Annual ALL DONE Time to Fly
Vegas?? Really? Southwest Airlines or any other budget carrier will get you to Vegas. Use the Mooney to go places it would be very expensive in airfare or time to get to otherwise.
Our little summer trip before Oshkosh is... Austin to Lincoln, NE to Winnipeg Manitoba, to Churchill Manitoba to International Falls, MN to Iron Mountain, MI to Mackinac Island, MI (where we are now) to Asheville, NC to Savannah, GA then home to Austin. (NC and GA along with Manitoba Canada in the same trip doesn't make much sense :blink:) But it's a Mooney and it doesn't seem so far. Then an oil change and off to Oshkosh.
I can give you some other ideas as well. A tour of the National Parks in California, Oregon, Washington, Montana, Wyoming. (Did that two summers ago). Vermont, New Hampshire, Maine, (last summer).
Mooney's are the best way to go places otherwise not so easy to get to.
Link to comment
Share on other sites
A few pictures from Mackinac Island. Absolutely a gorgeous day.36794380_10156455372370645_7466968220834988032_n.jpg.19576a879b78d96aecec34108c27e3e6.jpg
36753831_10156455371755645_3656450390892740608_n.thumb.jpg.0517303673d6f78405e09176a5ce6f65.jpg
36741677_10156455371680645_3724572536462114816_n.jpg.e5fc8809d6b835b3cfb24f2ded48b91e.jpg
36798346_10156455371465645_3124923191303077888_n.jpg.03f38e914cc0ea32a7d32611c148aa77.jpg
Unfortunately another white and blue M20K 252 landed gear up on the 4th of July. It's sitting on the ramp on it's wheels with curled tips on the prop.
Link to comment
well, I have to say I've been blessed,
the guy who put the plane back together after it's last gear up, is absolutely exceptional.
every mechanic I've taken the plane to comments on how absolutely clean it is.
both annuals were no squawks.  I Only changed the sparkplugs and had an oil change.
seriously, if someone could convince the guy to become a general mooney mechanic, we'd all be better for it.
Link to comment
Most, if not all the islands of Lake Erie have airports.  My last bit of avionics work has been delayed, an M20F geared itself up at the airport I was going to and my mechanic is knee deep in it.  I think I'll keep putting the gear and flaps dow a few miles out.  Slows things down, but all means I'm less likely to gear it up.
G Gear down
U Undercarriage should be down by now
M Make damn good and certain the blasted gear is down!
P Put your stupid hand on the gear switch and make bloody certain its down right now!
S Sure the gear is down?  Are you?
Link to comment
