defrkm20j Posted April 27, 2009 Report Share Posted April 27, 2009 Hi fellow Mooniacs, here is the question of the day. Does anyone know if the Intrument Panel in A M20J has a tilt and if it does how many degrees. We just installed a electr. artificial horizon from Castleberry which after a longer level flight turns to a pitch down attitude. The manufacturer claims this has something to do wit a tilt. Anyone knows something ? Zhx Axel Quote Link to comment Share on other sites More sharing options...
67M20F Posted April 27, 2009 Report Share Posted April 27, 2009 Call my friend Kerry, he has a shop in EVW and has an STC for an flat panel for mooneys, 307-789-6866 Great mooney guy, he works on others but knows alot about mooneys. I seen a F model that he put the panel in its very nice. Quote Link to comment Share on other sites More sharing options...
defrkm20j Posted April 28, 2009 Author Report Share Posted April 28, 2009 Thx, for the hint Axel Quote Link to comment Share on other sites More sharing options...
alun Posted August 23, 2009 Report Share Posted August 23, 2009 did you ever get an answer. i was wondering as i have a constant slip shown on my aspen and wandered if it was as a result of panel tilt? Quote Link to comment Share on other sites More sharing options...
Piloto Posted August 23, 2009 Report Share Posted August 23, 2009 I am not aware of any panel tilt angle on the M20J or later models. Instrument pitch angle tilt can be adjusted by adding washers at the mounting screws. For roll angle tilt you can enlarge the panel mounting holes slightly and adjust the instrument. José Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2009 Report Share Posted August 23, 2009 I believe the J has zero tilt in the vertical plane, assuming everything is still "square" with the world and the panel hasn't been monkeyed with at some point in the past. Alun, if you have a constant slip shown, I would suggest you get the rigging checked. (I presume you're talking about in flight, correct?) It could be that your plane is flying slightly crooked in cruise and indicates a slip. Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2009 Report Share Posted August 23, 2009 Oh, I forgot to mention...if you and/or your mechanic don't have access to the rigging boards, you can check the installation of the Aspen (or any TC) by jacking up the plane and leveling it per the maintenance manual. Once you get it completely level (front-to-back and wingtip-to-wingtip) then check the slip/skid indicator and the ball should be centered. I'm not sure how the Aspen displays, it though. If the instrument shows a slip, then you have a mounting problem with either the instrument or the entire panel. Quote Link to comment Share on other sites More sharing options...
defrkm20j Posted August 25, 2009 Author Report Share Posted August 25, 2009 Yes I got the answer. Panel tilt on the J is 0 Axel Quote Link to comment Share on other sites More sharing options...
