RobertGary1 Posted November 16, 2018 Report Share Posted November 16, 2018 Curious if anyone knows if there exists a copy of some of the old FAA requirements for certificates. I believe before the PTS there was the PTG but I've never been able to find a copy of one. Would be interesting to see what was required for private/com/CFI in the 60's for example. -Robert Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 16, 2018 Report Share Posted November 16, 2018 A historic record of all the annual FAR books would hold the key...I kept the new book next to all the old books... every year. There is probably a change record of the changes in each volume. Minimizing the amount of reading the same detail year after year... From a history point of view, send this question to AOPA... that would give their legal department an interesting way to write a page of important changes through the years.... Some of the changes were how to comply with the rule, as much as the rule itself... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
BDPetersen Posted November 16, 2018 Report Share Posted November 16, 2018 I matriculated through those certificates in the early ‘60’s but I won’t try to recite the details without digging out the old flight test guides. Basically 40 hrs for private, 200 hrs for commercial and CFI. No night required for private. Cross country requirement a bit different for private. 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted November 16, 2018 Author Report Share Posted November 16, 2018 (edited) 17 minutes ago, BDPetersen said: I matriculated through those certificates in the early ‘60’s but I won’t try to recite the details without digging out the old flight test guides. Basically 40 hrs for private, 200 hrs for commercial and CFI. No night required for private. Cross country requirement a bit different for private. Were the maneuvers similar? Do you think the requirements have progressively gotten easier/harder/about the same? -Robert Edited November 16, 2018 by RobertGary1 Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted November 16, 2018 Report Share Posted November 16, 2018 I heard that neither Orville, nor Wilbur even took a lesson prior to first solo. Can you believe it? Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted November 17, 2018 Author Report Share Posted November 17, 2018 (edited) 5 hours ago, Mooneymite said: I heard that neither Orville, not Wilbur even took a lesson prior to first solo. Can you believe it? They crashed too. Luckily they were only a few feet above ground -Robert Edited November 17, 2018 by RobertGary1 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted November 17, 2018 Report Share Posted November 17, 2018 Historical Regs Quote Link to comment Share on other sites More sharing options...
BDPetersen Posted November 17, 2018 Report Share Posted November 17, 2018 Digging out my copy of 1963 FAR’s (CAR’s prior to that)(this must be why I don’t throw stuff away) . . . The maneuvers aren’t so very different. The recent dumbing down of stall recovery being an exception. (Stall recognition was to be done without the aid of a stall warning device, for instance.) Instrument training and proficiency were required but minimal. ( The aircraft need only have a turn needle.) My biggest heart ache is in the cross country requirements. Back then there was a required solo xc leg of 100 miles. As it is now, one could be certified having only flown 50 miles at a time, practically seeing the destination soon after departure. I could do without the night xc that is now required. Long gone from the ATP ( we called it ATR back then. R for rating) is the beloved canyon approach. What fun is left? 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted November 18, 2018 Author Report Share Posted November 18, 2018 I found some Pilot Test Guides on eBay from the 60’s and 70’s. Should arrive next week. -Robert Quote Link to comment Share on other sites More sharing options...
