So my Alcor 4 channel EGT is shot. I ordered a E4 digital EGT from Spruce. My mechanic has it halfway installed and now says I cannot use it in place of my primary Alcor  because it is not STC'd as a primary for my Mooney.
Has anyone else come across this? Does anyone have paperwork allowing this E4 install to be done on a J?
Edited by Fookz92
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
So my Alcor 4 channel EGT is shot. I ordered a E4 digital EGT from Spruce. My mechanic has it halfway installed and now says I cannot use it in place of my primary Alcor  because it is not STC'd as a primary for my Mooney.  Has anyone else come across this? Does anyone have paperwork allowing this E4 install to be done on a J?
My understanding is that on my (most) Mooneys the EGT gauge is not part of the type certificate or Car 3 basic equipment and is not required, thus it can be removed entirely if desired. Read “Car 3 § 3.655 Required basic equipment.” You can therefore replace the original gauge with a TSO replacement gauge to be used as an advisory instrument. Mine was yanked when the JPI830 went in and the AI was fine with it. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/6ee01384f2e646e986258100005b0b61/$FILE/2A3_Rev57.pdf
Share this post
Link to post
Grab the MEL out of the POH...
The Alcor Without Numbers on it, calibrated by a screw from the front panel isn’t much of a primary indicator...
Fookz,
  • got a pic of what you have?
  • got a link to what you bought?
  • got a POH with an MEL?
Anything would be better than the OEM EGT... But if you need to keep it per the reg... keep it and drill another hole for the new engine monitor...
PP thoughts only...
Share this post
Link to post
Your A&P is either incredibly new or incredibly old.  Either way, the EGT is not required equipment.
Share this post
Link to post
Even if the Alcor EGT was OEM equipment front the factory?
Share this post
Link to post
Fookz,
PP thoughts only...
Here is the pic. Look far right.
The POH I had to rebuild and used the POH Mooney supplied me with (N1220G)
Share this post
Link to post
The original radios were installed as OEM equipment from the factory, too.  All of that stuff is optional per the Type Certificate Data Sheet (TCDS).  Your A&P should know how to check that document, and you should have a downloaded copy as well.
Share this post
Link to post
+ 1
If it was me, I would rather put the money toward a engine monitor than just replace a 4 place EGT gauge. I'd be more concerned with CHT' than EGT and here's where i'd put it.
Share this post
Link to post
It looks like the link to your TCDS was bad so here you go again: http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/6ee01384f2e646e986258100005b0b61/$FILE/2A3_Rev57.pdf
Read page 30 carefully; the EGT gauge is not mentioned. It states that required equipment is spelled out in the CAR 3 standards which says you must have a CHT gauge but no EGT gauge. It’s therefore not required.
Also, our Part 91 Mooneys don’t have a “minimum equipment list” either.
Edited: Link still bad... try going here then doing a make/model search. http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/Frameset?OpenPage
Share this post
Link to post
I appreciate you sending that link over. I have reviewed page 30 and will pass along to my IA.
Here is what he is sending me and has the issue with.....
He is telling me that I can have the E4 installed only if the Alcor is operative because it was installed in the factory by Mooney.
Edited by Fookz92
Share this post
Link to post
As others have mentioned I respectfully believe he is mistaken. If we were talking about the CHT gauge I would agree because it is specified as a requirement in the CAR 3 documents; that has been an issue for all of us that have JPI 700-800 series. We have to retain the original CHT gauge because it is required, primary, and those JPI models are NOT certified as primary instruments.
Our planes were certified under CAR 3, not Part 23. That is also stated in the TCDS. That is what controls what is required in our planes.
Try this link for the CAR 3 regs: http://www.navioneer.org/riprelay/Yet%20More%20Navion%20Files/car_part3.pdf
The applicable page is attached as a screenshot.
Edited: Sorry another bad link, due to Tapatalk I suppose. You can google it; the navioneer site has a copy. Here’s what you’re looking for.
Share this post
Link to post
Which shop are you working with? I would have them call over to Weber’s or AirMod’s. It is optional equipment. Do you have the original factory paperwork. It might even say optional EGT.
Share this post
Link to post
I agree with comments above but it might be difficult to convince your A&P...
When I bought my M20F, it already had EI E4 installed in it in lieu of Alcor EGT.
Share this post
Link to post
interesting conversation
I had the EI single CHT and EGT in my plane before I changed too the G2 monitor.
Not to hijack the thread but I did find this.   I always wondered why we don't have a both option on our fuel selector valves.  Now I know.:D
FFuel system arrangement.
Fuel systems shall be so arranged as to permit any
one fuel pump to draw fuel from only one tank at
a time. Gravity feed systems shall not supply fuel
to any one engine from more than one tank at a
time unless the tank air spaces are interconnected
in such a manner as to assure that all
interconnected tanks will feed equally.
Share this post
Link to post
This might help you. Take a look at the original factory build sheet. For items that are part of the type certificate, it will be in the column with the type label:
For any “extra” equipment, it is listed this way:
Share this post
Link to post
Thanks all for the posts and suggestions. I was able to come up with the correct documentation to convince my IA to get this airplane signed off. This is the last piece of the puzzle. Thank you.
Share this post
Link to post
1243262122_UBG-16EGT.thumb.jpg.f2ebe3b0fc04d8043684031358544ca2.jpgI replaced my previous LCD EGT with the UBG-16. Very happy with it. It also shows fuel flow, OAT and voltage
Share this post
Link to post
Next annual I will upgrade to this. Was looking at JPI 450 Fuel computer to add in the panel along with this new E4 I am installing now. But since this has all of it in one instrument, this seems the way to go. And just scrap the E4  completely.
Share this post
Link to post
Piloto (a/k/a Jose Monroy) . . .  nice subliminal commercial for http://www.monroyaero.com/
Share this post
Link to post
The tag is to avoid mix ups at the repair station. So I know I am getting back my original unit.
José
Share this post
Link to post
Every Mooney should have Monroy Long Rang Tanks - makes your Mooney a traveling machine, extending the range and giving you a lot of options!!
Share this post
Link to post
With all due respect to Jose’s fine modification I personally have no need for it.
I can fly 990 nm for 6.6 hours (+ VFR reserve) with my stock tanks which is well beyond my personal limits.
IMO every Monroy LR tank installation should include a free Monroy relief assembly (along with a free belly-washing contract). But until there’s female-friendly and dog-friendly options I’ll have to keep limiting my flights to 990 nm or less.
Share this post
Link to post
Hunter,
It looks to me like that EGT system was installed at the Factory via Supplemental Type Certificate (STC), so No, it won't be on the TCDS. However in order to remove it correctly, another 337 should be completed to remove the STC (and therefore the gauge) from the airplane.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
