Keith20EH Posted September 29, 2018 Report Share Posted September 29, 2018 Hello, I heard there is an stc available to remove the cooling shroud (aka Doghouse) that covers the top of the engine on an M20E. Does anyone have experience with this, and is it worth it? From a maintenance perspective, it sure is annoying to have to remove this shroud every time I want to work on the engine. My cylinder temps run on the cool side anyway. Thanks for any info regarding this. Quote Link to comment Share on other sites More sharing options...
takair Posted September 29, 2018 Report Share Posted September 29, 2018 10 minutes ago, Keith20EH said: Hello, I heard there is an stc available to remove the cooling shroud (aka Doghouse) that covers the top of the engine on an M20E. Does anyone have experience with this, and is it worth it? From a maintenance perspective, it sure is annoying to have to remove this shroud every time I want to work on the engine. My cylinder temps run on the cool side anyway. Thanks for any info regarding this. Hi Kieth, There are a couple of threads floating around right now. Not aware of an STC at the moment but would be interested as well. I find myself rebuilding every 500 hours. I’m curious, what year is your E? I thought only the 64 Es had the doghouse. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted September 29, 2018 Report Share Posted September 29, 2018 65 E's have a dog house, or at least mine does Quote Link to comment Share on other sites More sharing options...
takair Posted September 29, 2018 Report Share Posted September 29, 2018 23 minutes ago, RLCarter said: 65 E's have a dog house, or at least mine does Thanks, trying to figure out what year they went to baffles on the E model.....’66 anybody? Quote Link to comment Share on other sites More sharing options...
Hank Posted September 29, 2018 Report Share Posted September 29, 2018 Cs kept them right tomthe bitter end, 77 or 78 . . . . But Es didn't last that long, I don't think. Quote Link to comment Share on other sites More sharing options...
Keith20EH Posted September 29, 2018 Author Report Share Posted September 29, 2018 Mine is a ‘66 M20E and want to remove it, I will keep digging and let you know if I find this stc. Quote Link to comment Share on other sites More sharing options...
MyNameIsNobody Posted September 29, 2018 Report Share Posted September 29, 2018 My ‘66 E has doghouse. ZERO temp issues with engine. My A&P services/maintains engine and doghouse. I would be interested in Sabre Cowl with relocation of oil cooler/elimination of Ram Air/Relocation of Air Filter IF/WHEN the hint of oil temp issues are resolved and speed increase documented. Aesthetically it is a home run. They are working through “issues” on “first up” prototypes. I am confident that in final iteration it will be: Better looking/Faster/as cool as OEM. Sabre is NOT a “full-time” Mod guy. He is a dabbler doing overtime. He gets mad at me for challenging the concept (I do it out of love and hope for perfection) which I understand because he is not doing this full time...I am a believer that THIS is the ultimate way to mod a vintage Mooney and “lose” the doghouse and additional exterior drag... Check it out. Quote Link to comment Share on other sites More sharing options...
takair Posted September 29, 2018 Report Share Posted September 29, 2018 10 hours ago, Keith20EH said: Mine is a ‘66 M20E and want to remove it, I will keep digging and let you know if I find this stc. FAA website lists all STCs by model, don’t think I ever saw this, but it’s worth a look. So, we have ‘64 through at least ‘66. Wonder if they were all the same, I know the cowls are different. Oh, I too am looking forward to see the Sabre cowl, should be a good alternative. Quote Link to comment Share on other sites More sharing options...
Sabremech Posted September 29, 2018 Report Share Posted September 29, 2018 7 hours ago, MyNameIsNobody said: My ‘66 E has doghouse. ZERO temp issues with engine. My A&P services/maintains engine and doghouse. I would be interested in Sabre Cowl with relocation of oil cooler/elimination of Ram Air/Relocation of Air Filter IF/WHEN the hint of oil temp issues are resolved and speed increase documented. Aesthetically it is a home run. They are working through “issues” on “first up” prototypes. I am confident that in final iteration it will be: Better looking/Faster/as cool as OEM. Sabre is NOT a “full-time” Mod guy. He is a dabbler doing overtime. He gets mad at me for challenging the concept (I do it out of love and hope for perfection) which I understand because he is not doing this full time...I am a believer that THIS is the ultimate way to mod a vintage Mooney and “lose” the doghouse and additional exterior drag... Check it out. Issues have been resolved. Oil temp problem was on the airplane for quite some time before the mod and didn’t change because of my mod. The speed increases have been documented and verified on 2 of the four airplanes I’ve modified with the Gen 1 cowling mod. The new Gen 2 cowling which is a completely new cowling has been finalized and the prototype being built. It will fit from a J model and back. I’m not aware of an STC to remove the doghouse, but you could easily install baffling from a later model E that doesn’t have a doghouse. David 2 Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted September 29, 2018 Report Share Posted September 29, 2018 I see the doghouse is not universally loved, but I really like mine. Flying in the ATL area, my engine/oil temps are never a problem even on the hotest day. On my C, the cowl flaps are fixed, so I don'thave to futz with them. When I bought my C, the doghouse had some cracks which were easily repaired. Having the prop balanced stopped the doghouse craking issue. At a previous Mooney summit, I asked Bob Kromer why the doghouse was discontinued. He indicated that it was a cost saving measure...not that it didn't do a good job of keeping the engine cool. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2018 Report Share Posted September 30, 2018 It would appear that standing baffles started in 1967. Clarence Quote Link to comment Share on other sites More sharing options...
Hank Posted September 30, 2018 Report Share Posted September 30, 2018 3 hours ago, M20Doc said: It would appear that standing baffles started in 1967. On some models. Right abive is a 1974 C with a doghouse, and my 1970 C also has one . . . . Quote Link to comment Share on other sites More sharing options...
Keith20EH Posted September 30, 2018 Author Report Share Posted September 30, 2018 Thanks all, looks like I could upgrade this to a new model as a minor alteration. Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted April 15, 2021 Report Share Posted April 15, 2021 On 9/30/2018 at 7:20 AM, Keith20EH said: Thanks all, looks like I could upgrade this to a new model as a minor alteration. Keith did you do it? Quote Link to comment Share on other sites More sharing options...
Keith20EH Posted April 16, 2021 Author Report Share Posted April 16, 2021 Not yet, it has been easier to fix the cracked pieces than start over, at least for now.. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 16, 2021 Report Share Posted April 16, 2021 I’ve got a complete set of standing baffles, if anyone is interested. Clarence Quote Link to comment Share on other sites More sharing options...
