merrja Posted October 1, 2018 Report Share Posted October 1, 2018 Hi All, I'm looking to upgrade my Attitude indicaotr to an electric AI, any suggestions? (I don't have a certified gps on my plane). Thanks! Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted October 1, 2018 Report Share Posted October 1, 2018 G5 1 Quote Link to comment Share on other sites More sharing options...
Skates97 Posted October 1, 2018 Report Share Posted October 1, 2018 These are not approved yet and they are saying Mid 2019, but I really like the look of them. https://aerovonics.com/av-30 1 Quote Link to comment Share on other sites More sharing options...
MB65E Posted October 1, 2018 Report Share Posted October 1, 2018 The Founder of Aerovonics responded to a few emails. Looks promising. $1500 certified! -Matt Quote Link to comment Share on other sites More sharing options...
McMooney Posted October 1, 2018 Report Share Posted October 1, 2018 Man I would order one of those today. Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted October 1, 2018 Report Share Posted October 1, 2018 Merrja You wrote “electric AI” but we all assume you mean Electronic with no moving parts. I certainly agree that you don’t want another spinning mechanical gyro. If you’re really seeking only an AI a used RCA2600-3 is good. Examples have been offered on the used market for around $1500. But for “only” twice as much you can get a new G5 with lots more capabilities. Quote Link to comment Share on other sites More sharing options...
merrja Posted October 1, 2018 Author Report Share Posted October 1, 2018 Thanks very much for all the input! New G5 is on the way! 3 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted October 1, 2018 Report Share Posted October 1, 2018 FYI the g5 requires a gps source for stc certification. It’s used to correct drift internally. -Robert 1 Quote Link to comment Share on other sites More sharing options...
merrja Posted October 1, 2018 Author Report Share Posted October 1, 2018 I also purchased the Garmin Wass Antenna, so I guess the garmin transponder will be my next purchase for the ADSB compliance Quote Link to comment Share on other sites More sharing options...
MIm20c Posted October 1, 2018 Report Share Posted October 1, 2018 3 minutes ago, merrja said: I also purchased the Garmin Wass Antenna, so I guess the garmin transponder will be my next purchase for the ADSB compliance Leave the antenna cable long enough to reach the future adsb transponder. Later on the g5 can use the position source from the transponder and you won’t need another waas speed brake on the top of your plane. 1 Quote Link to comment Share on other sites More sharing options...
merrja Posted October 1, 2018 Author Report Share Posted October 1, 2018 Thanks Mlm! Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted October 1, 2018 Report Share Posted October 1, 2018 FYI the g5 requires a gps source for stc certification. It’s used to correct drift internally. -Robert It has an internal one, antenna maybe required, don’t know if stc allows it. Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted October 2, 2018 Report Share Posted October 2, 2018 3 hours ago, teejayevans said: It has an internal one, antenna maybe required, don’t know if stc allows it. External antenna is required unless you have a gps source for jt. So if you don’t you need to wire up an antenna -Robert Quote Link to comment Share on other sites More sharing options...
jetdriven Posted October 2, 2018 Report Share Posted October 2, 2018 Run 2 cables to the ceiling so when you get a GPS later you don’t have to pull all the interior out to do it again Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted October 2, 2018 Report Share Posted October 2, 2018 5 hours ago, jetdriven said: Run 2 cables to the ceiling so when you get a GPS later you don’t have to pull all the interior out to do it again You only need one. If you wire an antenna for the g5 today if you get a gps later you can unplug it from the g5 and plug it into the gps. Then run a data line from the gps to the g5. -Robert 1 Quote Link to comment Share on other sites More sharing options...
