted December 6, 2018 I need a replacement for the panel dimmer light that’s attached to the board. It’s a 1970 m20c and I have no clue where to get one. Any advice and direction would be greatly appreciated. Lawrence Quote Link to comment Share on other sites More sharing options...
DanM20C Posted December 6, 2018 Report Share Posted December 6, 2018 (edited) Lawrence, If you are referring to the assembly that contains the rheostat I don't think there are any simple replacements for it. The assembly is more than just a dimmer, it also controls the annunciator lights. They are relatively easy to fix. What is wrong with yours? Cheers, Dan Edited December 6, 2018 by DanM20C Quote Link to comment Share on other sites More sharing options...
steingar Posted December 6, 2018 Report Share Posted December 6, 2018 All I have are the torpedo lights in the ceiling, and they're so ineffective I might as well be using the Force. Somebody posted up an LED install for those, I'm going have to check that out. Quote Link to comment Share on other sites More sharing options...
N6018Q Posted December 6, 2018 Report Share Posted December 6, 2018 4 hours ago, steingar said: All I have are the torpedo lights in the ceiling, and they're so ineffective I might as well be using the Force. Somebody posted up an LED install for those, I'm going have to check that out. Search "Raptor's LED Torpedo Retrofit" 2 Quote Link to comment Share on other sites More sharing options...
Candy man Posted December 6, 2018 Author Report Share Posted December 6, 2018 18 hours ago, DanM20C said: Lawrence, If you are referring to the assembly that contains the rheostat I don't think there are any simple replacements for it. The assembly is more than just a dimmer, it also controls the annunciator lights. They are relatively easy to fix. What is wrong with yours? Cheers, Dan Half of our panel lights don’t light up.we’re afraid to work on that circuit board out of fear of losing more lights. Lawrence Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted December 6, 2018 Report Share Posted December 6, 2018 Just replace it with one of these: https://www.aircraftspruce.com/catalog/elpages/maxDimUnit.php?gclid=EAIaIQobChMI3ZXHk5yM3wIVAcNkCh2OXwA2EAQYBSABEgK8LfD_BwE Quote Link to comment Share on other sites More sharing options...
DanM20C Posted December 6, 2018 Report Share Posted December 6, 2018 20 minutes ago, Candy man said: Half of our panel lights don’t light up.we’re afraid to work on that circuit board out of fear of losing more lights. Lawrence If half the lights are working and half are not, there are only three components that would be suspect. A diode, transistor, and Fuse. I would check the fuse first. You should have 2 little 5A fuses mounted on the aluminum chassis of the assembly. Each handles 1/2 of the lighting. Pull each out and check continuity across the pins. Do all the annunciator lights work when you push the test button? Cheers, Dan Quote Link to comment Share on other sites More sharing options...
0TreeLemur Posted December 7, 2018 Report Share Posted December 7, 2018 15 hours ago, N201MKTurbo said: Just replace it with one of these: https://www.aircraftspruce.com/catalog/elpages/maxDimUnit.php?gclid=EAIaIQobChMI3ZXHk5yM3wIVAcNkCh2OXwA2EAQYBSABEgK8LfD_BwE We used one of these, and it works fine. It uses pulse-width modulation rather than resistive loading to vary the power delivered at constant voltage, so it dims both LEDs and incandescent bulbs. The lack of a large resistive load makes it lighter, considerably more efficient, and cooler running when dimming than a rheostat. The only thing I don't like it is the price. There are $30 alternatives that do the exactly the same thing, but they are not STC'd. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted December 7, 2018 Report Share Posted December 7, 2018 4 minutes ago, Fred_2O said: We used one of these, and it works fine. It uses pulse-width modulation rather than resistive loading to vary the power delivered at constant voltage, so it dims both LEDs and incandescent bulbs. The lack of a large resistive load makes it lighter, considerably more efficient, and cooler running when dimming than a rheostat. The only thing I don't like it is the price. There are $30 alternatives that do the exactly the same thing, but they are not STC'd. $30? you are overpaying! https://www.ebay.com/p/Brightness-PWM-Switch-Controller-Dimmer-for-LED-Strip-Light-12v-to-24v-8a-96w/19014519521?iid=192450239343 1 Quote Link to comment Share on other sites More sharing options...
