bradp Posted May 21, 2018 Report Share Posted May 21, 2018 Something that came up was (for everyone without a D Model) - gear up or gear down in a field. Gear up perhaps your stopping distance is shorter. Gear down perhaps you have some accouterments that can be shed to dissipate energy. Some Mooney POHs say either up or down. Thoughts? Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted May 21, 2018 Report Share Posted May 21, 2018 I'd have to make that decision "in situ". Not all farmers fields are created equal and you can't really see what you've bought until close. Even if I'd used the gear to dissipate energy prior to touchdown, I might raise it if the terrain looksd soft, or inhospitible on short final. 3 Quote Link to comment Share on other sites More sharing options...
Hank Posted May 22, 2018 Report Share Posted May 22, 2018 Yep. Ploughed ground or beans, gear up. Pastureland, corn, probably gear down. I rememberan ASI video about a Comanche going down in the desrt, the gear were pushed up through the wing by the broken groind. It would be bad to make that many sparks so close to the fuel tanks Landing across a slope or into trees? Maybe down to help dissipate some energy. All in all, it depends in what I see out tbe windshield. And with fast electric gear, I can change my mind pretty quickly. Quote Link to comment Share on other sites More sharing options...
cnoe Posted May 26, 2018 Report Share Posted May 26, 2018 I agree that the ultimate answer is situational but also agree with the interviewee that once the fan up front stops making power the goal is to use the airframe as a vehicle to minimize energy transfer to its occupants. The tubular steel framed cabin is perhaps the #1 Mooney attribute. As the old adage goes “if the engine quits it’s the insurance company’s plane”. Having made a few landings on grass strips I can testify that our gear isn’t very compliant on rough ground so it would have to appear quite smooth before I’d leave it down. And remember how robust our birds are when bellied in. When’s the last time you heard of a Mooney being scrapped following a gear-up landing?Therefore my default is likely to keep the gear up during an off-field and only drop it if a decent roll-out looks likely. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Boilermonkey Posted May 26, 2018 Report Share Posted May 26, 2018 I'd be concerned about catching one of the mains on uneven ground causing the aircraft to roll. Seems less likely with gear up.Sent from my Pixel using Tapatalk Quote Link to comment Share on other sites More sharing options...
Hank Posted May 27, 2018 Report Share Posted May 27, 2018 (edited) 7 hours ago, Boilermonkey said: I'd be concerned about catching one of the mains on uneven ground causing the aircraft to roll. Seems less likely with gear up. Sent from my Pixel using Tapatalk There are things hanging off the bottom of our planes that can dig in and catch on soft ground, too. Rolling ground can catch a flap, then there's that step hanging down on a steel tube, the belly strobe, flap hinges under each wing . . . . Who has belly antennas? Even the tail tie down ring could make life exciting. Edited May 27, 2018 by Hank Quote Link to comment Share on other sites More sharing options...
