NotarPilot Posted June 6, 2018 Report Share Posted June 6, 2018 It appears that the lateral deviation scale on the G500 has 4 degree spacing per dot as opposed to 2 degrees per dot on a standard CDI. Can someone confirm this and explain why Garmin did this? Quote Link to comment Share on other sites More sharing options...
201Mooniac Posted June 6, 2018 Report Share Posted June 6, 2018 From the G500/G600 Pilots Guide: The full-scale limits for the CDI are de ned by a GPS-derived distance when coupled to GPS. When coupled to a VOR or localizer (LOC), the CDI has the same angular limits as a mechanical CDI. Quote Link to comment Share on other sites More sharing options...
Bryan Posted June 6, 2018 Report Share Posted June 6, 2018 I was thinking the same thing. In GPS mode the CDI limits are changed by what mode you are in: Enroute, Terminal, Approach I think it should be: Enroute: (+-) 5.0nm or (+-) 2.0nm WAAS Terminal: (+-) 1.0nm Approach: (+-) 0.3nm I am having flashbacks of my IFR testing. Quote Link to comment Share on other sites More sharing options...
NotarPilot Posted June 6, 2018 Author Report Share Posted June 6, 2018 (edited) I’m referring to the marks of degrees of deflection as shown in the comparison below. The G500 only has two dots on each side while a standard HSI has 5 and VOR CDI has 4 on either side of the circle. Edited June 6, 2018 by NotarPilot Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 7, 2018 Report Share Posted June 7, 2018 Great pics, notar... Great question, too... Let’s get the CFII with the all G panel involved... @donkaye I bet Don knows the answer... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
kpaul Posted June 7, 2018 Report Share Posted June 7, 2018 13 hours ago, NotarPilot said: The G500 only has two dots on each side while a standard HSI has 5 and VOR CDI has 4 on either side of the circle. I am not sure there is a "standard" as you have shown in your pictures. All the glass I have flown behind has only had the 2 per side ( half and full scale deflection). The goal is to have it centered, no? or to know when established, 5 degrees on NDB, half scale on VOR, case break on the localizer. Quote Link to comment Share on other sites More sharing options...
Marauder Posted June 7, 2018 Report Share Posted June 7, 2018 I am not sure there is a "standard" as you have shown in your pictures. All the glass I have flown behind has only had the 2 per side ( half and full scale deflection). The goal is to have it centered, no? or to know when established, 5 degrees on NDB, half scale on VOR, case break on the localizer. Yeah, I never really paid much attention to the dots on my Aspens but I have 4 dots for either GPS or ILS approaches. The AI in this picture also shows the 4 dots in the horizontal and vertical course indicators. Quote Link to comment Share on other sites More sharing options...
PTK Posted June 7, 2018 Report Share Posted June 7, 2018 What's important is the sensitivity and the nav source i.e. GPS or VLOC, not the number of dots or circles. The sensitivity changes depending on segment of the flight. Enroute, terminal or approach. For example with GPS as the source the Enroute (ENR) sensitivity is 5 nm full deflection or 2.5 nm per circle. For terminal area (TERM) which I believe iirc is a radius between 2 and 30 nm from airport the sensitivity is 1 nm full deflection or 0.5 nm per circle. On approach within 2 nm radius of FAF the sensitivity becomes 0.3 nm in full deflection. Quote Link to comment Share on other sites More sharing options...
