Bob_Belville Posted November 7, 2018 Report Share Posted November 7, 2018 As some here will know, I had my plane painted this year. It turned out well, looks great. But the plane is noticeably slower and I am trying to figure out why. One possible issue is the paint trim stripes. The ends of the wings and (horizontal stabilizer) has 4 stripes angled and tapered, top and bottom. There's a paint ridge, perhaps as much as 1/16" high between all the stripes. Since the airflow over and under the wing passes over these ridges I suppose there is disruption. So... does anyone here have experience/knowledge as to whether this might be causing drag? And... what would be the best way to remove the ridge without screwing up the paint job? Thanks! Quote Link to comment Share on other sites More sharing options...
jackn Posted November 7, 2018 Report Share Posted November 7, 2018 Small ridges, unlikely. Control surfaces not put back exactly how they were removed, very likely. 13 2 Quote Link to comment Share on other sites More sharing options...
GLJA Posted November 7, 2018 Report Share Posted November 7, 2018 Weight difference Before new paint vs after? as @jackn said, the way the control surfaces were reinstalled would create a lot more drag than paint. I know I've drooled over this paint job in the past few months, but never saw the original paint job before. Questioning how a "smooth" paint vs. a previously "rough" job would cause more drag. Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted November 7, 2018 Report Share Posted November 7, 2018 Nothing slows a Mooney down quite like poor rigging. And no one seems to be able to coax as much speed out of a good rigging job as Don Maxwell. 4 1 Quote Link to comment Share on other sites More sharing options...
GLJA Posted November 7, 2018 Report Share Posted November 7, 2018 17 minutes ago, gsxrpilot said: Nothing slows a Mooney down quite like poor rigging. And no one seems to be able to coax as much speed out of a good rigging job as Don Maxwell. My fuel servo has slowed mine down considerably over the past 3 weeks.... Top speed has been 10-15 ktas, behind a tug, back and forth from the mechanics hangar and mine. 1 2 Quote Link to comment Share on other sites More sharing options...
orionflt Posted November 7, 2018 Report Share Posted November 7, 2018 2 minutes ago, CDNflyby said: My fuel servo has slowed mine down considerably over the past 3 weeks.... Top speed has been 10-15 ktas, behind a tug, back and forth from the mechanics hangar and mine. that's moving a bit fast, I would recommend 5 kts max Brian Quote Link to comment Share on other sites More sharing options...
GLJA Posted November 7, 2018 Report Share Posted November 7, 2018 1 minute ago, orionflt said: that's moving a bit fast, I would recommend 5 kts max Brian Pure estimates.... But, yeah your right. Strong tailwind? Quote Link to comment Share on other sites More sharing options...
orionflt Posted November 7, 2018 Report Share Posted November 7, 2018 I have seen people hauling ass towing planes, while that in it self isn't a major issue the problem is more the force on the nose gear when you turn, or need to slow or stop. a sudden stop could cause the gear to collapse and turns at high speeds will increase side loads on the nose gear. when you are taxing at higher speeds you are breaking with the mains so there is no load pushing back on the nose gear, turning at high speeds can put increased side load on the gear but that load is exaggerated by a tow bar attached to a vehicle. Quote Link to comment Share on other sites More sharing options...
Hank Posted November 7, 2018 Report Share Posted November 7, 2018 42 minutes ago, orionflt said: that's moving a bit fast, I would recommend 5 kts max Mine was last towed behind a small, dark red riding mower with the deck removed, with the mower running backwards to pull the plane from the ramp to the A&P's shop . . . Not quite my own [slow] walking speed . . . . Quote Link to comment Share on other sites More sharing options...
GLJA Posted November 7, 2018 Report Share Posted November 7, 2018 37 minutes ago, orionflt said: I have seen people hauling ass towing planes, while that in it self isn't a major issue the problem is more the force on the nose gear when you turn, or need to slow or stop. a sudden stop could cause the gear to collapse and turns at high speeds will increase side loads on the nose gear. when you are taxing at higher speeds you are breaking with the mains so there is no load pushing back on the nose gear, turning at high speeds can put increased side load on the gear but that load is exaggerated by a tow bar attached to a vehicle. I'm happy to have a AME that's cautious, and works on a lot of Mooney's.... He's slow as F&&K when it comes to getting things done (Fuel Servo has been back from OH for 11 days now... just finishing putting it on today), but he's careful and meticulous. My comment was that it wasn't going 145 kts like it should... Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted November 7, 2018 Report Share Posted November 7, 2018 When your airplane was disassembled for paint and re-assembled could the rigging have been effected? How is the rigging currently? Does the ball sit centered when you are in level flight? 1 Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 7, 2018 Author Report Share Posted November 7, 2018 4 minutes ago, aviatoreb said: When your airplane was disassembled for paint and re-assembled could the rigging have been effected? How is the rigging currently? Does the ball sit centered when you are in level flight? Eric, presumably the ailerons were put back on exactly as they were taken off, at the hinges, without changing the rigging. There is a definite possibility that the trailing edges of the control surface were changed. Lynn and I are in the process of re-tweaking them. Ball is centered in cruise. 1 Quote Link to comment Share on other sites More sharing options...
