Aviating2001 Posted July 28, 2018 Report Share Posted July 28, 2018 My 1976 F has a leaking oil cooler. Can anyone suggest a repair shop? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Ron McBride Posted July 28, 2018 Report Share Posted July 28, 2018 Try pacific oil coolers in Pomona CA. I replaced mine several years ago, it was not that much. Ron Quote Link to comment Share on other sites More sharing options...
Don Heene Posted July 28, 2018 Report Share Posted July 28, 2018 You can get them at Aircraft Spruce in Corona. You will need to count how many rows you have. They are not that expensive, I think they're about 400 to 600. Quote Link to comment Share on other sites More sharing options...
b65cuda Posted July 28, 2018 Report Share Posted July 28, 2018 I'd ask your A&P, but I bet it could be repaired at any radiator shop for $40 or so. Quote Link to comment Share on other sites More sharing options...
BKlott Posted July 28, 2018 Report Share Posted July 28, 2018 Not a place where I would want to cut corners. If an oil cooler blows while you’re flying, you have a forced landing in your immediate future. I had one cut loose but I was lucky. It was during a ground run with the cowling off following an oil change. Ran it to check for leaks and brother did we find one. Quote Link to comment Share on other sites More sharing options...
Jim Peace Posted March 26, 2019 Report Share Posted March 26, 2019 On 7/28/2018 at 2:53 PM, BKlott said: Not a place where I would want to cut corners. If an oil cooler blows while you’re flying, you have a forced landing in your immediate future. I had one cut loose but I was lucky. It was during a ground run with the cowling off following an oil change. Ran it to check for leaks and brother did we find one. agree,,,I was just told about some issues with my oil cooler during my annual and replacing with new..... The only thing I can find in my logs is that it was overhauled in 2005 after now has 1000 hours since then....no idea if it is original to plane etc...I am not near the shop to take a picture of it.. Quote Link to comment Share on other sites More sharing options...
MikeOH Posted March 27, 2019 Report Share Posted March 27, 2019 On 7/28/2018 at 7:58 AM, N803RM said: Try pacific oil coolers in Pomona CA. I replaced mine several years ago, it was not that much. Ron Just had mine done there. It's $189 for the clean/flush, but mine needed the flanges welded (crack) which was another $100. Quote Link to comment Share on other sites More sharing options...
Herlihy Brother Posted April 4, 2019 Report Share Posted April 4, 2019 I paid $800 for a new one at aircraft spruce. It was the more expensive one available because it is (meggit) heavier construction. Its still on my shelf awaiting my current one to self destruct but she has a will to live apparently as its been 5 years now. Quote Link to comment Share on other sites More sharing options...
PT20J Posted April 5, 2019 Report Share Posted April 5, 2019 Pacific overhauled mine for $267.92 last fall. Looks like new. Quote Link to comment Share on other sites More sharing options...
