flyboy0681 Posted August 25, 2018 Report Share Posted August 25, 2018 The original Hoskins strobe on the right wing flashes once for every six flashes of the left strobe. The ratio is always 1:6. What are the possible causes? Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted August 25, 2018 Author Report Share Posted August 25, 2018 Everything is original, including the Hoskins power supply. Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted August 25, 2018 Author Report Share Posted August 25, 2018 2 minutes ago, bluehighwayflyer said: Both power supplies are OEM Hoskins? There are two of them. One in each wingtip. Is the yellow wire connecting them? On my J at least Mooney left the yellow sync wire disconnected. I haven't physically inspected it, just saying that they weren't replaced with a newer product. Next time I'm in the hangar I'll check it out. Quote Link to comment Share on other sites More sharing options...
Andy95W Posted August 26, 2018 Report Share Posted August 26, 2018 It sounds like the capacitors in the power supply are starting to degrade. Maybe try swapping power supplies left to right and see if the fault follows. 1 Quote Link to comment Share on other sites More sharing options...
bradp Posted August 27, 2018 Report Share Posted August 27, 2018 Andy's right - it's the capacitors starting to go. Your options are to research the capacitor and get out your soldering.iron, replace with another power supply (I have a working whelen from ~2012 mfr that I can sell you if you need one - there are a couple of people on the forum that have working replacements - I'd caution looking for a used one on Ebay as most of them are probably junk), or bite the bullet and replace with an LED strobe. Hope this helps, Brad Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted August 27, 2018 Author Report Share Posted August 27, 2018 A replacement set seems to be in my future. What's another 1 AMU. 1 Quote Link to comment Share on other sites More sharing options...
OR75 Posted August 27, 2018 Report Share Posted August 27, 2018 i have a spare Hoskins power supply i could sell Quote Link to comment Share on other sites More sharing options...
kortopates Posted August 28, 2018 Report Share Posted August 28, 2018 Best excuse you'll get to replace with Whelen Orion's! 2 Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted August 29, 2018 Report Share Posted August 29, 2018 Absolutely. :-) Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted August 29, 2018 Report Share Posted August 29, 2018 I just last week pulled out the original Whelen strobe/ incandescent assemblies and put in the Orion 600 LED wing tip light replacements. They do look sleek. Lower current, 3 pounds lighter. Yep, 1 AMU. 1 Quote Link to comment Share on other sites More sharing options...