wcb Posted November 7, 2018 Report Share Posted November 7, 2018 Not only the rigging but I know you also had that new cowl. Is it noticeable after the cowl to after paint or before the cowl to after paint. How many kts is "noticeable"? The good news is it LOOKS FAST!!!!!!! 1 Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted November 7, 2018 Report Share Posted November 7, 2018 (edited) 1 hour ago, wcb said: Not only the rigging but I know you also had that new cowl. Is it noticeable after the cowl to after paint or before the cowl to after paint. How many kts is "noticeable"? The good news is it LOOKS FAST!!!!!!! You know - dawling - its now how you feel, its how you wrook. And you wrook MAAAVELOUS! Edited November 7, 2018 by aviatoreb 2 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted November 7, 2018 Report Share Posted November 7, 2018 1 hour ago, Bob_Belville said: Eric, presumably the ailerons were put back on exactly as they were taken off, at the hinges, without changing the rigging. There is a definite possibility that the trailing edges of the control surface were changed. Lynn and I are in the process of re-tweaking them. Ball is centered in cruise. No way that any of the control surfaces could be incorrectly installed, about the only thing that could be done improperly beyond balancing them would be too not use the proper hardware which can be verified visually. Neither effects rigging. 1 Quote Link to comment Share on other sites More sharing options...
steingar Posted November 7, 2018 Report Share Posted November 7, 2018 Bob, with the amount of stuff done to that airplane the last thing I would think about slowing it down would be paint stripes. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 7, 2018 Author Report Share Posted November 7, 2018 Not only the rigging but I know you also had that new cowl. Is it noticeable after the cowl to after paint or before the cowl to after paint. How many kts is "noticeable"? The good news is it LOOKS FAST!!!!!!! We finished the cowl just in time to fly to the painter so no data to distinguish. But the other planes with the SabreCowl all report speed gains.Sent from my XT1710-02 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Piloto Posted November 7, 2018 Report Share Posted November 7, 2018 Check Alternate air button position Pitot tube paint residue Static ports paint residue Static and pitot tube paint residue. José 1 Quote Link to comment Share on other sites More sharing options...
steingar Posted November 7, 2018 Report Share Posted November 7, 2018 1 hour ago, Bob_Belville said: We finished the cowl just in time to fly to the painter so no data to distinguish. But the other planes with the SabreCowl all report speed gains. The fact that other aircraft reported gains doesn't automatically mean yours will. Too small a sample size to really make solid predictions. Quote Link to comment Share on other sites More sharing options...
wcb Posted November 7, 2018 Report Share Posted November 7, 2018 55 minutes ago, Piloto said: Check Alternate air button position Pitot tube paint residue Static ports paint residue Static and pitot tube paint residue. José I think Jose is onto something. When I had my G5's installed and they re-certified my pitot static system I was having some false readings and they had to track down some leaks. Therefore, you might actually be going as fast as it looks but just reading slower. 1 Quote Link to comment Share on other sites More sharing options...
kpaul Posted November 7, 2018 Report Share Posted November 7, 2018 1 hour ago, Bob_Belville said: We finished the cowl just in time to fly to the painter so no data to distinguish. But the other planes with the SabreCowl all report speed gains. Sent from my XT1710-02 using Tapatalk Bob, But you had the ARI cowl before, the others I believe just had the LASAR lower enclosure and some still had the air and oil filter out front. It would make sense that those planes would see genuine gains where yours may not. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 7, 2018 Author Report Share Posted November 7, 2018 Just now, kpaul said: Bob, But you had the ARI cowl before, the others I believe just had the LASAR lower enclosure and some still had the air and oil filter out front. It would make sense that those planes would see genuine gains where yours may not. I Agree. The ARI was fine. But it is not that I've not gained speed, which I did not expect to gain much if anything, I have lost at least 5 kts, maybe more. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 7, 2018 Author Report Share Posted November 7, 2018 1 hour ago, Piloto said: Check Alternate air button position Pitot tube paint residue Static ports paint residue Static and pitot tube paint residue. José Thanks José. The plane had a static system certification after the paint job. IAS seems to be accurate. I made a round trip to Smithfield (about 150 nm due east) last week and the GPS ground speed was 160 kts with a strong tail wind and 115 on the return. 7000' and 6000', 8.1 GPH LOP. Not to assume too much precision, that's an average of 135-140 kts. I would have expected about 145 TAS under those conditions. Quote Link to comment Share on other sites More sharing options...
petegaz40 Posted November 7, 2018 Report Share Posted November 7, 2018 Have you checked your gear doors? Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted November 7, 2018 Author Report Share Posted November 7, 2018 Just now, petegaz40 said: Have you checked your gear doors? yes Quote Link to comment Share on other sites More sharing options...
