Mark89114
grey metal dust around alternator
Changing the oil on my Mooney Ovation and I go over all fittings, connections, etc. under the cowling and saw this gray looking dust on air intake.  Further investigation and you can see where it is coming from around the alternator.  The alternator was overhauled I am guessing about 100+ hours ago.  I also just recently spend about 2 hours flying in icing with the TKS fluid so wondering if that is causing any type of issues with washing "dirt" out of alternator?  I called my mechanic and he suggested possibility of the bolts being loose and fretting.  I did run my finger out of the alternator exhaust and nothing really there.  Any thoughts?
  20181204_190728.thumb.jpg.3696b1209b4ff3e3061c8909f95aa588.jpg20181204_190829.thumb.jpg.dd2d951f3b884e5506dab1a738989239.jpg
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
that is probably from the brushes in the alternator, I would be looking at what you want to replace it with. I personally like the plane power replacements.
Brian
Share this post
Link to post
See if there is any break-in advice for the alternator...?
Sharp square ends of the brushes may have a high wear-in phase...before conforming with the
 round shape they are following...(?)
In the mean time... clean the dusty mess and see if it comes back... (?)
New IO550 alternator, excessive dust, pics... an invite for @M20Doc to take a look as well...
I’m not a mechanic...
Share this post
Link to post
Brian
Us fancy Mooney Ovation owner have fancy geared alternators connected to internal gears on the engine, so I don't think that is an option.
Share this post
Link to post
they have direct drive replacements
Brian
Share this post
Link to post
I am not in a panic mode that this is going to cost me money yet......visiting my mechanic tomorrow and will see what he has to say.
Share this post
Link to post
just took a look and what they have are rebuilt not new replacement. looks like nothing worth getting your hopes up for. sorry.
Share this post
Link to post
I get that grey dust washed from the TKS on the prop slinger also. I get it all over the engine. Maybe just airflow is making it look like from the alternator?
Share this post
Link to post
There is a replacement option.  When mine started giving me grief, it made more sense to replace it with a new one of these than rebuild.  So far so good and a few pounds lighter off the nose.
https://www.aircraftspruce.com/pages/st/manu_hartzell/alv9610alternator.php
That said, if it isn't in the exhaust opening from the alternator itself, that probably came from around the alternator not the alternator itself.   I would clean it up and see if you can figure out where its coming from.  I don't think I'd be ready to swap the alternator right away.  There's also a pretty expensive coupler in there.  If it wasn't replaced at the last overhaul, that might need to be replaced too.  I changed mine out while we were in there.
Share this post
Link to post
I would remove the composite cover from the alternator then grasp the outer end of the alternator and give it a good twist to see if the 2 halves are loose at the tie bolts.
Share this post
Link to post
Update.....my mechanic looked at it and thinks it is from the composite cover wearing against the housing.  The two halves were tight and the alternator bolts are all snug, no movement.  Going to clean it up and see what happens.  Will keep an eye on it obviously.
Share this post
Link to post
that's good news
Share this post
Link to post
Anyone know why that shroud is really even there?  The parts book shows a hose on that exhaust port but I never had that.  I find it hard to believe its necessary for cooling with teh alternator directly in the stream of the blast air.  All it seems to do is direct air down and away from the cylinders.
Can the shroud be taken off for a while to see if the grey dust goes away?
Share this post
Link to post
The shroud helps direct air into the alternator then out the lower vent tube.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
