milotron Posted May 27, 2018 Report Share Posted May 27, 2018 On 5/19/2018 at 6:45 PM, gsxrpilot said: Nope, that will do it. I had a very similar situation with a 530W and a 330. Get the ES upgrade and reinstall. Done. In addition to the GPS input, what was used for for the 'ground' function? Air speed switch, squat switch or does the 330 not need this? iain Quote Link to comment Share on other sites More sharing options...
ragedracer1977 Posted May 27, 2018 Report Share Posted May 27, 2018 3 hours ago, LANCECASPER said: If that includes the 330 to 330ES upgrade from Garmin and installation that's a great deal. Yup, that’s the whole enchilada 1 Quote Link to comment Share on other sites More sharing options...
Chris from PA Posted May 27, 2018 Report Share Posted May 27, 2018 Following. I also have a 327 and would like to swap it for a 330 ES to check the ADSB-out box. Sent from my SM-T350 using Tapatalk Quote Link to comment Share on other sites More sharing options...
nels Posted May 28, 2018 Report Share Posted May 28, 2018 Ok, I’m going to admit I’m pretty ignorant when it comes to adsb out solutions but I’m now starting to look around at what is available at a good price. The Garmin GDL82 looks real reasonable to buy and a pretty much install yourself and have it signed off piece of equipment? Price is under 1800 and connects to your original transponder. If it isn’t what you want in a few years you could probably remove it and sell for 70% of the original price. I assume all you are looking for is adsb compliance for now. Let me know if lm in left field as I’m in a learning mode myself. Quote Link to comment Share on other sites More sharing options...
whiskytango Posted May 28, 2018 Report Share Posted May 28, 2018 +1 on having the 330 converted to an ES and using the CNX480 as a WAAS source. This was painless and cost effective. Quote Link to comment Share on other sites More sharing options...
bradp Posted May 30, 2018 Report Share Posted May 30, 2018 The 330ES uses software to determine air / ground ADS-B The latest revision of the Kt-74 also had an update for software based a/g switching. However, the perregrine STC may or may not have updated to get rid of the need for the airspeed switch. ES in my opinion is a simpler installation for folks that want OUT and already have a waas source. Quote Link to comment Share on other sites More sharing options...
