*Members that donate $10 or more do not see advertisements*
Yes - I see it's preorder and yes it's not certifed - but it does show that folks are thinking out of the box.....
https://www.gulfcoastavionics.com/products/4325-skybeacon-ads-b-system.aspx
They are also trying to certify a tail light version of this that is even more appealing in my view, but I do worry that it will literally take 5seconds to steal one of these and they are not exactly cheap.
Share this post
Link to post
Share on other sites
Share this post
Link to post
I'm not sure how well this will fit on a pre-1984 Mooney. Later models no deal.
Share this post
Link to post
That may work, but its vaporware. And changes the balance on a moveable surface, which requires one to remove the rudder and balance it. most avionics shops dont do that, so you have to take it or have them take it to a shop to have that done.  And when its all said and done, the garmin GDL-82 will likely cost the same or less. I can totally see this for a flight school 150, or 172 though. and there are millions of those.
Edited by jetdriven
Share this post
Link to post
I doubt it would need to be installed by an avionics shop, since they were touting it as a minor modification (the wingtip version, anyway).  On the other hand, if it ends up being a major modification that requires an avionics shop, that would defeat a lot of the initial purpose...
Share this post
Link to post
65 and older Mooneys, the tail light version of the vaporware... isn’t attached to anything moving. Just a tail cone for that...
If my memory still holds...
ADSB out and an I’m stolen message, serialized, automatically sent....with location.... (possibly)  :)
Verify the serial number before buying a used one.
Share this post
Link to post
Tail cone on the ‘66. Although my RV buddy refers to it as a “back-up light.” He enjoys out running Mooneys.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
