nels Posted April 2, 2018 Report Share Posted April 2, 2018 Probably never do this but it would be nice to have the capability to fly from Cincinnati to Denver non stop. Is there any structural improvements needed in the wing or is it basically adding another filler neck, adding the weep through holes at the bottom of the ribs and adding sealant? How much capacity is gained when done to a J model? Quote Link to comment Share on other sites More sharing options...
kpaul Posted April 2, 2018 Report Share Posted April 2, 2018 2 minutes ago, nels said: Probably never do this but it would be nice to have the capability to fly from Cincinnati to Denver non stop. Is there any structural improvements needed in the wing or is it basically adding another filler neck, adding the weep through holes at the bottom of the ribs and adding sealant? How much capacity is gained when done to a J model? www.monroyaero.com Says 36 Gal. $3000 plus install. Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 2, 2018 Report Share Posted April 2, 2018 STC and tank sealant Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 2, 2018 Report Share Posted April 2, 2018 Consider digital fuel floats when going through the planning phase... Connected to a digital engine monitor... Combined with GPS data... Possibly the best fuel knowledge a pilot can have... Fuel burn to destination. alarm if not going to make it... Lots of details to get right... lots of benefits if done properly... PP thoughts only, not an instruments guy... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
kortopates Posted April 2, 2018 Report Share Posted April 2, 2018 www.monroyaero.com Says 36 Gal. $3000 plus install. I recall 30 if you have speed brakes too.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Emmet Posted April 2, 2018 Report Share Posted April 2, 2018 Monroy Longrange Tank installationhttps://r.tapatalk.com/shareLink?share_fid=55491&share_tid=24793&url=https%3A%2F%2Fwww%2Emooneyspace%2Ecom%2Findex%2Ephp%3F%2Ftopic%2F24793-Monroy-Longrange-Tank-installation&share_type=t Quote Link to comment Share on other sites More sharing options...
nels Posted April 2, 2018 Author Report Share Posted April 2, 2018 1 hour ago, Emmet said: Monroy Longrange Tank installationhttps://r.tapatalk.com/shareLink?share_fid=55491&share_tid=24793&url=https%3A%2F%2Fwww%2Emooneyspace%2Ecom%2Findex%2Ephp%3F%2Ftopic%2F24793-Monroy-Longrange-Tank-installation&share_type=t How in the world did I miss that discussion?? That sure filled in a lot of blanks. Pilato mentioned, in that discussion, an AN fitting to transfer the fuel, is this a siphon method or just a hole at the bottom between the standard cell and the added cell? 1 Quote Link to comment Share on other sites More sharing options...
