Rookie Posted September 10, 2018 Report Share Posted September 10, 2018 Is there any scientific way of adjusting our landing lights (while the plane is on the ground) so the runway is in sight after round out and Flair? Yes I still have old halogen light but if a LED is not pointed at the correct angle it's no better. I do plan on getting a LED at annual but I'd like to repair this asap. Thanks, Quote Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2018 Report Share Posted September 10, 2018 Many light installations have 3 aiming screws on the back side in the engine cowls. Open your cowl flaps, disconnect the quick coupler to allow the flap to open even wider. You should see the screws. Line the plane up on a taxiway in the dark and adjust till you’re happy. Clarence Quote Link to comment Share on other sites More sharing options...
larrynimmo Posted September 13, 2018 Report Share Posted September 13, 2018 with me it was easy....aim the light as low as I could, and it was still a little too high....but acceptable 1 Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted September 13, 2018 Report Share Posted September 13, 2018 On 9/10/2018 at 8:51 AM, Rookie said: Is there any scientific way of adjusting our landing lights (while the plane is on the ground) so the runway is in sight after round out and Flair? Yes I still have old halogen light but if a LED is not pointed at the correct angle it's no better. I do plan on getting a LED at annual but I'd like to repair this asap. Thanks, If you have a J, the three aiming screws are accessible without taking off the cowl. Disconnect the right cowl flap, and reach up with a stubby phillips screwdriver to adjust the 3 aiming screws on the landing light ring. It makes sense, though to look at the hardware when you have the cowl off first so you know what you're going for! A reasonable strategy if you have a hangar opposite you and the ground is level is to do it at night or dusk, and just adjust it based on the opposite hangar door. Mark off where your tires are. Even a halogen lamp should only run 6 amps, so you should have plenty of battery and time to adjust it. Then take a picture of the opposite hangar door (probably more acceptable than marking on your neighbor's hangar door) and go fly. Based on what you see, you'll know what direction to adjust the beam once you put the tires back in the same place and review the photo. Edit: Oooh, now that I think about it, I'm not sure if the adjustment screws need a phillips or flat screwdriver... 1 Quote Link to comment Share on other sites More sharing options...
amillet Posted September 14, 2018 Report Share Posted September 14, 2018 I believe the maintence manual has specs for aiming. I made marks on the inside of my hangar doors (my lights are in the wings) Quote Link to comment Share on other sites More sharing options...
