BushPilot Posted August 29, 2018 Report Share Posted August 29, 2018 Looking to give an M20J a good home! The "Needs" 1978 or newer No Damage History no corrosion Recently overhauled engine/ Midtime engine (flown frequently)/ Run out engine (priced accordingly) IFR certification 430w 4 place intercom no fuel leaks complete logs >900lb useful load all ADs and especially SB208 complied with autopilot with alt hold hangared most of its life The Wants 1982 or newer A3B6 new prop: scimitar or top prop fuel bladders 530w Or GTN 650/750 stec autopilot gpss graphic engine monitor adsb garmin G5 or aspen PFD/HSI intercom w/music >1000lb useful load The Buyer Professional pilot/ATP Family man Perfectionist Hangar standing by Financing-ready to close a deal! Lets make it happen. email: Nbushpilot@gmail.com phone: (218) 242-0312 Thanks for reading! Quote Link to comment Share on other sites More sharing options...
Stryker Posted August 30, 2018 Report Share Posted August 30, 2018 (edited) 1981 MOONEY M20J 201 Edited August 30, 2018 by Stryker Quote Link to comment Share on other sites More sharing options...
BushPilot Posted August 30, 2018 Author Report Share Posted August 30, 2018 41 minutes ago, Stryker said: 1981 MOONEY M20J 201 I like this aircraft over all. However, the rust on the control shaft (Not sure the technical term for the steel shaft the yoke mounts to.) concerns me. I am worried the airframe may have many other parts that also have surface rust or worse. Thank you for sharing the link however! Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted August 30, 2018 Report Share Posted August 30, 2018 If Skywaggons would allow you to take the plane to TopGun for an inspection, it might be worth it. But they're not known for being friendly towards that idea. Since it's got all the right stuff... it might not be hard to get someone from this forum to go by and take a look at it and get a bunch of pictures that you could then run by (for a small fee) an MSC who knows what's critical and whats not. That might give you the info you'd need to pursue a proper inspection or pass on the plane. Quote Link to comment Share on other sites More sharing options...
BushPilot Posted August 30, 2018 Author Report Share Posted August 30, 2018 The high compression engine is the nail in the coffin for me... I would never trade reliability for performance for a family hauler. I may need some help looking in the future though! That is a great idea! Quote Link to comment Share on other sites More sharing options...
SD Flyer Posted September 8, 2018 Report Share Posted September 8, 2018 On 8/30/2018 at 9:40 AM, Stryker said: 1981 MOONEY M20J 201 This one has rust on every not painted iron part including all screws, bolts and nuts. If it came from SoCal, like Skywagon states - it was stored underwater. 1 Quote Link to comment Share on other sites More sharing options...
MB65E Posted September 8, 2018 Report Share Posted September 8, 2018 Didn’t know H/C pistons were legal? It’s already a fairly stout engine. -Matt Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted September 8, 2018 Report Share Posted September 8, 2018 On 8/30/2018 at 1:22 PM, BushPilot said: I like this aircraft over all. However, the rust on the control shaft (Not sure the technical term for the steel shaft the yoke mounts to.) concerns me. I am worried the airframe may have many other parts that also have surface rust or worse. Thank you for sharing the link however! My '83 J also has the rust, but what is interesting is the portion of the shaft that is behind the panel does not. It's only on the surface and I use a compound that somebody here recommended which instantly removes it and restores the chrome shine. The "rubdown" lasts about six months at which time the rust returns and I apply the solution again. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 8, 2018 Report Share Posted September 8, 2018 4 hours ago, MB65E said: Didn’t know H/C pistons were legal? It’s already a fairly stout engine. -Matt We have somebody here that just recently searched for and added 10:1 CR pistons to his J, and has done a fair amount of writing about the experience... Search for Firewall Forward STC... nice detailed list, Bushpilot! That will help you to get where you want to go. Where are you located? Best regards, -a- 1 Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted September 8, 2018 Report Share Posted September 8, 2018 If high compression pistons were bad why would they be used regularly on piston helicopters? Quote Link to comment Share on other sites More sharing options...
BushPilot Posted September 9, 2018 Author Report Share Posted September 9, 2018 4 hours ago, carusoam said: We have somebody here that just recently searched for and added 10:1 CR pistons to his J, and has done a fair amount of writing about the experience... Search for Firewall Forward STC... nice detailed list, Bushpilot! That will help you to get where you want to go. Where are you located? Best regards, -a- Thank you! I am in northern MN. This has been a great learnings experience and I appreciate all the feedback that people have given. Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 9, 2018 Report Share Posted September 9, 2018 4 hours ago, aviatoreb said: If high compression pistons were bad why would they be used regularly on piston helicopters? I think we would want to look up how long the cylinders last in the helicopter application... and what an acceptable limit is for them. It won’t tell us anything about the life expectancy of the same set-up in a Mooney because the environment is completely different... so I looked up the piston heli(s) i’m kinda Familiar with... Robinson R22 and R44... Robinson derates the O360 and O540 significantly.... no mention of high compression pistons.... The O540 only uses 185hp continuous... pretty far from the 260+ the Bravo has available from the IO version... From the pictures you can see a very large cooling fan mounted above the cylinders.... https://robinsonheli.com/wp-content/uploads/2016/12/r44_cadet_brochure.pdf the challenge with high compression ratios is the amount of heat generated inside the same cylinders... A similar challenge for those running 25°BTDC timing... in some parts of the world, this isn’t a problem at all. In other parts of the world a decent engine monitor takes care of a big part of the challenge.... Overall, CHT control keeps the cylinders living longer... Cold winter air may also be important to keep an eye on. super negative DAs may be more important in this set-up. More Pp thoughts only, -a- 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 9, 2018 Report Share Posted September 9, 2018 Sorry BushPilot, i’ve Made a mess of your thread... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
BushPilot Posted September 9, 2018 Author Report Share Posted September 9, 2018 8 hours ago, carusoam said: Sorry BushPilot, i’ve Made a mess of your thread... Best regards, -a- Haha no worries. 2 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted September 10, 2018 Report Share Posted September 10, 2018 On 9/8/2018 at 8:43 PM, BushPilot said: Thank you! I am in northern MN. This has been a great learnings experience and I appreciate all the feedback that people have given. Do you ever fly into KGPZ? I grew up there. Quote Link to comment Share on other sites More sharing options...
BushPilot Posted September 11, 2018 Author Report Share Posted September 11, 2018 Several times. I have a good friend who is currently based there. 1 hour ago, LANCECASPER said: Do you ever fly into KGPZ? I grew up there. Quote Link to comment Share on other sites More sharing options...
SAMFOX Posted November 10, 2018 Report Share Posted November 10, 2018 @BushPilot ever find that J?!? Quote Link to comment Share on other sites More sharing options...
Mcstealth Posted November 12, 2018 Report Share Posted November 12, 2018 On 11/10/2018 at 2:44 PM, SAMFOX said: @BushPilot ever find that J?!? Nice Icon 1 Quote Link to comment Share on other sites More sharing options...
SAMFOX Posted November 15, 2018 Report Share Posted November 15, 2018 https://www.controller.com/listings/aircraft/for-sale/29182725/1997-mooney-m20j?dlr=1&pcid=1295132&crmid=5248113&if=1 1 Quote Link to comment Share on other sites More sharing options...
