My (recently new-to-me) M20-C has a serial number of 2858.  Its been called a 1964 since the beginning but that serial number is among those for 1965 Mooney-Cs... Should I pursue correcting this or just Own me a '64?
3 minutes ago, neilpilot said:
You don’t own a 64C. Is it N7896V or N960GS? What do you need to correct?
0GS... The year on the registration says 1964... even though the serial number is 1965...
do you have square rear window or the curved rear window?
Curved = 64
square = 65
1 minute ago, mooniacX said:
Then I would say you definitely have a 65 :)
yea... I thought so... Now how to get it corrected on the registration...
Mooney followed car manufacturers of the time.  The ‘Model Year’ has nothing to do with registration date.  Why worry about changing it?  You have a 65 model built in 64.
If I bought a 1965 Mustang that was built in September of 1964, the registration still identifies it as a 1965 not a 1964, right... I know I'm picking nits, right? Just thought for accuracy sake, I should get it fixed... but first wanted to confirm my thoughts with you folks first
Edited by MIR2018
Focus on something more important.  There is nothing to fix.  Unless of course you still don’t have front shoulder belts.
  • Like 5
I have s/n 895,       registration shows 65....   mooney s/n data shows 66.....     as far as i can tell  after a yr of flying it....   no body cares...  and i am starting to wonder if I do... ???
I'm pretty sure for car registration, the date is the "model year", not the year of manufacture.  A quick google search suggests that the model year starts in October and goes through the following October, so a 2018 "model year" car was built in either 2018 or 2017.  So another 1965 Mustang could have actually been built in 1965
54 minutes ago, 1964-M20E said:
just own it!!  :D:)
and fly it like you stole it:o:D:)
sounds like we've reached a consensus... I'll do it!!
I ordered them installed while in prepurchase... wouldn’t fly without them
What difference does it make?  I have the same issue with my F.  It is listed some places as a 65 and others as a 66.  As long as it doesn’t change the plane in some way, I don’t care which it is.
If you did a vref on a 64 and 65 with everything else the same... I wonder, would it be worth more?
If you have squared windows and quarter turn fasteners on the cowl, call it a ‘65, even if built in ‘64.  I was looking at both when I bought.  Love my ‘64, but wish I had a ‘65 cowl...a little easier to pull the panels.  Enjoy it either way!
1 hour ago, PilotCoyote said:
What year did the aileron design change? I thought it was 1965?
With PC in 65. Mine was retrofitted in 65 when the added PC.
