ShuRugal Posted May 25, 2018 Report Share Posted May 25, 2018 Fun day... started my takeoff roll, noticed ASI wasn't moving... continued to rotate speed, wheels off the ground (4,500' of a 5,000' runway in front of me still) the needle jumped a bit and started moving... decided to err on the side of caution, aborted the takeoff and returned to the ramp. Mechanic put the pitot-static tester on it, and airspeed is all over the place: first test was 100 mph, reading 105, second test for 100, reading 80, test for 80, read 60, test 100 again, read 100.... I'm hoping that these symptoms are indicative of water in the system - had thunderstorms all last week and most of this week, and the thing was fine when I last flew it on the 14th... The shop is gonna look at it in more detail Tuesday - fingers crossed for a simple problem... 2 Quote Link to comment Share on other sites More sharing options...
steingar Posted May 25, 2018 Report Share Posted May 25, 2018 Had the same thing once. Got bugs in the pitot static system. Congrats on breaking the accident chain. 2 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted May 25, 2018 Report Share Posted May 25, 2018 Did you push the drain buttons a few times (one just below the pilot side leading edge of the wing, inner. the other under the battery box)? -Robert Quote Link to comment Share on other sites More sharing options...
ShuRugal Posted May 25, 2018 Author Report Share Posted May 25, 2018 Did you push the drain buttons a few times (one just below the pilot side leading edge of the wing, inner. the other under the battery box)? -Robert Mine hasn't got those buttons, unfortunately. 64 model. Lines are gonna have to be opened.Sent from my Pixel using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted May 26, 2018 Report Share Posted May 26, 2018 Congrats on the wise decision. Thanks for posting it. The static line... you probably have the dead leg, in the back... Not sure how to drain the Pitot system... without a button. That is in the front of the pilot side wing, near the fuselage... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 26, 2018 Report Share Posted May 26, 2018 (edited) Good job. Landing with a dead ASI is disturbing. Edited May 26, 2018 by N201MKTurbo Quote Link to comment Share on other sites More sharing options...
Stephen Posted May 26, 2018 Report Share Posted May 26, 2018 12 hours ago, N201MKTurbo said: Good job. Landing with a dead ASI is disturbing. Definately, but if forced, Pitch plus Power equals Performance. ... an AoA wouldn’t suck in that situation either. Quote Link to comment Share on other sites More sharing options...
Yetti Posted May 26, 2018 Report Share Posted May 26, 2018 You might have an alt static valve under the panel by your left knee. If you have the drain by the battery, there is a connector that can be taken off by a qualified person and then block one static port and blow the water out the static port. So you are blowing to the rear of the planes not to the instruments. then block the other static port and blow water out the other port. Since the static system has been touched the qualified person needs to make sure the static system is now quality assured. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted May 26, 2018 Report Share Posted May 26, 2018 For me it has always been mud daubers. It is amazing how fast they can work. 1 Quote Link to comment Share on other sites More sharing options...
ShuRugal Posted May 26, 2018 Author Report Share Posted May 26, 2018 You might have an alt static valve under the panel by your left knee. If you have the drain by the battery, there is a connector that can be taken off by a qualified person and then block one static port and blow the water out the static port. So you are blowing to the rear of the planes not to the instruments. then block the other static port and blow water out the other port. Since the static system has been touched the qualified person needs to make sure the static system is now quality assured. When you say "by the battery", I assume you mean "by the radio tray in the tail"? Or should there be a tap in front of the firewall? Sent from my Pixel using Tapatalk Quote Link to comment Share on other sites More sharing options...
Yetti Posted May 26, 2018 Report Share Posted May 26, 2018 Sorry my F has the battery in the Radio compartment. And the drain to the static system in the rear of the plane. Some planes, My 75 F have a drain to the pitot tube located by the wing root down along the forward edge There should be a couple of connectors in the static tubing in the radio access area. Mine is a Y to static ports on either side of the plane. Quote Link to comment Share on other sites More sharing options...
