Prior owner Posted August 14, 2018 Report Share Posted August 14, 2018 Sorry guys, I accidentally deleted the entire thread while trying to delete a draft response that got all messed up...whoops! I had no idea that I had the authority to do that! Feeling dumb, yet important. Maybe I should run for office. 1 1 Quote Link to comment Share on other sites More sharing options...
David Lloyd Posted August 14, 2018 Report Share Posted August 14, 2018 Nope, better not run for office. You admitted making a mistake! 2 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted August 14, 2018 Report Share Posted August 14, 2018 RE: the 13 year old shock discs, if they've been stored inside under temperature control I'd be willing to go with them. 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted August 15, 2018 Report Share Posted August 15, 2018 2 hours ago, LANCECASPER said: RE: the 13 year old shock discs, if they've been stored inside under temperature control I'd be willing to go with them. +1, if the rubber is playable (fingernail test) I'd install them Quote Link to comment Share on other sites More sharing options...
Prior owner Posted August 15, 2018 Author Report Share Posted August 15, 2018 Thank you everyone for your responses! Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 16, 2018 Report Share Posted August 16, 2018 Did you really have the old firestone donuts? There may be a requirement for some parts for the conversion to Lord donuts... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Prior owner Posted August 16, 2018 Author Report Share Posted August 16, 2018 11 hours ago, carusoam said: Did you really have the old firestone donuts? There may be a requirement for some parts for the conversion to Lord donuts... Best regards, -a- Yes, I really still have the Firestones. I have seen other planes for sale recently that also have them.... I am doing the conversion per Mooney’s instructions, which does require quite a few new parts if you’re going to follow the instructions to the letter. It is not a cheap conversion. 1 Quote Link to comment Share on other sites More sharing options...
drapo Posted August 16, 2018 Report Share Posted August 16, 2018 2 hours ago, PilotCoyote said: Yes, I really still have the Firestones. I have seen other planes for sale recently that also have them.... I am doing the conversion per Mooney’s instructions, which does require quite a few new parts if you’re going to follow the instructions to the letter. It is not a cheap conversion. Just went through the conversion on both mains myself. Hardware : $1200, Pucks (8): $1000, Labor $500, The new ride....Priceless! 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted August 17, 2018 Report Share Posted August 17, 2018 4 hours ago, PilotCoyote said: Yes, I really still have the Firestones. I have seen other planes for sale recently that also have them.... I am doing the conversion per Mooney’s instructions, which does require quite a few new parts if you’re going to follow the instructions to the letter. It is not a cheap conversion. The kit through Mooney is wildly spendy, give LASAR a call, they had everything in stock when I did mine a few years ago Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 17, 2018 Report Share Posted August 17, 2018 Great pics, Drapo! the rubber discs all start out cylindrical in shape. Over time they compress and flow outwards. Enough that is kind of visible in the picture... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Prior owner Posted August 17, 2018 Author Report Share Posted August 17, 2018 (edited) LASAR is out of the PMA later style shock links until end of the year.... so it’s either Mooney $$$ links or a serviceable used set. I have been told that you can use all of your original hardware, including the shock links by flipping the top spacer and moving it to the bottom of the shock link, but I didn’t want to do it that way. Edited August 17, 2018 by PilotCoyote Quote Link to comment Share on other sites More sharing options...
carusoam Posted August 18, 2018 Report Share Posted August 18, 2018 There are a few resources of used proper parts if you are interested...? watch for how worn these parts may be... Contact. @acpartswhse and the grim reaper @Alan Fox Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted August 18, 2018 Report Share Posted August 18, 2018 23 hours ago, PilotCoyote said: LASAR is out of the PMA later style shock links until end of the year.... so it’s either Mooney $$$ links or a serviceable used set. I have been told that you can use all of your original hardware, including the shock links by flipping the top spacer and moving it to the bottom of the shock link, but I didn’t want to do it that way. Or spruce , or any other company that sells Lord products.. Quote Link to comment Share on other sites More sharing options...
Prior owner Posted August 20, 2018 Author Report Share Posted August 20, 2018 (edited) Thanks again Alan for making this conversion more afforable! Edited August 20, 2018 by PilotCoyote Quote Link to comment Share on other sites More sharing options...
Jerry Pressley Posted August 21, 2018 Report Share Posted August 21, 2018 Have a nice set from a low time 201. as usual everything is guaranteed to pass your close inspection. you price them. Jerry 423 231 3491 best source for anything new is Don Maxwell. Quick and most reasonable of the Mooney service centers. 903-643-9902 Quote Link to comment Share on other sites More sharing options...
