cliffy Posted August 15, 2019 Report Share Posted August 15, 2019 With two magnetos you need to ground the one for starting Get the bar and install it 1 Quote Link to comment Share on other sites More sharing options...
jkarch Posted August 15, 2019 Report Share Posted August 15, 2019 Where do I get that bar from? Right now all I have is a jumper. It’s basically busbar material but the link distance is custom right? There’s no PN for that which is why I have a short 16 AWG wire link between two pidg lugs. Quote Link to comment Share on other sites More sharing options...
cliffy Posted August 15, 2019 Report Share Posted August 15, 2019 You can probably call any magneto repair shop and order it but the wire jumper should work just fine if it is made well and secure. 1 1 Quote Link to comment Share on other sites More sharing options...
jkarch Posted August 15, 2019 Report Share Posted August 15, 2019 You’d be surprised how hard these things are to find but that wire jumper is pretty solid! Quote Link to comment Share on other sites More sharing options...
EricJ Posted August 15, 2019 Report Share Posted August 15, 2019 The wire jumper will do the same job. 1 Quote Link to comment Share on other sites More sharing options...
McMooney Posted August 15, 2019 Report Share Posted August 15, 2019 On 9/22/2018 at 8:32 PM, LANCECASPER said: Before I spent $500 for a new switch I would be tempted to get an EA-15000. http://electroair.net/switchPanel.html think this'll work with a surefly? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 15, 2019 Report Share Posted August 15, 2019 10 hours ago, cliffy said: With two magnetos you need to ground the one for starting Get the bar and install it Unless the engine has dual impulse couplings. Clarence Quote Link to comment Share on other sites More sharing options...
cliffy Posted August 15, 2019 Report Share Posted August 15, 2019 3 hours ago, M20Doc said: Unless the engine has dual impulse couplings. Clarence Do any Mooneys have dual impulse couplings? :-) I've never seen one. Quote Link to comment Share on other sites More sharing options...
EricJ Posted August 15, 2019 Report Share Posted August 15, 2019 1 hour ago, cliffy said: Do any Mooneys have dual impulse couplings? :-) I've never seen one. One of the advantages of the dual mag (D) is that the impulse coupler can drive both sides. I think this is where the rewiring issues with the ignition switch come from. Quote Link to comment Share on other sites More sharing options...
