Sentry or Stratus ADS-B In
bill98
This weird phenomenon know as rain finally came back to DFW this weekend.
I want a portable ADS-B in solution by the end of the week.
Thoughts on the Sentry and Thoughts of the Stratus 3.
(If someone knows of a good deal let me know)!
i know the Stratus 3 is being offered with “$200 off”
the sentry intrigues me though. Plus the new tail beacon ADS-B looks kind of cool.
@gsxrpilot this will help me navigate down to Bastrop to say hello and buy you some beer for all your help!
Link to comment
Share on other sites
If you act fast, Seattle Avionics still has an Oshkosh price on their Merlin.  I've been using it for a year coupled to FlyQ, and it works great.  Stratus-like performance at a fraction of the price.  Currently the Merlin dual-channel battery-powered ADS-B, WAAS GPS, AHRS receiver is $199.99 + $14.95 US shipping and handling.
Link to comment
Merlin is just someone else assembling a stratux unit for you; which if you’re not handy is a great deal.
-Robert
Link to comment
I have a buddy with the StratuX. He is constantly rebooting it and seems to never lock on the first time and is too “project” to save a $100 or $200 on the better designed Stratus and Sentry all in one units.
All accounts show them to work very well but. I am thinking about one as a backup to my GTX 345 which gives me the awesome ADS-B in. I would go with the newer Sentry as the AHRS seems cool to have but just doesn’t justify it for me having used it.
Link to comment
Something seems odd there. I have over 200 hours with my Stratux and have had it twice stop sending out the wifi signal because the SD card got corrupted. After the first time I started carrying a spare card with the image loaded on it so I could just swap it out which only takes a couple of minutes. Reformatting and reloading the image is easy to do as well to repair the bad card for the next time it's needed. (In fairness to the system if I took the time to shut it down with the app instead of just turning off the power to it I probably wouldn't have it getting corrupted.)
I've never had it reboot or fail to lock on.
Link to comment
I hear you, something is wrong, but for the headache he has had and the cost difference I’d rather have the Sentry with all the features and a CO monitor; it is also supported by a company that I can call or replace if it is broken or doesn’t work as advertised or supposed to instead of remoting into the device to reinstall firmware.
Link to comment
Bought a Sentry a couple weeks ago before we picked up our plane. Very pleased with it, and has a great price. Its small, comes with a Ram suction mount, and charging cord. Uses WiFi, and works flawlessly with ForeFlight. You can connect up to 5 devices at the same time. Will work on iPhone, but Synthetic Vision part only works on the iPad version of FF.
Link to comment
  • 8 months later...
11 hours ago, Hyett6420 said:
STOP PRESS
The UK is waking up and is trialing ADS-B as a situation aware source and appears to be trialling weather on the UAT link as well (well in southern UK where i am anyway.).
So now I can buy USA products like the Stratus 3 and get ADSB in and weather.  I am about to move to foreflight as well as they now have CAA charts on there.
My only concern is how does the Stratus charge, as your mains power is different to ours.  Does it use USB like most of these devices?
Thanks in advance.
Andrew
I believe all Stratus use USB C.  I don’t bother to charge my Stratus II in the air because the battery life exceeds my needs many times over. They claim 8 hrs and I’d bet that’s conservative.
Edited by Shadrach
Link to comment
It uses a USB C cable, the plug that comes with it is rated 110-240V so with an adapter you can plug it in there in the UK.
Link to comment
12 hours ago, Hyett6420 said:
STOP PRESS
Thanks in advance.
Andrew
Wow!  I didn't think any other country would consider using the UAT concept...
Have fun!
P.S.  Don't forget the Stratux as a cheaper alternative.  about $200 and you're up and running...
Link to comment
Have fun!
Yep, been using my Stratux for a couple of years now and very happy with it, and the price tag. I think it cost me about $120 in parts to build it back then.
Link to comment
14 hours ago, Hyett6420 said:
STOP PRESS
Thanks in advance.
Andrew
Andrew:  I would love a PIREP on how your Stratus/Stratux/Sentry receives the space-based ADS-B signals.  We are about to have one of our Flight Information Regions here Canada go live with it.
Link to comment
12 minutes ago, Ned Gravel said:
FWIW:  I had a Stratus 2 and I sold it for the Sentry.  Time was ripe to buy the Stratus 3, but the Sentry has a smaller footprint on my side window - so that is the one I got.
I'm still quite content with the function of my aging Stratus 2, but maybe ignorance is bliss. Do you notice a major performance improvement with the Sentry?  The CO monitor on the Sentry is nice but not enough to make me switch, so a bought a separate monitor.
Link to comment
I have to imagine for ADS-B In, it has the potential to be better than ground-based transmitters, since most of us put antennas on the glareshield or windows.  On the other hand, for ADS-B Out, it might be more of an issue since most of us have transponder antennas under the plane.
Has anyone heard if the UK is planning on implanting ADS-B In and Out over UAT, or just ADS-B In?  I suspect the latter is more likely
Link to comment
I had Stratux Tablet IN long before putting a 345 in the Mooney.  I used the Stratux in both the Mooney and the Cessna until a couple of months ago until putting a Stratus ESG and 3i in the panel.  I flew both planes a good bit with the Stratux and found it to be quite reliable.  It is so much cheaper than a Stratus I really don’t know how they sell the Stratus for so much more.  Since getting Panel IN in both planes I gave the Stratux to a friend and it has worked perfectly for him.
Link to comment
No change in performance at all.  Both provide good service.  Speed of ForeFlight was determined by the iPad, not the ads ADS-B receiver.  And for that I had to toss my iPad mini 2 for a 4.  Reason for change was to get it further from my head, in the event....  Already have a Sensorcon..
Link to comment
+1 on the Stratux, especially for somebody with an IT pro in the household.   Plus the Raspberry Pi has UK heritage, so there's that...  ;)
Link to comment
or simply buy a commercially assembled Stratux.  I've been using the Merlin, acquired for $199 during their Black Friday intro.  It lists for $250.....https://seattleavionics.com/merlin.aspx
While I know that a few have had issues with this unit, it's works flawlessly for me.  I strongly favor XM weather over ADSB, but that's another issue.
Link to comment
