nosky2high
M20F Alternator Conversion - Belt Part#
We recently upgraded from an M20C to a 67’ M20F. Some of the initial upgrade chores include replacing the starter with a skytec 149NL, installing an Airwolf Remote Oil Filter kit, and have the planepower 70amp alternator conversion kit ready to install next.
Question, what alternator belt should be ordered for this combination?
I assume I’m not the first to have done this.
Edited by nosky2high
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
This may be of some help.   If you get the Gates Belt from NAPA, you can save $40 that you can use in gas driving back and forth till you get the right length.  Or buy several lengths and then just return the rest.
Or you can buy one of these for an emergency belt, get it to the right size and then take it to NAPA.   Then use it for Emergencies.
https://www.harborfreight.com/vibration-free-link-belt-43771.html
Share this post
Link to post
It should be the -376 belt.
Share this post
Link to post
I didn’t realize you were converting from a generator to an alternator. The -376 is the narrow belt used when an alternator was previously installed.
Share this post
Link to post
So I should go with the -341?
Share this post
Link to post
The belt on my plane has a Gates part number.  I can take a picture of it for you this evening if it'll help.
Share this post
Link to post
Please do thanks
Share this post
Link to post
A  few years ago I converted my 64c, serial number 2799 from a generator to the plane power alternator #SAL12-70.
The belt that is on my plane is a 9335 Gates Green Stripe XL 13A0850
Share this post
Link to post
Is you current belt is in good shape?
When I converted my E from generator to Plane Power alternator I used the same belt that was on there and eliminated the need to remove the prop.
Share this post
Link to post
Planepower left a workaround on choosing which belt can be used legally. It’s not in the text of the STC, but if you look at the drawings for the installation instructions, you will see a Gates part number along with one of those high dollar PMA numbered belts.  I chose to save the $50 and installed the Gates version from National Aircraft Parts Association (NAPA).
-_-
Edited by pmccand
Oops
Share this post
Link to post
There was a minor leak at the crank seal that I wanted to fix anyway so I might as well install a new belt.
Share this post
Link to post
Confirmed today that if you’re converting your generator equipped M20F to a PlanePower alternator this is the belt that fit in my situation.
Share this post
Link to post
7 hours ago, nosky2high said:
Out with the boat anchors and in with lighter weight, better performing, replacements.
Welcome to the club.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
